GP2000-D11-L25-0.3
GP2000-D11-L25-0.3
    T-GLOBAL
    THERMAL PAD TUBE 11X25X0.3MM
GP2000-D11-L25-0.3 数据手册
GP2000 Thermally Conductive Tubes Features Usable over a wide temperature range Simplified processing and reduced operating costs Complies with UL standards Properties Property GP2000D11-L25-0.3 GP2000D11-L30-0.3 GP2000D13.5-L25-0.3 GP2000D13.5-L30-0.3 Test Method Colour Green Green Green Green Visual Base Silicone Rubber Silicone Rubber Silicone Rubber Silicone Rubber - Thickness (mm) 0.3 0.3 0.3 0.3 - Diameter / Length 11mm / 25mm 11mm / 30mm 13.5mm / 25mm 13.5mm / 30mm - Op. Temp. Range (ºC) -55 to 180 -55 to 180 -55 to 180 -55 to 180 - Density (g/cm ) 2.52 2.52 2.52 2.52 ASTM D792 Thermal Conductivity (W/mk) 1.3 1.3 1.3 1.3 ASTM D5470 3 Shore A 80 80 80 80 ASTM D2240 Breakdown Voltage AC (V) 5000 5000 5000 5000 ASTM D149 Breakdown Voltage DC (V) 7000 7000 7000 7000 ASTM D149 Dielectric Constant (1000 Hz) 5.7 5.7 5.7 5.7 ASTM D150 Volume Resistivity (Ohm-cm) ›1012 ›1012 ›1012 ›1012 ASTM D257 TML (%) ‹0.2% ‹0.2% ‹0.2% ‹0.2% ASTM E595 Tensile Strength (PSI) 200 200 200 200 ASTM D412 Elongation (%) 60 60 60 60 ASTM D412 UL Flammability V-0 V-0 V-0 V-0 UL 94 Limited Warranty High Thermal Conductivity Tubes are guaranteed against detachment, under normal use, for 5 years from the purchase date. The User shall be solely responsible for determining the suitability of TC Tubes for the intended use, and the user assumes all risks and liabilities whatsoever in connection there with. Neither seller nor manufacturer shall be liable either in tort or in contract for any loss damage, including loss of profits or revenue arising out of the use or the inability to use the product. Tel: +44 20 8133 2062 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
GP2000-D11-L25-0.3
GP2000热传导管的物料型号包括GP2000 D11-L25-0.3、GP2000 D11-L30-0.3、GP2000 D13.5-L25-0.3、GP2000 D13.5-L30-0.3。
这些热传导管基于硅橡胶,具有0.3mm的厚度,直径和长度分别为11mm/25mm、11mm/30mm、13.5mm/25mm、13.5mm/30mm。
它们在-55至180摄氏度的温度范围内工作,密度为2.52 g/cm³,热导率为1.3 W/mK。
这些管材的邵氏硬度为80,电气强度为5000V交流和7000V直流,介电常数为5.7 (1000 Hz),体积电阻率大于10¹²欧姆-厘米,总质量损失(TML)小于0.2%,拉伸强度为200 PSI,伸长率为60%,且符合UL 94 V-0级可燃性标准。
该产品提供5年有限保证,保证在正常使用下不脱落。
用户需自行确定产品的适用性,并承担与使用相关的风险和责任。
供应商或制造商不承担因使用或无法使用产品而造成的损失或损害赔偿责任。
联系方式为电话:+44 20 8133 2062,电子邮件:sales@tglobaltechnology.com,网站:www.tglobaltechnology.com,Skype:tglobal.technology。
GP2000-D11-L25-0.3 价格&库存
很抱歉,暂时无法提供与“GP2000-D11-L25-0.3”相匹配的价格&库存,您可以联系我们找货
