CP60239H
CP60239H
    CUIDEVICES
    PELTIER,20X20X3.9MM,6A,
CP60239H 数据手册
Additional Resources: Product Page | 3D Model date 08/05/2022 page 1 of 22 SERIES: CP60H | DESCRIPTION: PELTIER MODULE FEATURES • arcTEC™ structure on select models • enhanced reliability for high thermal cycling • superior thermal performance • silicon sealed • wide ΔT max • low profile • precise temperature control • solid state construction MODEL input voltage1 input current2 internal resistance3 max (Vdc) max (A) typ (Ω±10%) CP60131H 3.8 6.0 CP60139H 2.1 6.0 CP60231H 8.8 6.0 CP60239H 3.8 6.0 CP602040395H 7.6 6.0 CP60301233H 5.6 6.0 CP60301531H 7.6 6.0 0.93 26.3 28.9 70 77 CP60302031H 13.0 6.0 1.51 49.5 54.5 68 75 CP603315H6 15.7 6.0 1.90 53.1 59.1 70 77 CP60303956 11.8 6.0 1.65 41.5 45.6 70 77 CP603395H 8.8 6.0 1.25 31.1 34.2 70 77 CP604020395H6 7.6 6.0 1.09 27.5 30.2 70 77 CP60433H 19.5 6.0 2.54 67.6 74.3 68 75 CP604395H6 15.7 6.0 2.2 55.6 61.0 70 77 CP604040 24.1 6.0 3.21 83.5 91.9 68 75 CP605462416 41.3 6.0 5.78 147 161 70 77 CP60553546 35.4 6.0 4.95 126 138 70 77 CP60555542 29.8 6.0 4.15 106 116 70 77 CP6040603956 23.6 6.0 3.3 80.2 88.2 70 77 6 6 6 6 6 Notes: output Qmax4 output ∆Tmax5 Th=27°C (W) Th=50°C (W) Th=27°C (°C) Th=50°C (°C) 0.45 13 14.3 70 77 0.30 7.4 8.2 70 77 1.05 29.7 32.7 70 77 0.55 13.6 14.9 70 77 1.09 27.5 30.2 70 77 0.76 19.7 21.7 70 77 1. Maximum voltage at ΔT max and Th=27°C 2. Maximum current to achieve ΔT max 3. Measured by AC 4-terminal method at 25°C 4. Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C 5. Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa) 6. Designed with arcTEC™ structure. cuidevices.com Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 2 of 22 SPECIFICATIONS parameter conditions/description min solder melting temperature connection between thermoelectric pairs 235 typ max units °C assembly compression 1 RoHS MPa yes MECHANICAL DRAWING units: mm MATERIAL HOT SIDE 0.05 THICKNESS COLD SIDE 0.05 PLATING ceramic plate 96% AL2O3 wire leads (CP60131H, CP60231H, CP60302031H CP60301233H, CP60301531H, CP603315H) 22 AWG tin wire leads (all other models) 20 AWG tin sealer silicon rubber 703 RTV (between cold and hot side plates) joint cover silicon rubber 703 RTV marking P/N & S/N printed on cold side surface 10.0 3.0 Red (+) WIDTH COLD SIDE Black (-) LENGTH 100.0 5.0 MODEL NO. LENGTH (mm) WIDTH (mm) THICKNESS (mm) MODEL NO. LENGTH (mm) WIDTH (mm) THICKNESS (mm) CP60131H 15 ±0.3 15 ±0.3 3.1 ±0.025 CP603395H 30 ±0.3 30 ±0.3 3.95 ±0.025 CP60139H 15 ±0.3 15 ±0.3 3.9 ±0.025 CP604020395H 40 ±0.3 20 ±0.3 3.95 ±0.025 CP60231H 20 ±0.3 20 ±0.3 3.1 ±0.025 CP60433H 40 ±0.3 40 ±0.3 3.3 ±0.03 CP60239H 20 ±0.3 20 ±0.3 3.9 ±0.025 CP604395H 40 ±0.3 40 ±0.3 3.95 ±0.025 CP602040395H 20 ±0.3 40 ±0.3 3.95 ±0.025 CP604040 40 ±0.3 40 ±0.3 4.0 ±0.1 CP60301233H 30 ±0.1 12 ±0.1 3.3 ±0.1 CP60546241 62.5 ±0.3 54 ±0.3 4.1 ±0.1 CP60301531H 30 ±0.3 15 ±0.3 3.1 ±0.025 CP6055354 55 ±0.3 55 ±0.3 4.1 ±0.1 CP60302031H 30 ±0.3 20 ±0.3 3.1 ±0.1 CP60555542 55 ±0.3 55 ±0.3 4.2 ±0.1 CP603315H 30 ±0.3 30 ±0.3 3.15 ±0.025 CP604060395 40 ±0.3 60 ±0.3 3.95 ±0.025 CP6030395 30 ±0.3 30 ±0.3 3.95 ±0.025 cuidevices.com Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 3 of 22 Input Voltage (V) CP60131H PERFORMANCE (Th=27°C) 6A 4.0 4.8 A 3.6 A 2.4 A 2.0 1.2 A Heat Pumped, Q (W) 0 6A 12 4.8 3.6 8.0 A 2.4 A 4.0 0 A 1.2 A 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP60131H PERFORMANCE (Th=50°C) 6A 4.0 4.8 A 3.6 A 2.4 A 2.0 1.2 A Heat Pumped, Q (W) 0 6A 12 8.0 A 3.6 A 2.4 A 1.2 A 4.0 0 4.8 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 4 of 22 Input Voltage (V) CP60139H PERFORMANCE (Th=27°C) 6A 2.0 4.8 A 3.6 A 2.4 A 1.0 1.2 A 0 Heat Pumped, Q (W) 6A A 4.8 6.0 3.6 A 2.4 A 4.0 1.2 A 2.