PL-05-1-1016
PL-05-1-1016
    WAKEFIELD-VETTE
    ULTIMIFLUX101.6X101.6X0.5MM
PL-05-1-1016 数据手册
ulTIMiFlux Thermal Gap Filling Pad SILICONE BASED THERMALLY CONDUCTIVE GAP FILLER FEATURES AND BENIFITS ● Excellent Thermal Conductivity ● Natural Tackiness – no need for adhesive ● Excellent Compression Characteristics ● Good Wet-Out and Superb Flexibility ● Excellent Converting Properties ● RoHS and HF Compliant Wakefield-Vette's ulTIMiFlux line of thermal interface materials offer high performance, low cost, configurability and custom sizes for your thermal system needs. Thermal Interface Materials (TIM) are a secondary material installed between the heat sink and the device which are designed to improve the thermal transfer to the heat sink. Regardless of how flat or smooth the device and heat sink are, there will always be small air voids between the two surfaces. Since air is a not a great conductor of heat, a TIM replaces the air and fills the voids. There are many types of TIMs and each has its best case usages. Wakefield-Vette’s line of thermal gap filling pads are intended to fill a large void between a device and the heat sink. A gap pad is a compressible material most commonly used when there are multiple devices to be contacted to the heat sink, but all the different device heights make it difficult to use a thin material. These materials come in a variety of thicknesses, conductivities, and durometers to meet a wide range of needs. Part Number Configurator: PL-Thickness- W/ m K- Foot Print – Hypersoft Option WV Part Number Description Size Thermal Conductivity Hardness (Shore 00) PL-05-1-254 0.5mm Thickness 1 W/m K Silicone Gap Filler 25.4mm X 25.4mm 1 W/m K 5 PL-05-1-1016 0.5mm Thickness 1 W/m K Silicone Gap Filler 101.6mm X 101.6mm 1 W/m K 5 PL-1-1-254 1.0mm Thickness 1 W/m K Silicone Gap Filler 25.4mm X 25.4mm 1 W/m K 5 PL-1-1-1016 1.0mm Thickness 1 W/m K Silicone Gap Filler 101.6mm X 101.6mm 1 W/m K 5 PL-2-1-254 2.0mm Thickness 1 W/m K Silicone Gap Filler 25.4mm X 25.4mm 1 W/m K 5 PL-2-1-1016 2.0mm Thickness 1 W/m K Silicone Gap Filler 101.6mm X 101.6mm 1 W/m K 5 PL-05-3-254-H 0.5mm Thickness 3 W/m K Hypersoft Silicone Gap Filler 25.4mm X 25.4mm 3 W/m K 20 PL-05-3-1016-H 0.5mm Thickness 3 W/m K Hypersoft Silicone Gap Filler 101.6mm X 101.6mm 3 W/m K 20 PL-05-3-254 0.5mm Thickness 3 W/m K Silicone Gap Filler 25.4mm X 25.4mm 3 W/m K 35 PL-05-3-1016 0.5mm Thickness 3 W/m K Silicone Gap Filler 101.6mm X 101.6mm 3 W/m K 35 PL-1-3-254-H 1.0mm Thickness 3 W/m K Hypersoft Silicone Gap Filler 25.4mm X 25.4mm 3 W/m K 20 PL-1-3-1016-H 1.0mm Thickness 3 W/m K Hypersoft Silicone Gap Filler 101.6mm X 101.6mm 3 W/m K 20 PL-1-3-254 1.0mm Thickness 3 W/m K Silicone Gap Filler 25.4mm X 25.4mm 3 W/m K 35 PL-1-3-1016 1.0mm Thickness 3 W/m K Silicone Gap Filler 101.6mm X 101.6mm 3 W/m K 35 PL-2-3-254-H 2.0mm Thickness 3 W/m K Hypersoft Silicone Gap Filler 25.4mm X 25.4mm 3 W/m K 20 PL-2-3-1016-H 2.0mm Thickness 3 W/m K Hypersoft Silicone Gap Filler 101.6mm X 101.6mm 3 W/m K 20 PL-2-3-254 2.0mm Thickness 3 W/m K Silicone Gap Filler 25.4mm X 25.4mm 3 W/m K 35 PL-2-3-1016 2.0mm Thickness 3 W/m K Silicone Gap Filler 101.6mm X 101.6mm 3 