CM23-1.9-05AC
CM23-1.9-05AC
    MARLOWINDUSTRIES,INC.
    TEM8.18X6.02X1.65MM
CM23-1.9-05AC 数据手册
Technical Data Sheet for CM23-1.9 Commercial Module for CATV & SLED Applications NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): PRODUCT FEATURES       27 71 3.4 1.9 2.8 1.23 85 92 4.1 1.8 3.5 -- ORDERING OPTIONS RoHS EU Compliant: CM23-1.9-01AC, -03AC, -04AC, -05AC, -07AC, -17AC Not RoHS EU Compliant: CM23-1.9-06AC, -08AC, -09AC Ceramic Material: Aluminum Oxide Au flash exterior, suitable for soldering. Maximum process temperature is 220°C. Height includes metallization, where applicable, and excludes tinning. Model Number CM23-1.9-01AC CM23-1.9-03AC CM23-1.9-04AC CM23-1.9-05AC CM23-1.9-06AC CM23-1.9-07AC CM23-1.9-08AC CM23-1.9-09AC CM23-1.9-17AC Description Metallized Exterior Non Metallized Exterior 146°C Pretinned Exterior 138°C Pretinned Exterior 138°C /183°C Pretinned Exterior 138°C Pretinned Exterior and 2 sides encapsulated 118°C /183°C Pretinned Exterior 118°C /183°C Pretinned Exterior with Teflon Sleeving. 138°C Pretinned Exterior and 4 sides encapsulated OPERATION CAUTIONS INSTALLATION For maximum reliability, storage and operation below 85°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Recommended mounting methods: Bonding with thermal epoxy or soldering with metallized ceramics. For additional information, please refer to our TEC Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0808 Rev. A II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0353 REV L - PAGE 1 OF 2 www.marlow.com TYPICAL PERFORMANCE CURVES ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN TA = Temperature 85°C - Vacuum Hot Side 85°C Hot Side 27°C TA Temperature = 27°C - Vacuum Heat Heat Load (W) 100.0 Load (W) 100.0 0.00 80.0 0.50 80.0 0.00 0.50 1.00 40.0 1.50 1.00 60.0 DT (°C) DT (°C) 60.0 1.50 2.00 40.0 2.50 2.00 20.0 3.00 20.0 2.50 3.50 3.00 0.0 0.4 0.8 1.2 1.6 2.0 0.0 4.0 4.0 3.5 3.5 3.0 Voltage (VDC) Voltage (VDC) 4.00 0.0 0.0 Q=0 2.5 2.0 1.5 1.0 DT = 0 0.5 3.0 0.4 0.8 1.2 1.6 2.0 Q=0 2.5 2.0 1.5 DT = 0 1.0 0.5 0.0 0.0 0.0 0.4 0.8 1.2 1.6 2.0 Current (amps) 0.0 0.4 0.8 1.2 1.6 2.0 Current (amps) MECHANICAL CHARACTERISTICS For performance information in a vacuum or with hot side temperatures other than 27°C or 85°C, contact one of our Applications Engineers at 877-627-5691. TYPICAL PERFORMANCE Environment : Vacuum TA (C) : 27 VMAX (VDC) : 2.8 D TMAX (C) : 71 IMAX (amps) : 1.9 QMAX (W) : 3.4 ACR (W) : 1.23 TYPICAL PERFORMANCE Environment : Vacuum TA (C) : 85 VMAX (VDC) : 3.5 D TMAX (C) : 92 IMAX (amps) : 1.8 QMAX (W) : 4.1 ACR (W) : - All dimensions are in millimeters unless otherwise stated. For customer support or general questions please contact a local office or visit our website at www.marlow.com. Marlow reserves the right to make product changes without notice. . MI Form 005-0808 Rev. A DOC # 102-0353 REV L - PAGE 2 OF 2 www.marlow.com
CM23-1.9-05AC 价格&库存
很抱歉,暂时无法提供与“CM23-1.9-05AC”相匹配的价格&库存,您可以联系我们找货
