TG4040SA-288-192-3
TG4040SA-288-192-3
    T-GLOBAL
    TG4040SA288X192X3MM
TG4040SA-288-192-3 数据手册
TG4040SA Ultra Soft Silicone Thermal Pad Description TG4040SA is a white colored, both side tacky, ultra soft silicone thermal pad, suitable for use as thermal interface material or heat sink to dissipate the heat from electronic devices, especially in integrated circuit (IC) and LEDs packaging. This pad has very low hardness and elastic, and yet provides high thermal conductivity, good high temperature resistance and good electrical insulation. Applications Soft silicone based thermal interface material or heat sink to dissipate the heat from electronic devices, especially in integrated circuit (IC) device and LEDs packaging. Guidelines for Use 1. Pick up silicone thermal pad from release film gently. 2. Make sure the surface of the substrate is clean and dried before apply the silicone thermal pad. 3. Position the silicone thermal pad to substrate. 4. Apply some pressure to ensure good contact. 5. The silicone thermal pad can be applied and removed easily (care must be taken during installation to avoid tearing). Properties Property Typical Value Unit Test Method Binder Silicone - - Color White - Visual Reinforcement carrier None - - Specific gravity 2.0 g/cm³ - Thermal conductivity 4.1 W/mK ASTM D5470 Hardness 42 Shore 00 ASTM D2250 Flammability V-0 UL 94 - Working temperature -45 to 200 ⁰C - Breakdown voltage 14 Kv / mm ASTM D149 Packaging Thickness range: 1.0 to 3.0mm Release film: Plastic film Storage Store the silicone thermal pad in a dried place. NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent otherwise stated T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and liability incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with existing future patents covering any product or material or its use. Tel: +44 (0) 1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
TG4040SA-288-192-3 价格&库存
很抱歉,暂时无法提供与“TG4040SA-288-192-3”相匹配的价格&库存,您可以联系我们找货
