CP60133
CP60133
    CUIDEVICES
    PELTIER MOD 15 X 3.3MM 6.0A INP
CP60133 数据手册
Additional Resources: Product Page | 3D Model date 08/05/2022 page 1 of 11 SERIES: CP60 | DESCRIPTION: PELTIER MODULE FEATURES • solid state device • precise temperature control • quiet operation MODEL input voltage1 input current2 internal resistance3 max (Vdc) max (A) typ (Ω±10%) CP60133 3.8 6.0 CP60233 8.6 6.0 CP60333 15.4 CP60140 2.1 CP60240 CP60301540 CP60340 8.6 CP60440 15.4 Notes: output Qmax4 output ∆Tmax5 Th=27°C (W) Th=50°C (W) Th=27°C (°C) Th=50°C (°C) 0.50 12.2 13.6 66 72 1.20 27.9 31.2 66 72 6.0 2.20 50.5 56.5 66 72 6.0 0.29 7.1 7.9 68 75 3.8 6.0 0.53 13.0 14.5 68 75 4.2 6.0 0.57 14.5 16.1 68 75 6.0 1.21 29.0 32.4 68 75 6.0 2.17 53.0 59.3 68 75 1. Maximum voltage at ΔT max and Th=27°C 2. Maximum current to achieve ΔT max 3. Measured by AC 4-terminal method at 25°C 4. Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C 5. Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa) cuidevices.com Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 2 of 11 SPECIFICATIONS parameter conditions/description min solder melting temperature connection between thermoelectric pairs CP60133, CP60233, CP60333, CP60301540 all other models 235 138 typ units °C °C assembly compression hot side plate RoHS max 1 MPa 80 °C yes MECHANICAL DRAWING units: mm MATERIAL HOT SIDE 0.05 THICKNESS COLD SIDE 0.05 96% AL2O3 wire leads 20 AWG sealer silicon rubber 703 RTV (between cold and hot side plates) joint cover silicon rubber 703 RTV marking P/N & S/N printed on cold side surface 7 3.0 Red (+) WIDTH COLD SIDE Black (-) LENGTH 100.0 5.0 MODEL NO. LENGTH (mm) WIDTH (mm) THICKNESS (mm) CP60133 15 ±0.3 15 ±0.3 3.22 ±0.1 CP60233 20 ±0.3 20 ±0.3 3.22 ±0.1 CP60333 30 ±0.3 30 ±0.3 3.22 ±0.1 CP60140 15 ±0.3 15 ±0.3 4.0 ±0.1 CP60240 20 ±0.3 20 ±0.3 4.0 ±0.1 CP60301540 30 ±0.3 15 ±0.3 4.0 ±0.1 CP60340 30 ±0.3 30 ±0.3 4.0 ±0.1 CP60440 40 ±0.3 40 ±0.3 4.0 ±0.1 cuidevices.com PLATING ceramic plate tin Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 3 of 11 Input Voltage (V) CP60133 PERFORMANCE (Th=27°C) 6.0 A 4.0 4.8 A 3.6 A 2.0 2.4 A 1.2 A Heat Pumped, Q (W) 0 12.0 6.0 A 4.8 A 8.0 3.6 A 2.4 A 4.0 1.2 A 0     ΔT=Th-Tc (°C)       Input Voltage (V) CP60133 PERFORMANCE (Th=50°C) 6.0 A 4.0 4.8 A 3.6 A 2.4 A 2.0 1.2 A Heat Pumped, Q (W) 0 12.0 6.0 A 4.8 A 3.6 A 8.0 2.4 A 4.0 1.2 A 0     ΔT=Th-Tc (°C) cuidevices.com   Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 4 of 11 Input Voltage (V) CP60233 PERFORMANCE (Th=27°C) 6.0 A 8.0 4.8 A 3.6 A 2.4 A 4.0 1.2 A 0 Heat Pumped, Q (W) 30.0 6.0 A 20.0 4.8 A 3.6 A 2.4 A 10.0 1.2 A 0         ΔT=Th-Tc (°C) Input Voltage (V) CP60233 PERFORMANCE (Th=50°C) 6.0 A 4.8 A 8.0 3.6 A 2.4 A 4.0 1.2 A 0 Heat Pumped, Q (W) 30.0 6.0 A 4.8 A 20.0 3.6 A 2.4 A 10.0 1.2 A 0     ΔT=Th-Tc (°C) cuidevices.com     Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 5 of 11 Input Voltage (V) CP60333 PERFORMANCE (Th=27°C) 6.0 A 