Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 6
SERIES: CP30 | DESCRIPTION: PELTIER MODULE
FEATURES
• solid state device
• small and lightweight
• precise temperature control
• quiet operation
MODEL
input
voltage
input
current
max
(V)
max
(A)
Th=27°C
(W)
CP30138
3.8
3
CP30238
8.6
3
15.4
3
CP30338
Notes:
output
Qmax1
output
∆Tmax2
Th=50°C
(W)
Th=27°C
(°C)
Th=50°C
(°C)
6.5
7.2
66
72
15
16.7
66
72
27
30.1
66
72
1. maximum cooling capacity at Imax, Vmax, and ∆T=0°C
2. maximum temperature difference at Imax, Vmax, and Q=0W (maximum parameters are measured in a vacuum)
PART NUMBER KEY
CP30 X 38
Base Number
Thickness
Length/Width:
1 = 15 x 15 mm
2 = 20 x 20 mm
3 = 30 x 30 mm
cuidevices.com
Product Page
3D Model
CUI DEVICES | SERIES: CP30 | DESCRIPTION: PELTIER MODULE
date 08/05/2022 | page 2 of 6
SPECIFICATIONS
parameter
conditions/description
min
typ
max
units
internal resistance3
CP30138
CP30238
CP30338
0.9
2.07
3.6
1.0
2.3
4.0
1.1
2.53
4.4
Ω
Ω
Ω
solder melting temperature
connection between termoelectric pairs
138
°C
98.07
10
N/cm2
kgf/cm2
assembly compression
yes
RoHS
Notes:
3. measured by AC 4-terminal method at 25°C
MECHANICAL DRAWING
units: mm
MATERIAL
0.80 (TYP)
Cold Side
3.8 0.1
ceramic plate
Al203 (Alumina)
sealer
silicon rubber RTV
lead wire
UL1430 (22AWG)
joint cover
silicon rubber RTV
Hot Side
100.0 5.0
7.0 3.0
L
Red (+)
W
COLD SIDE
Black (-)
MODEL NO.
LENGTH
(mm)
WIDTH
(mm)
THICKNESS
(mm)
CP30138
15 ±0.3
15 ±0.3
3.8 ±0.1
CP30238
20 ±0.3
20 ±0.3
3.8 ±0.1
CP30338
30 ±0.3
30 ±0.3
3.8 ±0.1
cuidevices.com
PLATING
tin
Product Page
3D Model
date 08/05/2022 | page 3 of 6
CP30138 PERFORMANCE (Th=27°C)
3.0 A
Input Voltage (V)
4.0
2.4 A
1.8 A
2.0
1.2 A
0.6 A
Heat Pumped (W)
3.0 A
2.4 A
4.0
1.8 A
1.2 A
2.0
0.6 A
60
50
40
30
ΔT=Th−Tc(℃)
CP30138 PERFORMANCE (Th=50°C)
3.0 A
Input Voltage (V)
4.0
2.4 A
1.8 A
1.2 A
2.0
0.6 A
3.0 A
Heat Pumped (W)
6.0
2.4 A
1.8 A
4.0
1.2 A
2.0
0.6 A
ΔT=Th−Tc(℃)
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 4 of 6
CP30238 PERFORMANCE (Th=27°C)
3.0 A
Input Voltage (V)
8.0
2.4 A
1.8 A
1.2 A
4.0
0.6 A
Heat Pumped (W)
3.0 A
12.0
2.4 A
1.8 A
8.0
1.2 A
4.0
0.6 A
60
50
40
30
ΔT=Th−Tc(℃)
CP30238 PERFORMANCE (Th=50°C)
Input Voltage (V)
3.0 A
2.4 A
8.0
1.8 A
1.2 A
4.0
0.6 A
Heat Pumped (W)
3.0 A
2.4 A
12.0
1.8 A
1.2 A
8.0
0.6 A
4.0
ΔT=Th−Tc(℃)
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 5 of 6
Input Voltage (V)
CP30338 PERFORMANCE (Th=27°C)
3.0 A
16.0
2.4 A
1.8 A
8.0
1.2 A
0.6 A
Heat Pumped (W)
3.0 A
2.4 A
16.0
1.8 A
1.2 A
8.0
0.6 A
60
50
40
30
ΔT=Th−Tc(℃)
CP30338 PERFORMANCE (Th=50°C)
Input Voltage (V)
3.0 A
16.0
2.4 A
1.8 A
1.2 A
8.0
0.6 A
3.0 A
Heat Pumped (W)
24.0
2.4 A
1.8 A
16.0
1.2 A
8.0
0.6 A
60
50
40
30
ΔT=Th−Tc(℃)
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 6 of 6
REVISION HISTORY
rev.
description
date
1.0
initial release
09/03/2009
1.01
applied new template
05/07/2012
1.02
brand update
10/30/2019
logo, datasheet style update
08/05/2022
1.03
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CP30338”相匹配的价格&库存,您可以联系我们找货
