PC93-10-10-1
PC93-10-10-1
    T-GLOBAL
    THERMAL PAD 10X10X1MM
PC93-10-10-1 数据手册
PC93 Non-Silicone Thermal Conductive Pad Version 2.160819 Non-Silicone Thermal Conductive Pad PC93 is a soft, non-silicone thermal interface pad designed to replace traditional thermal pads in silicone-sensitive applications. Typical uses include, set-top boxes, optical and automotive projects. PC93 can be provided in a range of different thicknesses and formats depending on the end use. Features Low contact thermal impedance Good thermal conductivity Silicone free Long term stability Applications Electronic components: IC, CPU, MOS LED, M/B, P/S, Heat Sink LCD TV, Notebook PC, PC Telecom Device, Wireless Hub, etc. DDR II Module, DVD Applications, Hand-set applications, etc. Properties REACH Compliant ROHS Compliant Property PC93 Unit Tolerance Colour Grey - - Visual Thickness (Available thickness range) 0.50 - 5.0 mm - ASTM D374 0.0197 - 0.1969 inch - ASTM D374 Thermal Conductivity 2.1 W/mK ± 10% ASTM D5470 Flammability Rating V-0 - - UL 94 Dielectric Breakdown Voltage 10.2 kV/mm ±1 ASTM D149 Weight Loss ‹1 % - ASTM E595 Density 2.1 g/cm³ ± 0.2 ASTM D792 Working Temperature -30 to +125 ˚C - - Volume Resistance ›10 Ohm-cm - ASTM D257 Elongation 350 % - ASTM D412 Tensile Strength 1 Kgf/mm² - ASTM D412 Hardness 55 Shore 00 ± 10 ASTM D2240 10 Thermal Impedance vs Pressure vs Deflection T-Global Technology Limited 1 & 2 Cosford Business Park, Central Park, Lutterworth, Leicestershire LE17 4QU U.K. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com VAT #: GB 116 662 714 Test Method Pressure (psi) R(°C-in²/W) Deflection (%) 10 1.01 16 20 0.95 32 40 0.74 43 PC93 Non-Silicone Thermal Conductive Pad Standard Weights & Dimensional Tolerance Size Thickness (mm) 0.50 0.80 1.00 1.50 2.00 2.50 3.00 3.50 4.00 4.50 5.00 100x100 10.50 16.80 21.00 31.50 42.00 52.50 63.00 73.50 84.00 94.50 105.00 150x150 23.63 37.80 47.25 70.88 94.50 118.13 141.75 165.38 189.00 212.63 236.25 300x300 94.50 151.20 189.00 283.50 378.00 472.50 567.00 661.50 756.00 850.50 945.00 320x320 107.52 172.03 215.04 322.56 430.08 537.60 645.12 752.64 860.16 967.68 1,075.20 * All measurements in mm Die-Cut Thickness Tolerances Thickness (mm) Tolerance (mm) 0.3 ±0.03 0.5 ±0.05 0.8 ±0.08 1.0 ±0.1 1.2 ±0.12 1.5 ±0.15 2.0 ±0.2 2.5 - 3.5 ±0.25 4.0 - 4.5 ±0.3 5.0 ±0.35 6.0 - 8.0 ±0.4 9.0 ±0.45 10.0 ±0.5 >10.0 ±0.5 * Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application. NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent otherwise stated in T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and all liabilities incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with existing or future patents covering any product or material or its use. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com
PC93-10-10-1
物料型号:PC93 器件简介:PC93是一种柔软的非硅导热界面垫,设计用于替代硅敏感应用中的传统导热垫。典型用途包括机顶盒、光学和汽车项目。 引脚分配:文档中未提供引脚分配信息。 参数特性:包括颜色(灰色)、厚度范围(0.50-5.0mm或0.0197-0.1969英寸)、热导率(2.1 W/mK)、阻燃等级(V-0)、介电击穿电压(10.2 kV/mm)、重量损失(<1%)、密度(2.1 g/cm³)、工作温度范围(-30至+125°C)、体积电阻(>10^10 Ohm-cm)、伸长率(350%)、拉伸强度(1 Kgf/mm²)、硬度(55 Shore 00)。 功能详解:文档中未提供功能详解应用信息:适用于电子元件(如IC、CPU、MOS)、LED、主板、电源、散热器、液晶电视、笔记本电脑、个人电脑、电信设备、无线中心等。 封装信息:提供了不同厚度的标准重量和尺寸公差。
PC93-10-10-1 价格&库存
很抱歉,暂时无法提供与“PC93-10-10-1”相匹配的价格&库存,您可以联系我们找货
