12032GA (Ø120 X 32L)
Legacy Part No. BG1203
NMBTC.COM / 248.919.2250
Characteristic Curves
General Specifications
Motor Protection:
(Pa)
In H2O
1.1
275
Auto Restart/Polarity Protection
Insulation Resistance:
10M Ω or over with a DC500V Megger
-10°C ~ +60°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
Ps
Expected Life
.8
200
225
.7
N
M
175
.6
150
.5
L
125
.4
K
100
.3
.2
75
50
.1
Failure Rate: 10%
25°C
250
DC
DCAxial
Blowers
Fans
Static Pressure
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
1.0
.9
25
100,000 Hours
0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0
3.5
Material
10.6
17.6 27.9
Air Flow
31.7
(m3/min)
CFM
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Ball Bearing
Lead Wire : UL1007, AWG24, +Red, -Black
4.13
(105 ± 0.3)
4.72
(120 ± 1)
.30
(7.5)
LOT No.
DIE-CAV No.
2.56
(65 ± 0.3)
.59
(15)
3.62
(92 ± 0.3)
.29
(7.5)
NAME
PLATE
3.46
(88 ± 0.3)
.30
(7.5)
.29
(7.5)
3.62
(92 ± 0.3)
AIR
4.13
(105 ± 0.3)
4.72
(120 ± 1)
2.16
(55)
2.4
(61 ± 0.5)
ROTATION
AIR
1.26
(32 ± 0.5)
.08
(2 ± 0.2)
11.8
(300) min
inch
Units: (mm)
.30(7.5)
.87(22)
Outline
3.54
(90 ± 0.3)
3.46
(88 ± 0.3)
THROUGH HOLE
.176
9 – (φ4.3 ± 0.3)
Specifications
MODEL
LEGACY P/N
Rated Operating Current Input Speed
Voltage Voltage
Power
(V)
(V)
(A)*1
(W)*1
(min-1)*1
12032GA-12K-AA-00
BG1203-B042-000-00
12
6 ~ 13.8
0.30
3.60
12032GA-12L-AA-00
BG1203-B043-000-00
12
6 ~ 13.8
0.48
5.78
12032GA-12M-AA-00
BG1203-B044-000-00
12
6 ~ 13.8
0.65
12032GA-12N-AA-00
BG1203-B045-000-00
12
6 ~ 13.8
12032GA-24K-AA-00
BG1203-B052-000-00
24
12032GA-24L-AA-00
BG1203-B053-000-00
12032GA-24M-AA-00
BG1203-B054-000-00
12032GA-24N-AA-00
BG1203-B055-000-00
Rotation: Counterclockwise
Max.
Air Flow
Max. Static
Pressure
Noise Mass
CFM*1 (m3/min)*1 in H2O
(Pa)*1
(dB)*1
1800
22.2
0.63
.40
100
41.5
270
2100
26.1
0.74
.58
145
46.5
270
7.80
2250
28.2
0.80
.70
175
48.5
270
0.93
11.16
2650
33.2
0.94
1.04
260
54.0
270
12 ~ 27.6
0.17
4.08
1800
22.2
0.63
.40
100
41.5
270
24
12 ~ 27.6
0.25
6.00
2100
26.1
0.74
.56
145
46.5
270
24
12 ~ 27.6
0.30
7.20
2250
28.2
0.80
.70
175
48.5
270
24
12 ~ 25.2
0.48
11.52
2650
33.2
0.94
1.04
260 54.0 270
*1: Average Values in Free Air
Note: PWM/Locked Rotor/Tach Available
(g)
2.3
很抱歉,暂时无法提供与“BG1203-B045-00S-00”相匹配的价格&库存,您可以联系我们找货
