LI98-1120-12-0.25
LI98-1120-12-0.25
    T-GLOBAL
    Thermal Pad White 1.12m x 12.00mm Rectangle Adhesive - Both Sides
LI98-1120-12-0.25 数据手册
Li98 Thermal Tape Version 4.05122019 Thermal Tape Li98 thermal tapes are double-sided thermal interface tapes and provide exceptional bonding properties between electronic components and heat sinks, eliminating the need for mechanical fasteners. Li98 can be offered in various formats such as sheets, rolls and die cut parts depending on the applications and have proven reliability under various mechanical, thermal, and environmental stresses. Features Good adhesion (Acrylic PSA) Great reliability Cost effective with great performance Easy to assemble Applications Electronic components: IC, CPU, MOS LED, M/B, P/S, Heat Sink LCD, TV, Notebook PC, PC Telecom Device, Wireless Hub, etc. DDR II Module, DVD Applications, Hand-set applications, etc. Properties REACH Compliant ROHS Compliant Property Li98 Li98C Colour Liner Colour Thickness Thermal Conductivity Unit Tolerance Test Method - - Visual Green Red 0.15 0.25 0.15 0.25 0.18 mm - ASTM D374 0.0059 0.00984 0.0059 0.00984 0.00709 inch - ASTM D374 0.95 0.95 1.8 1.8 2 W/mK ±0.10% ASTM D5470 °C - - Continuous Working Temperature White -30 to 120 Short Time Using Temperature 200 Density Tensile Strength Li98CN White 1.85 200 Glass Transition Temperature 1.8 400 200 -30 400 -27 °C - - g/cm3 ±1.3 ASTM D792 psi - ASTM D412 -30 °C - - Initial Tack 10 8 14 12 15 cm - PSTC-6 Lap Shear Strength 61 55 55 50 55 N/cm2 - ASTM D1002 Die Shear Strength 25 °C 120 109 109 100 100 N/cm2 ±0.2 - Die Shear Strength 80 °C 69 68 55 N/cm2 - - Holding Power 1000g 25 °C 68 >10000 Holding Power 1000g 80 °C min - PSTC-7 min - PSTC-7 90° Peeling Strength >10 >12 >6 >8 >8 N/in - ASTM D3330 Dielectric Breakdown Voltage (AC) 2 3 2 3 5 kV ±0.10% ASTM D149 Dielectric Breakdown Voltage (DC) 3 4 3 4 6 kV ±0.10% ASTM D149 Reinforcement Carrier Fiberglass Mesh - - - Shelf Life (can be requalified for further 12) 12 months - - T-Global Technology Limited 1 & 2 Cosford Business Park, Central Park, Lutterworth, Leicestershire LE17 4QU U.K. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology VAT #: GB 116 662 714 Thermal Impedance vs Pressure vs Deflection Li98 Thermal Tape Standard Weights & Dimensional Tolerance Thickness (mm) Tolerance (mm) 0.3 ±0.03 0.5 ±0.05 0.25 0.8 ±0.08 Weights (g) Size Thickness (mm) 0.15 100x100 2.78 4.63 1.0 ±0.1 150x150 6.24 10.41 1.2 ±0.12 300x300 24.98 41.63 1.5 ±0.15 320x320 28.42 47.36 2.0 ±0.2 2.5 - 3.5 ±0.25 Die-Cut Thickness Tolerances Data 4.0 - 4.5 ±0.3 ±0.35 Digi-Key Part T-Global Part 5.0 1168-1715-ND LP0001/01-Li98-0.15 6.0 - 8.0 ±0.4 1168-1908-ND LP0007/01-Li98-0.25 9.0 ±0.45 1168-1867-ND LP0003/01-Li98-0.25 10.0 ±0.5 1168-1845-ND TG-CPCB1-Li98-0.15 >10.0 ±0.5 1168-1843-ND TG-CPCB2-Li98-0.15 1168-1841-ND TG-CPCB3-Li98-0.15 1168-1847-ND LP0001/01-Li98-0.25 1168-1857-ND LP0002/01-Li98-0.25 1168-1907-ND LP0007/01-Li98-0.15 1168-1763-ND LP0003/01-Li98-0.15 1168-1718-ND LP0002/01-Li98-0.15 1168-1766-ND LP0004/01-Li98-0.15 1168-1769-ND LP0005/01-Li98-0.15 1168-1877-ND LP0004/01-Li98-0.25 1168-1772-ND LP0006/01-Li98-0.15 1168-1887-ND LP0005/01-Li98-0.25 1168-1897-ND LP0006/01-Li98-0.25 Digi-Key Part T-Global Part 1168-1715-ND LP0001/01-Li98-0.15 1168-1908-ND LP0007/01-Li98-0.25 1168-1867-ND LP0003/01-Li98-0.25 1168-1845-ND TG-CPCB1-Li98-0.15 1168-1843-ND TG-CPCB2-Li98-0.15 1168-1841-ND TG-CPCB3-Li98-0.15 Thickness Material 0.0007” Acrylic (0.178mm) Elastomer Adhesive Backing Carrier Thermal Conductivity Both sides Fiberglass 2.0 W/m-K * Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application. NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent otherwise stated in T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and all liabilities incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with existing or future patents covering any product or material or its use. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
LI98-1120-12-0.25 价格&库存
很抱歉,暂时无法提供与“LI98-1120-12-0.25”相匹配的价格&库存,您可以联系我们找货
