A15340-03
A15340-03
    LAIRD(莱尔德)
    TFLEX 3200,DC1 9" X 9"
A15340-03 数据手册
TflexTM 300 Series Thermal Gap Filler Innovative Technology for a Connected World UNIQUE SILICONE GEL OFFERS COMPLIANCY, THERMAL RESISTANCE Tflex™ 300, at pressures of 50psi, will deflect to over 50% the original thickness. This high rate of compliancy allows the material to “totally blanket” the component, enhancing thermal transfer. The material has a very low compression set enabling the pad to be reused many times. Tflex™ 300, in achieving its stellar compliancy, does not sacrifice thermal performance. With a thermal conductivity of 1.2 W/mK, low thermal resistances can be achieved at low pressures. Tflex™ 300-H is offered with a hard, metallized liner option for easy handling and improved rework. The metallized liner’s lower coefficient of friction also allows for easy assembly of parts that must slide together, such as a card into a chassis. Tflex™ 300-TG is offered with a cut-through resistant Tgard™ silicone liner. The TG liner offers a guaranteed dielectric barrier, and easier part handling for mass production. FEATURES AND BENEFITS • Extreme compliancy allows material to “totally blanket” component(s) • Thermal conductivity of 1.2 W/mK • Available in thicknesses from 0.020” - 0.200” (.5mm – 5.0mm) • Low compression set enables the pad to be reused many times APPLICATIONS • Notebook and desktop computers • Telecommunication hardware • Flat panel displays • Memory modules • Power conversion equipment • Set top box • Lighting ballast • Automotive electronics • LED lighting • Handheld electronics • Optical disk drives • Vibration dampening global solutions: local support Americas: +1.888.246.9050 Europe: +49.(0).8031.2460.0 Asia: +86.755.2714.1166 CLV-customerservice@lairdtech.com www.lairdtech.com/thermal TM TflexTM 300 Series Thermal Gap Filler Innovative Technology for a Connected World TFLEXTM 300 TYPICAL PROPERTIES TEST METHOD Color Thermal Conductivity Hardness (Shore 00) Density Thickness Range Filled silicone elastomer NA Light green Visual 1.2 W/mK 27 (at 3 second delay) ASTM D5470 1.78 g/cc ASTM D2240 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 340 360 380 3100 3150 3200 10 20 30 40 50 60 70 80 90 100 110 P re ssure psi 0.020" - .200" (0.5 - 5.0mm)* P res s ure v s Deflec tion (A S T M D575) 3100 330 340 360 380 Thickness Tolerance ±10% UL Flammability Rating 94 V0 UL Temperature Range -40ºC to 160ºC NA Volume Resistivity 10 ^13 ohm-cm ASTEM D257 Outgassing TML 0.56% ASTM E595 Outgassing CVCM 0.10% ASTM E595 600 ppm/C IPC-TM-650 2.4.24 Coefficient Thermal Expansion (CTE) 330 Helium Pyncometer P erc ent Deflec tion Construction T herm al R es s itanc e in 2 /W 320 P res s ure v s . thermal res is tanc e (AS T M D 5470) ⁰ C- TFLEXTM 300 320 3150 90% 80% 70% 60% 50% 40% 30% 20% 10% 0% 0 3200 10 20 30 40 50 60 P re ssure psi 70 80 90 100 110 STANDARD THICKNESSES 0.020 to 0.200-inch (0.5 to 5.0mm)* 0.020 to 0.200-inch thick material available in 0.010-inch (0.25mm) increments 0.250-inch (6.4 mm) also available with TG liner option only. *Inquire about availability of material and options above 0.200-inches OPTIONS Tgard™ “TG” dielectric barrier available to aid in handling and PET dielectric “H” liner available for applications where easy slide assembly is desirable MATERIAL NAME AND THICKNESS EXAMPLES Tflex™ indicates elastomeric gap filler product line 3xxx indicates high recovery ‘3 series’ 1.2 W/mK material -DC1 designates proprietary tack eliminated coating -TG indicates Tgard™ liner option -H indicates hard PET liner option Tflex™ 3120 = standard 0.120-inch thick Tflex™ 300 material Tflex™ 3120DC1 = 0.120-inch thick material with DC1 coating Tflex™ 3120TG = 0.120-inch thick material with Tgard™ liner Tflex™ 3120H = 0.120-inch thick material with hard PET liner THR-DS-TFLEX-300 1010 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user, since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness, merchantability or suitability of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2010 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trade marks or registered trade marks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights. Document A15293-00 Rev D, 10/2009.
A15340-03
物料型号:Tflex™ 300系列
器件简介:这是一种填充硅胶弹性体,具有极高的合规性,能够在低压力下实现低热阻,热导率为1.2W/mK。它有多种厚度选项,从0.020英寸到0.200英寸(0.5mm到5.0mm),并具有低压缩永久变形,允许垫片多次重复使用。
引脚分配:文档中未提及引脚分配
参数特性: - 颜色:浅绿色 - 硬度(邵氏00):27(3秒延迟) - 密度:1.78g/cc - 厚度公差:±10% - UL阻燃等级:94V0 - 温度范围:-40°C至160°C - 体积电阻率:10^13欧姆-厘米 - 质量损失(TML):0.56% - 质量损失(CVCM):0.10% - 热膨胀系数(CTE):600ppm/C
功能详解: - 极高的合规性允许材料完全覆盖组件 - 低热阻可以在低压力下实现 - 提供了带硬质金属化衬里选项的Tflex™ 300-H,便于处理和改进返工 - 提供了带Tgard™硅胶衬里的Tflex™ 300-TG,保证介电屏障,便于大规模生产中的零件处理
应用信息: - 笔记本电脑和台式电脑 - 电信硬件 - 平板显示器 - 存储模块 - 功率转换设备 - 机顶盒 - 照明镇流器 - 汽车电子 - LED照明 - 手持电子设备 - 光盘驱动器
封装信息:材料名称和厚度示例包括Tflex™ 3120(标准0.120英寸厚的Tflex™ 300材料)、Tflex™ 3120DC1(带DC1涂层的0.120英寸厚材料)、Tflex™ 3120TG(带Tgard™衬里的0.120英寸厚材料)、Tflex™ 3120H(带硬质PET衬里的0.120英寸厚材料)。
A15340-03 价格&库存
很抱歉,暂时无法提供与“A15340-03”相匹配的价格&库存,您可以联系我们找货