W/m K 35 PL-05-5-254-H 0.5mm Thickness 5 W/m K Hypersoft Silicone Gap Filler 25.4mm X 25.4mm 5 W/m K 40 PL-05-5-1016-H 0.5mm Thickness 5 W/m K Hypersoft Silicone Gap Filler 101.6mm X 101.6mm 5 W/m K 40 PL-05-5-254 0.5mm Thickness 5 W/m K Silicone Gap Filler 25.4mm X 25.4mm 5 W/m K 45 PL-05-5-1016 0.5mm Thickness 5 W/m K Silicone Gap Filler 101.6mm X 101.6mm 5 W/m K 45 PL-1-5-254-H 1.0mm Thickness 5 W/m K Hypersoft Silicone Gap Filler 25.4mm X 25.4mm 5 W/m K 40 PL-1-5-1016-H 1.0mm Thickness 5 W/m K Hypersoft Silicone Gap Filler 101.6mm X 101.6mm 5 W/m K 40 PL-1-5-254 1.0mm Thickness 5 W/m K Silicone Gap Filler 25.4mm X 25.4mm 5 W/m K 45 PL-1-5-1016 1.0mm Thickness 5 W/m K Silicone Gap Filler 101.6mm X 101.6mm 5 W/m K 45 PL-2-5-254-H 2.0mm Thickness 5 W/m K Hypersoft Silicone Gap Filler 25.4mm X 25.4mm 5 W/m K 40 PL-2-5-1016-H 2.0mm Thickness 5 W/m K Hypersoft Silicone Gap Filler 101.6mm X 101.6mm 5 W/m K 40 PL-2-5-254 2.0mm Thickness 5 W/m K Silicone Gap Filler 25.4mm X 25.4mm 5 W/m K 45 PL-2-5-1016 2.0mm Thickness 5 W/m K Silicone Gap Filler 101.6mm X 101.6mm 5 W/m K 45 Custom Sizes Available Upon Request: www.wakefield-vette.com ulTIMiFlux Thermal Gap Filling Pad SILICONE BASED THERMALLY CONDUCTIVE GAP FILLER Part Number Configurator: PL-Thickness- W/ m K- Foot Print – Hypersoft Option WV Part Number Description Size Color Shelf Life Thermal Conductivity Dielectric Breakdown Strength Hardness (Shore 00) PL-05-1-254 0.5mm Thickness 1 W/m K Silicone Gap Filler 25.4mm X 25.4mm Gray 3 Years 1 W/m K >5KVac 5 PL-05-1-1016 0.5mm Thickness 1 W/m K Silicone Gap Filler 101.6mm X 101.6mm Gray 3 Years 1 W/m K >5KVac 5 PL-1-1-254 1.0mm Thickness 1 W/m K Silicone Gap Filler 25.4mm X 25.4mm Gray 3 Years 1 W/m K >5KVac 5 PL-1-1-1016 1.0mm Thickness 1 W/m K Silicone Gap Filler 101.6mm X 101.6mm Gray 3 Years 1 W/m K >5KVac 5 PL-2-1-254 2.0mm Thickness 1 W/m K Silicone Gap Filler 25.4mm X 25.4mm Gray 3 Years 1 W/m K >5KVac 5 PL-2-1-1016 2.0mm Thickness 1 W/m K Silicone Gap Filler 101.6mm X 101.6mm Gray 3 Years 1 W/m K >5KVac 5 Dielectric Breakdown Strength Hardness (Shore 00) WV Part Number Description Size Color Shelf Life Thermal Conductivity PL-05-3-254-H 0.5mm Thickness 3 W/m K Hypersoft Silicone Gap Filler 25.4mm X 25.4mm Green 3 Years 3 W/m K >5KVac 20 PL-05-3-1016-H 0.5mm Thickness 3 W/m K Hypersoft Silicone Gap Filler 101.6mm X 101.6mm Green 3 Years 3 W/m K >5KVac 20 PL-05-3-254 0.5mm Thickness 3 W/m K Silicone Gap Filler 25.4mm X 25.4mm Green 3 Years 3 W/m K >5KVac 35 PL-05-3-1016 0.5mm Thickness 3 W/m K Silicone Gap Filler 101.6mm X 101.6mm Green 3 Years 3 W/m K >5KVac 35 PL-1-3-254-H 1.0mm Thickness 3 W/m K Hypersoft Silicone Gap Filler 25.4mm X 25.4mm Green 3 Years 3 W/m K >5KVac 20 PL-1-3-1016-H 1.0mm Thickness 3 W/m K Hypersoft Silicone Gap Filler 101.6mm X 101.6mm Green 3 Years 3 W/m K >5KVac 20 PL-1-3-254 1.0mm Thickness 3 W/m K Silicone Gap Filler 25.4mm X 25.4mm Green 3 Years 3 W/m K >5KVac 35 PL-1-3-1016 1.0mm Thickness 3 W/m K Silicone Gap Filler 101.6mm X 101.6mm Green 3 Years 3 W/m K >5KVac 35 PL-2-3-254-H 2.0mm Thickness 3 W/m K Hypersoft Silicone Gap Filler 25.4mm X 25.4mm Green 3 Years 3 W/m K >5KVac 20 PL-2-3-1016-H 