ulTIMiFlux Thermal Gap Filling Pad
SILICONE BASED THERMALLY CONDUCTIVE GAP FILLER
FEATURES AND BENIFITS
● Excellent Thermal Conductivity
● Natural Tackiness – no need for adhesive
● Excellent Compression Characteristics
● Good Wet-Out and Superb Flexibility
● Excellent Converting Properties
● RoHS and HF Compliant
Wakefield-Vette's ulTIMiFlux line of thermal interface materials offer high performance, low cost, configurability and
custom sizes for your thermal system needs. Thermal Interface Materials (TIM) are a secondary material installed between
the heat sink and the device which are designed to improve the thermal transfer to the heat sink. Regardless of how flat or
smooth the device and heat sink are, there will always be small air voids between the two surfaces. Since air is a not a great
conductor of heat, a TIM replaces the air and fills the voids. There are many types of TIMs and each has its best case
usages. Wakefield-Vette’s line of thermal gap filling pads are intended to fill a large void between a device and the heat
sink. A gap pad is a compressible material most commonly used when there are multiple devices to be contacted to the heat
sink, but all the different device heights make it difficult to use a thin material. These materials come in a variety of
thicknesses, conductivities, and durometers to meet a wide range of needs.
Part Number Configurator: PL-Thickness- W/ m K- Foot Print – Hypersoft Option
WV Part Number
Description
Size
Thermal
Conductivity
Hardness
(Shore 00)
PL-05-1-254
0.5mm Thickness 1 W/m K Silicone Gap Filler
25.4mm X 25.4mm
1 W/m K
5
PL-05-1-1016
101.6mm X 101.6mm
1 W/m K
5
PL-1-1-254
1.0mm Thickness 1 W/m K Silicone Gap Filler
25.4mm X 25.4mm
1 W/m K
5
PL-1-1-1016
101.6mm X 101.6mm
1 W/m K
5
PL-2-1-254
2.0mm Thickness 1 W/m K Silicone Gap Filler
25.4mm X 25.4mm
1 W/m K
5
PL-2-1-1016
101.6mm X 101.6mm
1 W/m K
5
PL-05-3-254-H
0.5mm Thickness 3 W/m K Hypersoft Silicone Gap Filler
25.4mm X 25.4mm
3 W/m K
PL-05-3-1016-H
101.6mm X 101.6mm
3 W/m K
PL-05-3-254
0.5mm Thickness 3 W/m K Silicone Gap Filler
25.4mm X 25.4mm
3 W/m K
35
PL-05-3-1016
101.6mm X 101.6mm
3 W/m K
35
PL-1-3-254-H
1.0mm Thickness 3 W/m K Hypersoft Silicone Gap Filler
25.4mm X 25.4mm
3 W/m K
PL-1-3-1016-H
101.6mm X 101.6mm
3 W/m K
PL-1-3-254
1.0mm Thickness 3 W/m K Silicone Gap Filler
25.4mm X 25.4mm
3 W/m K
35
PL-1-3-1016
101.6mm X 101.6mm
3 W/m K
35
PL-2-3-254-H
2.0mm Thickness 3 W/m K Hypersoft Silicone Gap Filler
25.4mm X 25.4mm
3 W/m K
PL-2-3-1016-H
101.6mm X 101.6mm
3 W/m K
PL-2-3-254
2.0mm Thickness 3 W/m K Silicone Gap Filler
25.4mm X 25.4mm
3 W/m K
35
PL-2-3-1016
101.6mm X 101.6mm
3 W/m K
35
PL-05-5-254-H
0.5mm Thickness 5 W/m K Hypersoft Silicone Gap Filler
25.4mm X 25.4mm
5 W/m K
40
PL-05-5-1016-H
101.6mm X 101.6mm
5 W/m K
40
PL-05-5-254
0.5mm Thickness 5 W/m K Silicone Gap Filler
25.4mm X 25.4mm
5 W/m K
45
PL-05-5-1016
101.6mm X 101.6mm
5 W/m K
45
PL-1-5-254-H
1.0mm Thickness 5 W/m K Hypersoft Silicone Gap Filler
25.4mm X 25.4mm
5 W/m K
40
PL-1-5-1016-H
101.6mm X 101.6mm
5 W/m K
40
PL-1-5-254
1.0mm Thickness 5 W/m K Silicone Gap Filler
25.4mm X 25.4mm
5 W/m K
45
PL-1-5-1016
101.6mm X 101.6mm
5 W/m K
45
PL-2-5-254-H
2.0mm Thickness 5 W/m K Hypersoft Silicone Gap Filler
25.4mm X 25.4mm
5 W/m K
40
PL-2-5-1016-H
101.6mm X 101.6mm
5 W/m K
40
PL-2-5-254
2.0mm Thickness 5 W/m K Silicone Gap Filler
25.4mm X 25.4mm
5 W/m K
