NL1023T-01AC
NL1023T-01AC
    MARLOWINDUSTRIES,INC.
    TEM13.16X13.16X2.16MM
NL1023T-01AC 数据手册
Technical Data Sheet for NL1023T Single-Stage Thermoelectric Module NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): Device ZT PRODUCT FEATURES • • • • • 27 64 9.2 1.8 8.0 3.86 0.77 50 73 10.5 1.8 9.0 --- ORDERING OPTIONS RoHS EU Compliant Rated operating temperature of 85°C. Maximum process temperature is 220°C Ceramic material: Aluminum Oxide. Pre-tinned metallized ceramic surface(s) with 138°C solder, option available. Model Number NL1023T-01AC NL1023T-02AC NL1023T-03AC NL1023T-04AC Description TEM, Top and Base Metallized Exterior TEM, Base Metallized Exterior TEM, No Metallized Exterior TEM, Top and Base Pre-Tinned with 138 °C Solder OPERATION INSTALLATION For maximum reliability, storage and operation below 85°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Recommended mounting methods: Bonding with thermal epoxy or soldering with metallized ceramics. For additional information, please refer to our TEM Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0808 Rev. B II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0297 REV L - PAGE 1 OF 3 www.marlow.com ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN Hot Side Temperature 27°C 80.0 20.0 VOLTAGE (VDC) 0.0 T (C) 0.0 6.0 4.0 Q=0 T=0 0.0 0.0 0.4 0.8 1.2 1.6 CURRENT (AMPS) 40.0 20.0 8.0 2.0 0.00 1.00 2.00 3.00 4.00 5.00 6.00 7.00 8.00 9.00 10.00 60.0 VOLTAGE (VDC) T (C) 40.0 HEAT LOAD (WATTS) 80.0 0.00 1.00 2.00 3.00 4.00 5.00 6.00 7.00 8.00 9.00 60.0 8.0 6.0 4.0 Q=0 T=0 2.0 0.0 0.0 2.0 0.4 0.8 1.2 1.6 CURRENT (AMPS) 2.0 POWER GENERATION PERFORMANCE CURVES Hot Side Temperature (°C) 45 50 55 65 Hot Side Temperature (°C) 75 85 Tc=27°C 1.2 0.06 1 0.05 0.8 0.6 0.4 0.2 Power 1.3 2.3 3.3 Heat (W) 4.3 5.3 60 65 70 75 80 85 0.7 0.6 Tc=50°C 0.04 0.5 0.4 0.03 0.3 0.02 0.2 0.01 0.1 Voltage Power 0 0.3 55 Voltage 0 6.3 Opt Voltage (V) 0.2 0.18 0.16 0.14 0.12 0.1 0.08 0.06 0.04 0.02 0 40 Opt Power (W) 35 Opt Voltage (V) 30 Opt Power (W) TYPICAL PERFORMANCE CURVES Hot Side Temperature 50°C HEAT LOAD (WATTS) 0 0.5 1.0 1.5 2.0 2.5 Heat (W) 3.0 3.5 Efficiency 0 1 2 3 4 5 6 7 Load Resistance Ratio 8 1 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 Voltage 0.1 0 9 10 Voltage / VOC η / Opt η Normalized Off-Peak Performance 1 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 Hot Side Temperature (°C) Cold Side Temperature (°C) Optimum Efficiency, η (%) Optimum Power (W) Optimum Voltage (V) Load Resistance for Opt η (Ω) Open Circuit Voltage, VOC (V) Short Circuit Current (A) Thermal Resistance (°C/W) 85 27 2.53 0.162 1.011 6.32 1.77 0.37 9.09 55 27 1.28 0.039 0.482 5.91 0.85 0.19 9.09 35 27 0.37 0.003 0.136 5.62 0.24 0.06 9.06 For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691. MI Form 005-0808 Rev. B DOC # 102-0297 REV L - PAGE 2 OF 3 www.marlow.com MECHANICAL CHARACTERISTICS *NOTE: Cold side, hot side, positive leads, and negative leads are valid only for thermoelectric cooling. For power generation, refer to figure below. For customer support or general questions please contact a local office or visit our website at www.marlow.com. Marlow reserves the right to make product changes without notice. MI Form 005-0808 Rev. B DOC # 102-0297 REV L - PAGE 3 OF 3 www.marlow.com
NL1023T-01AC 价格&库存
很抱歉,暂时无法提供与“NL1023T-01AC”相匹配的价格&库存,您可以联系我们找货
