H48-6A-320-320-0.5-1A
    T-GLOBAL
    H48-6 SHEET 320X320X0.5MM W/ADH
H48-6A-320-320-0.5-1A 数据手册
H48-6A Thermal Conductive Pad Version 4.270318 Thermal Conductive Pad H48-6A is a silicone based thermal interface pad which offers a good combination of low thermal impedance, good compressibility and a high dielectric breakdown voltage. H48-6 is available in numerous different formats such as custom die cuts or standard sheets. Additionally, both custom die cut pads and standard sheets can be supplied with either one of two side thermally conductive adhesive applied for greater ease of manufacture. Features Good thermal conductivity Ultra-soft and high compressibility Natural tack Easy to assemble Good insulator Shock and vibration absorber Applications Electronic components: IC, CPU, MOS LED, M/B, P/S, Heat Sink LCD, TV, Notebook PC, PC Telecom Device, Wireless Hub, etc. DDR II Module, DVD Applications, Hand-set applications, etc. Properties REACH Compliant ROHS Compliant Property H48-6A Unit Tolerance Test Method Colour Henna - - Visual 0.3 - 10 mm - ASTM D374 0.0118 - 0.787 inch - ASTM D374 Thermal Conductivity 4 W/mK ±0.4 ASTM D5470 Flammability Rating V-0 - - UL 94 Dielectric Breakdown Voltage 2 kV/mm ±0.5 ASTM D149 Weight Loss ‹1 % - ASTM E595 Thickness Density 2.48 g/cm ±0.2 ASTM D792 Working Temperature -40 to 200 °C - - Volume Resistance ›10¹¹ Ohm-cm - ASTM D257 Elongation 120 % Tensile Strength 3 ±13 ASTM D412 8 Kgf/cm 2 ±2 ASTM D412 Hardness 25 Shore A ±5 ASTM D2240 Shelf Life 36 months - - Shelf Life with adhesive (can be requalified for a further 12) 12 months - - Thermal Impedance vs Pressure vs Deflection T-Global Technology Limited 1 & 2 Cosford Business Park, Central Park, Lutterworth, Leicestershire LE17 4QU U.K. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology VAT #: GB 116 662 714 H48-6A Thermal Conductive Pad Standard Weights & Dimensional Tolerance Size Weights (g) Thickness (mm) 0.30 0.50 0.80 1.00 1.50 2.00 2.50 3.00 3.50 4.00 4.50 5.00 100x100 7.44 12.15 19.84 24.80 37.20 49.60 62.00 74.40 86.80 99.20 111.60 124.00 150x150 16.74 27.34 44.64 55.80 83.70 111.60 139.50 167.40 195.30 223.20 251.10 279.00 300x300 66.96 109.35 178.56 223.20 334.80 446.40 558.00 669.60 781.20 892.80 320x320 76.19 124.42 203.16 253.95 380.93 1,004.40 1,116.00 507.90 634.88 761.86 888.83 1,015.81 1,142.78 1,269.76 Thickness (mm) 5.50 6.00 6.50 7.00 7.50 8.00 8.50 9.00 9.50 10.00 100x100 136.40 148.80 161.20 173.60 186.00 198.40 210.80 223.20 235.60 248.00 150x150 306.90 334.80 362.70 390.60 418.50 446.40 474.30 502.20 530.10 558.00 300x300 1,227.60 1,339.20 1,450.80 1,562.40 1,674.00 1,785.60 1,897.20 2,008.80 2,120.40 2,232.00 320x320 1,396.74 1,523.71 1,650.69 1,777.66 1,904.64 2,031.62 2,158.59 2,285.57 2,412.54 2,539.52 Data Die-Cut Thickness Tolerances Thickness (mm) Tolerance (mm) 0.3 ±0.03 0.5 ±0.05 0.8 ±0.08 1.0 ±0.1 1.2 ±0.12 1.5 ±0.15 2.0 ±0.2 2.5 - 3.5 ±0.25 4.0 - 4.5 ±0.3 5.0 ±0.35 6.0 - 8.0 ±0.4 9.0 ±0.45 10.0 ±0.5 >10.0 ±0.5 * Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application. NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent otherwise stated in T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and all liabilities incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with existing or future patents covering any product or material or its use. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
物料型号:H48-6A
器件简介:H48-6A是一种基于硅的热界面垫,具有低热阻、良好的压缩性和高介电击穿电压的优良组合。H48-6A提供多种不同格式,如定制切割或标准片材。此外,定制切割垫和标准片材都可以提供两种热导性粘合剂,以便于制造。
引脚分配:文档中没有提供引脚分配信息,因为H48-6A是一种热导垫,不是电子元件。
参数特性: - 颜色:棕红色 - 厚度:0.3-10毫米或0.0118-0.787英寸 - 热导率:4 W/mK,公差+0.4 - 阻燃等级:V-0 - 介电击穿电压:2 kV/mm,公差±0.5 - 重量损失:<1% - 密度:2.48 g/cm²,公差±0.2 - 工作温度范围:-40至200摄氏度 - 体积电阻:大于10欧姆-厘米 - 伸长率:120%,公差±13 - 拉伸强度:8 Kgf/cm²,公差+2 - 硬度:25 Shore A,公差±5 - 保质期:36个月,带粘合剂的保质期为12个月(可重新认证延长12个月)
功能详解:H48-6A具有良好的热导性、超软和高压缩性、天然粘性、易于组装、良好的绝缘性、以及作为冲击和振动吸收器。
应用信息:适用于电子元件(如IC、CPU、MOS)、LED、主板、电源、散热器、液晶显示器、电视、笔记本电脑、个人电脑、电信设备、无线中心等,以及DDR II模块、DVD应用、手机应用等。
封装信息:文档提供了标准重量和尺寸公差表,以及不同厚度的热导率与硬度的比较数据。
H48-6A-320-320-0.5-1A 价格&库存
很抱歉,暂时无法提供与“H48-6A-320-320-0.5-1A”相匹配的价格&库存,您可以联系我们找货