16.0 4.8 A 3.6 A 8.0 2.4 A 1.2 A Heat Pumped, Q (W) 0 6.0 A 40.0 4.8 A 3.6 A 2.4 A 20.0 1.2 A 0     ΔT=Th-Tc (°C)     CP60333 PERFORMANCE (Th=50°C) Input Voltage (V) 6.0 A 16.0 4.8 A 3.6 A 2.4 A 8.0 1.2 A Heat Pumped, Q (W) 0 6.0 A 40.0 4.8 A 3.6 A 2.4 A 20.0 1.2 A 0     ΔT=Th-Tc (°C) cuidevices.com     Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 6 of 11 Input Voltage (V) CP60140 PERFORMANCE (Th=27°C) 6.0 A 2.0 4.8 A 3.6 A 2.4 A 1.0 1.2 A Heat Pumped, Q (W) 0 6.0 6.0 A 4.8 A 3.6 A 4.0 2.4 A 2.0 1.2 A 0     ΔT=Th-Tc (°C)       CP60140 PERFORMANCE (Th=50°C) Input Voltage (V) 6.0 A 4.8 A 2.0 3.6 A 2.4 A 1.0 1.2 A 0 Heat Pumped, Q (W) 6.0 A 6.0 4.8 A 3.6 A 4.0 2.4 A 2.0 1.2 A 0     ΔT=Th-Tc (°C) cuidevices.com   Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 7 of 11 Input Voltage (V) CP60240 PERFORMANCE (Th=27°C) 6.0 A 4.0 4.8 A 3.6 A 2.0 2.4 A 1.2 A Heat Pumped, Q (W) 0 12.0 6.0 A 4.8 A 8.0 3.6 A 2.4 A 4.0 1.2 A 0     ΔT=Th-Tc (°C)       Input Voltage (V) CP60240 PERFORMANCE (Th=50°C) 6.0 A 4.0 4.8 A 3.6 A 2.4 A 2.0 1.2 A Heat Pumped, Q (W) 0 6.0 A 12.0 4.8 A 3.6 A 8.0 2.4 A 4.0 1.2 A 0     ΔT=Th-Tc (°C) cuidevices.com   Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 8 of 11 Input Voltage (V) CP60301540 PERFORMANCE (Th=27°C) 8.0 6.0 6A 4.0 4.8 A 3.6 A 2.4 A 2.0 1.2 A Heat Pumped, Q (W) 0 16 6A 12 3.6 8.0 4.8 A A 2.4 A 1.2 A 4.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP60301540 PERFORMANCE (Th=50°C) 8.0 6.0 4.0 6A 4.8 A 3.6 A 2.4 A 2.0 1.2 A Heat Pumped, Q (W) 0 4.8 A 16 6A 3.6 12 2.4 A 8.0 1.2 A 4.0 0 A 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 9 of 11 Input Voltage (V) CP60340 PERFORMANCE (Th=27°C) 6.0 A 8.0 4.8 A 3.6 A 2.4 A 4.0 1.2 A 0 Heat Pumped, Q (W) 30 6.0 A 4.8 A 20 3.6 A 2.4 A 10 1.2 A 0 70 60 50 40 ΔT=Th-Tc (°C) 30 20 10 0 10 0 Input Voltage (V) CP60340 PERFORMANCE (Th=50°C) 6.0 A 4.8 A 8.0 3.6 A 2.4 A 4.0 1.2 A 0 Heat Pumped, Q (W) 30.0 6.0 A 4.8 A 20.0 3.6 A 2.4 A 10.0 1.2 A 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 10 of 11 Input Voltage (V) CP60440 PERFORMANCE (Th=27°C) 6.0 A 16.0 4.8 A 3.6 A 8.0 2.4 A 1.2 A Heat Pumped, Q (W) 0 6.0 A 40.0 4.8 A 3.6 A 2.4 A 20.0 1.2 A 0     ΔT=Th-Tc (°C)       CP60440 PERFORMANCE (Th=50°C) Input Voltage (V) 6.0 A 16.0 4.8 A 3.6 A 2.4 A 8.0 1.2 A 0 Heat Pumped, Q (W) 6.0 A 4.8 A 40.0 3.6 A 2.4 A 20.0 1.2 A 0     ΔT=Th-Tc (°C) cuidevices.com   Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60 | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 11 of 11 REVISION HISTORY rev. description date 1.0 initial release 09/03/2009 1.01 applied new template 05/08/2012 1.02 added new models 09/09/2016 1.03 changed thickness of CP60133, CP60233, CP60333, CP60301540 models 09/20/2018 1.04 brand update 10/28/2019 logo, datasheet style update 08/05/2022 1.05 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com Additional Resources: Product Page | 3D Model
CP60133 价格&库存
很抱歉,暂时无法提供与“CP60133”相匹配的价格&库存,您可以联系我们找货
