H48-2K-15-15-0.1
H48-2K-15-15-0.1
    T-GLOBAL
    H48-2K15X15X0.1MM
H48-2K-15-15-0.1 数据手册
H48-2K Thermal Conductive Pad Version 3.030220 Thermal Conductive Pad H48-2K is an ultra thin, silicon based gap filler which is designed for applications which require a high dielectric breakdown voltage combined with ultra low silicone outgassing. H48-2K is available in various formats such as standard sheets or custom die cuts to support both prototyping and high volume manufacturing. Features Good thermal conductivity Ultra-soft and high compressibility Natural tack Easy to assemble Good insulator Shock and vibration absorber Applications Electronic components: IC, CPU, MOS LED, M/B, P/S, Heat Sink LCD, TV, Notebook PC, PC Telecom Device, Wireless Hub, etc. DDR II Module, DVD Applications, Hand-set applications, etc. Properties REACH Compliant ROHS Compliant Property H48-2K Unit Tolerance Test Method Colour Dark Red - - Visual 0.1/0.2/0.3 mm - - 0.004/0.008/0.01 inch - - Optimal Temperature Range -45 to 200 °C - - Density 2.4 g/cm³ ±0.2 ASTM D792 Thermal Conductivity 2.2 W/mK ±0.2 ASTM D5470 Flammability Rating V-0 - - UL 94 Dielectric Breakdown Voltage 1.2/2.5/3.5 kV ±0.1/±0.2/±0.3 ASTM D149 Hardness 85 Shore A ±5 ASTM D2240 Volume Resistance >1011 Ohm-m - ASTM D257 Elongation 50 % - ASTM D412 Shelf Life 36 months - - Shelf Life with adhesive (can be requalified for a further 12) 12 months - - Thickness Thermal Impedance vs Pressure vs Deflection T-Global Technology Limited 1 & 2 Cosford Business Park, Central Park, Lutterworth, Leicestershire LE17 4QU U.K. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com VAT #: GB 116 662 714 H48-2K Thermal Conductive Pad Standard Weights & Dimensional Tolerance Weights (g) Size Thickness (mm) 0.10 0.20 0.30 100x100 2.10 4.20 6.30 150x150 4.73 9.45 14.18 300x300 18.90 37.80 56.70 320x320 21.50 43.01 64.51 Data Die-Cut Thickness Tolerances Thickness (mm) Tolerance (mm) 0.3 ±0.03 0.5 ±0.05 0.8 ±0.08 1.0 ±0.1 1.2 ±0.12 1.5 ±0.15 2.0 ±0.2 2.5 - 3.5 ±0.25 4.0 - 4.5 ±0.3 5.0 ±0.35 6.0 - 8.0 ±0.4 9.0 ±0.45 10.0 ±0.5 >10.0 ±0.5 * Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application. NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent otherwise stated in T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and all liabilities incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with existing or future patents covering any product or material or its use. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com
H48-2K-15-15-0.1 价格&库存
很抱歉,暂时无法提供与“H48-2K-15-15-0.1”相匹配的价格&库存,您可以联系我们找货