2.0mm Thickness 3 W/m K Hypersoft Silicone Gap Filler 101.6mm X 101.6mm Green 3 Years 3 W/m K >5KVac 20 PL-2-3-254 2.0mm Thickness 3 W/m K Silicone Gap Filler 25.4mm X 25.4mm Green 3 Years 3 W/m K >5KVac 35 PL-2-3-1016 2.0mm Thickness 3 W/m K Silicone Gap Filler 101.6mm X 101.6mm Green 3 Years 3 W/m K >5KVac 35 Dielectric Breakdown Strength Hardness (Shore 00) WV Part Number Description PL-05-5-254-H 0.5mm Thickness 5 W/m K Hypersoft Silicone Gap Filler PL-05-5-1016-H 0.5mm Thickness 5 W/m K Hypersoft Silicone Gap Filler Size Color Shelf Life Thermal Conductivity 25.4mm X 25.4mm Gold 3 Years 5 W/m K >5KVac 40 101.6mm X 101.6mm Gold 3 Years 5 W/m K >5KVac 40 PL-05-5-254 0.5mm Thickness 5 W/m K Silicone Gap Filler 25.4mm X 25.4mm Gold 3 Years 5 W/m K >5KVac 45 PL-05-5-1016 0.5mm Thickness 5 W/m K Silicone Gap Filler 101.6mm X 101.6mm Gold 3 Years 5 W/m K >5KVac 45 PL-1-5-254-H 1.0mm Thickness 5 W/m K Hypersoft Silicone Gap Filler 25.4mm X 25.4mm Gold 3 Years 5 W/m K >5KVac 40 PL-1-5-1016-H 1.0mm Thickness 5 W/m K Hypersoft Silicone Gap Filler 101.6mm X 101.6mm Gold 3 Years 5 W/m K >5KVac 40 PL-1-5-254 1.0mm Thickness 5 W/m K Silicone Gap Filler 25.4mm X 25.4mm Gold 3 Years 5 W/m K >5KVac 45 PL-1-5-1016 1.0mm Thickness 5 W/m K Silicone Gap Filler 101.6mm X 101.6mm Gold 3 Years 5 W/m K >5KVac 45 PL-2-5-254-H 2.0mm Thickness 5 W/m K Hypersoft Silicone Gap Filler 25.4mm X 25.4mm Gold 3 Years 5 W/m K >5KVac 40 PL-2-5-1016-H 2.0mm Thickness 5 W/m K Hypersoft Silicone Gap Filler 101.6mm X 101.6mm Gold 3 Years 5 W/m K >5KVac 40 PL-2-5-254 2.0mm Thickness 5 W/m K Silicone Gap Filler 25.4mm X 25.4mm Gold 3 Years 5 W/m K >5KVac 45 PL-2-5-1016 2.0mm Thickness 5 W/m K Silicone Gap Filler 101.6mm X 101.6mm Gold 3 Years 5 W/m K >5KVac 45 Custom Sizes Available Upon Request: www.wakefield-vette.com ulTIMiFlux Thermal Gap Dispensable Filling Pad SILICONE BASED THERMALLY CONDUCTIVE GAP FILLER The Wakefield-Vette Dispensable Gap Filling material is an ultra-soft thermally conductive silicone supplied as a two- component liquid dispensable material. The thixotropic gap filler is designed to remain where it is dispensed, conform to the surface and cure in place providing thermal protection at thin bond lines with little to no stress on the components during assembly. Features: • Dispensable Two-Part Silicone • High Temperature Resistance • Low Stress on Components Shock Absorbing • Low VoC • RoHS and HF Compliant Wakefield Vette Part Number Description PL-BT-601-50M ulTIMiflux 1 W/M K 2-PART DISPENSIBLE SILICONE GAP FILLER PL-BT-603-50M ulTIMiflux 3 W/M K 2-PART DISPENSIBLE SILICONE GAP FILLER PL-BT-605-50M ulTIMiflux 5 W/M K 2-PART DISPENSIBLE SILICONE GAP FILLER For Use with Hardware BT-01-50M, BT-02-50M BT-01-50M, BT-02-50M BT-01-50M, BT-02-50M PL-BT-601-50M Custom Sizes Available Upon Request: www.wakefield-vette.com ulTIMiFlux Thermal Gap Dispensable Filling Pad SILICONE BASED THERMALLY CONDUCTIVE GAP FILLER PL-BT-603-50M PL-BT-605-50M
PL-05-1-1016 价格&库存
很抱歉,暂时无法提供与“PL-05-1-1016”相匹配的价格&库存,您可以联系我们找货
PL-05-1-1016
  • 1+53.226301+6.65739
  • 10+47.1575310+5.89833
  • 25+44.9191025+5.61835
  • 50+43.2975150+5.41553
  • 100+41.73135100+5.21964
库存:116
