06038DA (60 X 38L)
NMBTC.COM / 248.919.2250
Characteristic Curves
General Specifications
Motor Protection:
In H2O
Auto Restart/Polarity Protection
Insulation Resistance:
10M Ω or over with a DC500V Megger
Static Pressure
-10°C ~ +70°C (Operating)
-30°C ~ +70°C (Storage)
(non-condensing environment)
4.00
1000
3.20
800
2.40
600
1.60
400
.80
200
R Class
Q Class
Ps
Expected Life
Failure Rate: 10%
40°C
S Class
70,000 Hours (L10)
Material
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Ball Bearing
Lead Wire : UL10368, AWG24, +Red, -Black
(m3/min)
35.3
52.95
70.6
CFM
7.88
min (200)
AIR
.177
(4 – φ4.5)
(4 – φ4.5)
2.28
(58.0)
1.97
(50.0)
52
2. 4.0)
6
(φ
.157
(4.0 ±0.3 )
1.77
(8 – φ 4.5 ±0.3)
2.36
(60.0 ±1.0 )
1.97
(50.0 ±0.3)
.177
(φ 2.4
63 8
.0
2.0
ROTATION
Panel Cut-Outs
2.28
(58.0)
1.97
(50.0)
1.5
Air Flow
Outline
inch
Units: (mm)
1.0
1.97
(50.0 ±0.3 )
2.36
(60.0 ±1.0 )
.157
(4.0 ±0.3)
1.49
(38.0 ±0.5 )
1.97
(50.0)
2.28
(58.0)
1.97
(50.0)
2.28
(58.0)
INLET SIDE
OUTLET SIDE
NAME
PLATE
Specifications
Rated
Operating
Voltage
Voltage
Power
(V)
(V)
(A)*1 (W)*1 (min-1)*1
06038DA-12Q-EA-D0
12
10.8 ~ 13.2
0.78
9.40
13000
50.5
1.43
2.31 575.0
58.0
123
06038DA-12R-EA-D0
12
10.8 ~ 13.2
1.16
14.00
15000
58.6
1.66
2.97 740.0
61.5
123
06038DA-12S-EA-D0
12
10.8 ~ 13.2
1.65
19.80
17000
66.4
1.88
3.71 925.0
63.5
123
MODEL
Rotation: Clockwise
Current
Airflow Outlet: Air Out Over Struts
Input
Speed
Max.
Max. Static
Air Flow
Pressure
CFM*1 (m3/min)*1 in H2O
*1: Average Values in Free Air
Noise
Mass
(Pa)*1 (dB)*1 (g)
Note: PWM/Locked Rotor/Tach Available
DC Axial Fans
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
(Pa)
很抱歉,暂时无法提供与“06038DA-12S-EU-D0”相匹配的价格&库存,您可以联系我们找货
