1619FT-04W-B86-B50
1619FT-04W-B86-B50
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 40X48MM 12VDC WIRE
1619FT-04W-B86-B50 数据手册
1619FT (40 X 48L) NMBTC.COM / 818.341.3355 PATENT PENDING Characteristic Curves General Specifications Motor Protection: (Pa) P-Q Curve Auto Restart/Polarity Protection 4.00 1000 25000 min 10M Ω by DC500V Megger 3.20 800 20000 Static Pressure In H2O 2.40 600 15000 Ps 1.60 400 10000 .80 200 5000 Insulation Resistance: Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: -10°C ~ +60°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Expected Life 0 Failure Rate: 10% 40°C 70,000 Hours 0 0. 0.2 0.4 0.6 0.8 1.0 0.0 7 14 21 28 35 Speed Speed Curve (m3/min) CFM Air Flow PATENT PENDING inch Units: (mm) .137 (4 – F3.5 ± 0.3) 1.57 (40.0 ± 0.5) 1.26 32.0 ± 0.3 .137 (4 – F3.5± 0.3) AIR NAME PLATE 62 1. 1.2 F4 0 R .11 2. 9 1.51 (38.4) 1.26 (32.0) 57 1. 40) ( 1.51 (38.4) 1.26 (32.0) 7.88 (200± 15) .137 (4 – F3.5 ± 0.3) ROTATION 1.26 (32.0) 1.51 (38.4) LOT NO. DC Axial Fans - TurboFans Panel Cut-outs Outline 1.26 (32.0) 1.51 (38.4) INLET SIDE OUTLET SIDE Material 0.197 (5) 1.89 (48.0 ± 0.5) 0.197 (5) Casing : Plastic (Black) 94V-0 Impeller : Plastic (Black) 94V-0 Bearing : Ball Bearing Lead Wire : UL10368, AWG24, +Red, -Black Tach Sig. : White PWM Control : Brown 1.26 (32± 0.3) 1.57 (40.0 ± 0.5) Reference PWM Duty vs Speed Curve PWM Control Voltage at Vin=12VDC, f=25.0kHz, Vst=4.5V(Hi)/0V(Lo), Ta=25˚C Vst = 0V ~ 0.5V Stop (On Duty 0%) Vst = 3.3V ~ 5.0V Full Speed (On Duty 100%) Vst = Open Full Speed (At Ta = 25°C, rated voltage 12VDC) 30000 Speed [min -1] 25000 20000 max 15000 min 10000 5000 0 0 Rated Voltage Operating Voltage Current Input Power Speed Product No. (V) (V) (A)*1 (W)*1 (min-1)*1 BXX 12 10.8 ~ 13.2 1.05 12.60 23,000 MODEL 1619FT-04W-B86- Rotation: Clockwise Airflow Outlet: Air Out Over Struts 20 40 60 80 100 PWM Duty 0% Duty Stop Max. Air Flow Noise Mass CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 28.9 62.0 71 0.82 *1: Average Values in Free Air Max. Static Pressure 3.29 820.0 0.0
1619FT-04W-B86-B50 价格&库存
很抱歉,暂时无法提供与“1619FT-04W-B86-B50”相匹配的价格&库存,您可以联系我们找货
