H48-6-150-150-0.3-2A
    T-GLOBAL
    H48-6 SHEET 150X150X0.3MM W/ADH
H48-6-150-150-0.3-2A 数据手册
H48-6 Thermal Conductive Pad Version 4.270318 Thermal Conductive Pad H48-6 is a silicone based thermal interface pad which offers a good combination of low thermal impedance, good compressibility and a high dielectric breakdown voltage. H48-6 is available in numerous different formats such as custom die cuts or standard sheets. Additionally, both custom die cut pads and standard sheets can be supplied with either one of two side thermally conductive adhesive applied for greater ease of manufacture. Features Good thermal conductivity Ultra-soft and high compressibility Natural tack Easy to assemble Good insulator Shock and vibration absorber Applications Electronic components: IC, CPU, MOS LED - M/B, P/S, Heat Sink LCD, TV, Notebook PC, PC Telecom Device, Wireless Hub, etc. DDR II Module, DVD Applications, Hand-set applications, etc. Properties REACH Compliant ROHS Compliant Property H48-6 Unit Tolerance Test Method Colour Dark Grey - - Visual Thickness (Available thickness range) 0.3 - 10 mm - ASTM D374 0.0118 - 0.787 inch - ASTM D374 Thermal Conductivity 3.2 W/mK ±0.3 ASTM D5470 Flammability Rating V-0 - - UL 94 Dielectric Breakdown Voltage 2 kV/mm ±0.2 ASTM D149 Weight Loss 10 Ohm-cm - ASTM D257 Elongation 130 % - ASTM D412 Tensile Strength 8 Kgf/cm - ASTM D412 Hardness 30 Shore A ±10 ASTM D2240 Shelf Life 36 months - - Shelf Life with adhesive (can be requalified for a further 12) 12 months - - 11 2 Thermal Impedance vs Pressure vs Deflection T-Global Technology Limited 1 & 2 Cosford Business Park, Central Park, Lutterworth, Leicestershire LE17 4QU U.K. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology VAT #: GB 116 662 714 H48-6 Thermal Conductive Pad Standard Weights & Dimensional Tolerance Size Weights (g) Thickness (mm) 0.30 0.50 0.80 1.00 1.50 2.00 2.50 3.00 3.50 4.00 4.50 5.00 100x100 7.29 12.15 19.44 24.30 36.45 48.60 60.75 72.90 85.05 97.20 109.35 121.50 150x150 16.40 27.34 43.74 54.68 82.01 109.35 136.69 164.03 191.36 218.70 246.04 273.38 300x300 65.61 109.35 174.96 218.70 328.05 437.40 546.75 656.10 765.45 874.80 984.15 1,093.50 320x320 74.65 124.42 199.07 248.83 373.25 497.66 622.08 746.50 870.91 995.33 1,119.74 1,244.16 Thickness (mm) 5.50 6.00 6.50 7.00 7.50 8.00 8.50 9.00 9.50 10.00 100x100 133.65 145.80 157.95 170.10 182.25 194.40 206.55 218.70 230.85 243.00 150x150 300.71 328.05 355.39 382.73 410.06 437.40 464.74 492.08 519.41 546.75 300x300 1,202.85 1,312.20 1,421.55 1,530.90 1,640.25 1,749.60 1,858.95 1,968.30 2,077.65 2,187.00 320x320 1,368.58 1,492.99 1,741.82 1,866.24 1,990.66 2,115.07 2,239.49 2,363.90 2,488.32 1,617.41 Data Die-Cut Thickness Tolerances Thickness (mm) Tolerance (mm) 0.3 ±0.03 0.5 ±0.05 0.8 ±0.08 1.0 ±0.1 1.2 ±0.12 1.5 ±0.15 2.0 ±0.2 2.5 - 3.5 ±0.25 4.0 - 4.5 ±0.3 5.0 ±0.35 6.0 - 8.0 ±0.4 9.0 ±0.45 10.0 ±0.5 >10.0 ±0.5 * Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application. NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent otherwise stated in T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and all liabilities incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with existing or future patents covering any product or material or its use. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
H48-6-150-150-0.3-2A 价格&库存
很抱歉,暂时无法提供与“H48-6-150-150-0.3-2A”相匹配的价格&库存,您可以联系我们找货