45
PL-2-5-1016
101.6mm X 101.6mm
5 W/m K
45
Custom Sizes Available Upon Request: www.wakefield-vette.com
WV Part Number
Description
Size
Color
Shelf Life
Thermal
Conductivity
Dielectric
Breakdown
Strength
Hardness
(Shore 00)
PL-05-1-254
25.4mm X 25.4mm
Gray
3 Years
1 W/m K
>5KVac
5
PL-05-1-1016
101.6mm X 101.6mm
Gray
3 Years
1 W/m K
>5KVac
5
PL-1-1-254
25.4mm X 25.4mm
Gray
3 Years
1 W/m K
>5KVac
5
PL-1-1-1016
101.6mm X 101.6mm
Gray
3 Years
1 W/m K
>5KVac
5
PL-2-1-254
25.4mm X 25.4mm
Gray
3 Years
1 W/m K
>5KVac
5
PL-2-1-1016
101.6mm X 101.6mm
Gray
3 Years
1 W/m K
>5KVac
5
Dielectric
Breakdown
Strength
Hardness
(Shore
00)
WV Part Number
Description
Size
Color
Shelf Life
Thermal
Conductivity
PL-05-3-254-H
25.4mm X 25.4mm
Green
3 Years
3 W/m K
>5KVac
PL-05-3-1016-H
101.6mm X 101.6mm
Green
3 Years
3 W/m K
>5KVac
PL-05-3-254
25.4mm X 25.4mm
Green
3 Years
3 W/m K
>5KVac
35
PL-05-3-1016
101.6mm X 101.6mm
Green
3 Years
3 W/m K
>5KVac
35
PL-1-3-254-H
25.4mm X 25.4mm
Green
3 Years
3 W/m K
>5KVac
PL-1-3-1016-H
101.6mm X 101.6mm
Green
3 Years
3 W/m K
>5KVac
PL-1-3-254
25.4mm X 25.4mm
Green
3 Years
3 W/m K
>5KVac
35
PL-1-3-1016
101.6mm X 101.6mm
Green
3 Years
3 W/m K
>5KVac
35
PL-2-3-254-H
25.4mm X 25.4mm
Green
3 Years
3 W/m K
>5KVac
PL-2-3-1016-H
101.6mm X 101.6mm
Green
3 Years
3 W/m K
>5KVac
PL-2-3-254
25.4mm X 25.4mm
Green
3 Years
3 W/m K
>5KVac
35
PL-2-3-1016
101.6mm X 101.6mm
Green
3 Years
3 W/m K
>5KVac
35
Dielectric
Breakdown
Strength
Hardness
(Shore 00)
WV Part Number
Description
PL-05-5-254-H
PL-05-5-1016-H 0.5mm Thickness 5 W/m K Hypersoft Silicone Gap Filler
Size
Color
Shelf Life
Thermal
Conductivity
25.4mm X 25.4mm
Gold
3 Years
5 W/m K
>5KVac
40
101.6mm X 101.6mm
Gold
3 Years
5 W/m K
>5KVac
40
PL-05-5-254
25.4mm X 25.4mm
Gold
3 Years
5 W/m K
>5KVac
45
PL-05-5-1016
101.6mm X 101.6mm
Gold
3 Years
5 W/m K
>5KVac
45
PL-1-5-254-H
25.4mm X 25.4mm
Gold
3 Years
5 W/m K
>5KVac
40
PL-1-5-1016-H
101.6mm X 101.6mm
Gold
3 Years
5 W/m K
>5KVac
40
PL-1-5-254
25.4mm X 25.4mm
Gold
3 Years
5 W/m K
>5KVac
45
PL-1-5-1016
101.6mm X 101.6mm
Gold
3 Years
5 W/m K
>5KVac
45
PL-2-5-254-H
25.4mm X 25.4mm
Gold
3 Years
5 W/m K
>5KVac
40
PL-2-5-1016-H
101.6mm X 101.6mm
Gold
3 Years
5 W/m K
>5KVac
40
PL-2-5-254
25.4mm X 25.4mm
Gold
3 Years
5 W/m K
>5KVac
45
PL-2-5-1016
101.6mm X 101.6mm
Gold
3 Years
5 W/m K
>5KVac
45
ulTIMiFlux Thermal Gap Dispensable Filling Pad
The Wakefield-Vette Dispensable Gap Filling material is
an ultra-soft thermally conductive silicone supplied as a
two- component liquid dispensable material. The
thixotropic gap filler is designed to remain where it is
dispensed, conform to the surface and cure in place
providing thermal protection at thin bond lines with little
to no stress on the components during assembly.
Features:
Dispensable Two-Part Silicone
High Temperature Resistance
Low Stress on Components Shock Absorbing
Low VoC
Wakefield Vette Part Number Description
PL-BT-601-50M
ulTIMiflux 1 W/M K 2-PART DISPENSIBLE SILICONE GAP FILLER
PL-BT-603-50M
ulTIMiflux 3 W/M K 2-PART DISPENSIBLE SILICONE GAP FILLER
PL-BT-605-50M
ulTIMiflux 5 W/M K 2-PART DISPENSIBLE SILICONE GAP FILLER
For Use with Hardware
BT-01-50M, BT-02-50M
PL-BT-601-50M
PL-BT-603-50M
PL-BT-605-50M
很抱歉,暂时无法提供与“PL-05-3-1016”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+105.630991+13.68110
- 10+93.5271910+12.11344
- 25+89.0823125+11.53775
- 50+86.3148250+11.17931
