CP30138H
CP30138H
    CUIDEVICES
    PELTIER,15X15X3.8MM,3A,
CP30138H 数据手册
Additional Resources: Product Page | 3D Model date 08/05/2022 page 1 of 9 SERIES: CP30H | DESCRIPTION: PELTIER MODULE FEATURES • arcTEC™ structure on select models • enhanced reliability for high thermal cycling • superior thermal performance • silicon sealed • wide ΔT max • low profile • precise temperature control • solid state construction MODEL input voltage1 input current2 internal resistance3 max (Vdc) max (A) typ (Ω±10%) CP30138H 3.8 3.0 1.0 CP30238H 8.8 3.0 2.20 CP30239H 6.0 3.0 1.5 CP30301538H 7.6 3.0 1.95 CP303385H 15.7 3.0 CP304446 19.5 3.0 6 Notes: output Qmax4 Th=50°C (W) Th=27°C (°C) Th=50°C (°C) 7.3 8.0 70 77 16.6 18.0 70 77 10.3 11.3 70 77 14.7 16.1 70 77 4.0 29.8 32.5 70 77 4.8 34 37 70 77 1. Maximum voltage at ΔT max and Th=27°C 2. Maximum current to achieve ΔT max 3. Measured by AC 4-terminal method at 25°C 4. Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C 5. Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa) 6. Designed with arcTEC™ structure. cuidevices.com Th=27°C (W) output ∆Tmax5 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP30H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 2 of 9 SPECIFICATIONS parameter conditions/description min solder melting temperature connection between thermoelectric pairs 235 typ max units °C assembly compression 1 RoHS MPa yes MECHANICAL DRAWING units: mm MATERIAL HOT SIDE 0.05 THICKNESS COLD SIDE 0.05 ceramic plate 96% AL2O3 wire leads (CP30444) 20 AWG tin wire leads (all other models) 22 AWG tin sealer silicon rubber 703 RTV (between cold and hot side plates) joint cover silicon rubber 703 RTV marking P/N & S/N printed on cold side surface 10.0 3.0 Red (+) WIDTH COLD SIDE Black (-) LENGTH 100.0 5.0 MODEL NO. LENGTH (mm) WIDTH (mm) THICKNESS (mm) CP30138H 15 ±0.3 15 ±0.3 3.8 ±0.025 CP30238H 20 ±0.3 20 ±0.3 3.8 ±0.025 CP30239H 20 ±0.3 20 ±0.3 3.9 ±0.1 CP30301538H 30 ±0.3 15 ±0.3 3.8 ±0.025 CP303385H 30 ±0.3 30 ±0.3 3.85 ±0.02 CP30444 40 ±0.3 40 ±0.3 4.4 ±0.1 cuidevices.com PLATING Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP30H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 3 of 9 Input Voltage (V) CP30138H PERFORMANCE (Th=27°C) 3A 4.0 2.4 A 1.8 A 1.2 A 2.0 0.6 A 0 Heat Pumped, Q (W) 3A 6.0 2.4 A 1.8 1.2 4.0 A A 0.6 A 2.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP30138H PERFORMANCE (Th=50°C) 3A 4.0 2.4 A 1.8 A 1.2 A 2.0 0.6 A Heat Pumped, Q (W) 0 2.4 A 1.8 A 3A 6.0 1.2 4.0 A 0.6 A 2.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP30H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 4 of 9 Input Voltage (V) CP30238H PERFORMANCE (Th=27°C) 3A 8.0 2.4 A 1.8 A 1.2 A 4.0 0.6 A 0 Heat Pumped, Q (W) 16 2.4 A 1.8 A 3A 12 1.2 8.0 A 0.6 A 4.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP30238H PERFORMANCE (Th=50°C) 3A 2.4 A 8.0 1.8 A 1.2 A 4.0 0.6 A 0 3A Heat Pumped, Q (W) 16 1.8 12 2.4 A A 1.2 A 8.0 0.6 A 4.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP30H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 5 of 9 Input Voltage (V) CP30239H PERFORMANCE (Th=27°C) 8.0 3A 2.4 A 6.0 1.8 A 4.0 1.2 A 2.0 0.6 A Heat Pumped, Q (W) 0 12 3A 9.0 2.4 A 6.0 1.2 3.0 1.8 A A 0.6 A 0 70 60 50 40 ΔT=Th-Tc (°C) 30 20 10 0 Input Voltage (V) CP30239H PERFORMANCE (Th=50°C) 8.0 3A 6.0 2.4 A 1.8 A 4.0 1.2 A 2.0 0.6 A Heat Pumped, Q (W) 0 12 3A 9.0 1.8 A 1.2 6.0 A 0.6 A 3.0 0 2.4 A 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP30H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 6 of 9 Input Voltage (V) CP30301538H PERFORMANCE (Th=27°C) 8.0 3A 2.4 A 6.0 1.8 A 4.0 1.2 A 0.6 A 2.0 Heat Pumped, Q (W) 0 16 3A A 2.4 A 8 1. A 1.2 12.0 8.0 0.6 4.0 0 70 60 50 40 ΔT=Th-Tc (°C) 30 20 A 10 0 Input Voltage (V) CP30301538H PERFORMANCE (Th=50°C) 8.0 3A 2.4 A 1.8 A 6.0 1.2 A 4.0 0.6 A 2.0 Heat Pumped, Q (W) 0 16 3A 12.0 8.0 4.0 0 2.4 1.8 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 1.2 A 0.6 A A A 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP30H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 7 of 9 Input Voltage (V) CP303385H PERFORMANCE (Th=27°C) 3A 16 2.4 A 1.8 A 1.2 A 8.0 0.6 A 0 Heat Pumped, Q (W) 3A 24 2.4 A 1.8 A 1.2 16 A 0.6 A 8.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP303385H PERFORMANCE (Th=50°C) 20 3A 2.4 A 1.8 A 10 1.2 A 0.6 A Heat Pumped, Q (W) 0 3A 30 2.4 20 1.2 A 1.8 A A 0.6 A 10 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP30H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 8 of 9 Input Voltage (V) CP30444 PERFORMANCE (Th=27°C) 20 15 10 5.0 Heat Pumped, Q (W) 0 32 24 16 8.0 0 70 60 50 40 30 20 10 0 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP30444 PERFORMANCE (Th=50°C) 20 15 10 5.0 Heat Pumped, Q (W) 0 32 24 16 8.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP30H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 9 of 9 REVISION HISTORY rev. description date 1.0 initial release 09/08/2016 1.01 updated datasheet 09/25/2017 1.02 added new models 05/21/2018 1.03 added model CP30444, brand update 10/18/2019 1.04 logo, datasheet style update 08/05/2022 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CP30138H 价格&库存
很抱歉,暂时无法提供与“CP30138H”相匹配的价格&库存,您可以联系我们找货