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP60139H PERFORMANCE (Th=50°C) 6A 4.8 A 2.0 3.6 A 2.4 A 1.0 1.2 A Heat Pumped, Q (W) 0 6A 6.0 4.8 A 3.6 A 2.4 A 4.0 1.2 A 2.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 5 of 22 CP60231H PERFORMANCE (Th=27°C) Input Voltage (V) 6A 8.0 4.8 A 3.6 A 2.4 A 4.0 1.2 A 0 Heat Pumped, Q (W) 30 6A 4.8 3.6 20 A A 2.4 A 10 1.2 A 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) CP60231H PERFORMANCE (Th=50°C) Input Voltage (V) 6A 4.8 A 8.0 3.6 A 2.4 A 4.0 1.2 A 0 6A Heat Pumped, Q (W) 30 4.8 20 3.6 A 2.4 A 1.2 A 10 0 A 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 6 of 22 Input Voltage (V) CP60239H PERFORMANCE (Th=27°C) 6A 4.0 4.8 A 3.6 A 2.4 A 2.0 1.2 A Heat Pumped, Q (W) 0 6A 12 4.8 8.0 A 3.6 A 2.4 A 1.2 A 4.0 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP60239H PERFORMANCE (Th=50°C) 6A 4.0 4.8 A 3.6 A 2.4 A 2.0 1.2 A Heat Pumped, Q (W) 0 6A 4.8 12 3.6 A A 2.4 A 8.0 1.2 A 4.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 7 of 22 Input Voltage (V) CP602040395H PERFORMANCE (Th=27°C) 8.0 6A 4.8 A 6.0 3.6 A 4.0 2.4 A 1.2 A 2.0 Heat Pumped, Q (W) 0 40 4.8 A 30 6A 20 3.6 A 10 2.4 A 1.2 A 0 70 60 50 40 ΔT=Th-Tc (°C) 30 10 20 0 CP602040395H PERFORMANCE (Th=50°C) Input Voltage (V) 6A 8.0 4.8 A 3.6 A 6.0 2.4 A 4.0 1.2 A 2.0 Heat Pumped, Q (W) 0 40 4.8 A 30 6A 20 2.4 A 10 0 3.6 A 1.2 A 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 8 of 22 Input Voltage (V) CP60301233H PERFORMANCE (Th=27°C) 8.0 6.0 6A 4.8 A 3.6 A 4.0 2.4 A 2.0 1.2 A Heat Pumped, Q (W) 0 20 6A 4.8 A 15 3.6 A 2.4 A 10 1.2 A 5.0 0 70 60 50 40 ΔT=Th-Tc (°C) 30 20 10 0 Input Voltage (V) CP60301233H PERFORMANCE (Th=50°C) 8.0 6.0 6A 4.8 A 3.6 A 4.0 2.4 A 2.0 1.2 A Heat Pumped, Q (W) 0 6A 20 4.8 A 3.6 A 15 2.4 A 10 1.2 A 5.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 9 of 22 Input Voltage (V) CP60301531H PERFORMANCE (Th=27°C) 8.0 6A 4.8 A 6.0 3.6 A 4.0 2.4 A 1.2 A 2.0 Heat Pumped, Q (W) 0 6A 24 4.8 A 3.6 A 18 2.4 A 12 1.2 A 6.0 0 70 60 50 40 ΔT=Th-Tc (°C) 30 20 10 0 Input Voltage (V) CP60301531H PERFORMANCE (Th=50°C) 8.0 6A 4.8 A 3.6 A 6.0 2.4 A 4.0 1.2 A 2.0 Heat Pumped, Q (W) 0 6A 4.8 A 24 3.6 A 18 2.4 A 12 1.2 A 6.0 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 10 of 22 Input Voltage (V) CP60302031H PERFORMANCE (Th=27°C) 16 6A 12 4.8 A 3.6 A 8 2.4 A 4 1.2 A Heat Pumped, Q (W) 0 48 4.8 A 6A 36 3.6 A 24 2.4 A 1.2 A 12 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP60302031H PERFORMANCE (Th=50°C) 16 12 6A 4.8 A 3.6 A 8.0 2.4 A 1.2 A 4.0 Heat Pumped, Q (W) 0 6A A 4.8 48 3.6 36 A 2.4 A 24 1.2 A 12 0 70 60 50 40 30 ΔT=Th-Tc (°C) cuidevices.com 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 11 of 22 Input Voltage (V) CP603315H PERFORMANCE (Th=27°C) 6A 16 4.8 A 3.6 A 2.4 A 8.0 1.2 A 0 Heat Pumped, Q (W) 6A 4.8 40 3.6 A A 2.4 A 20 1.2 A 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) CP603315H PERFORMANCE (Th=50°C) Input Voltage (V) 6A 4.8 A 16 3.6 A 2.4 A 8.0 1.2 A Heat Pumped, Q (W) 0 6A 4.8 3.6 40 A A 2.4 A 20 1.2 A 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 12 of 22 Input Voltage (V) CP6030395 PERFORMANCE (Th=27°C) 6A 4.8 A 10 3.6 A 2.4 A 5 1.2 A 0 Heat Pumped, Q (W) 40 6A 4.8 A 3.6 A 30 2.4 A 20 1.2 A 10 0 70 60 50 40 ΔT=Th-Tc (°C) 30 20 10 0 Input Voltage (V) CP6030395 PERFORMANCE (Th=50°C) 6A 4.8 A 10 3.6 A 2.4 A 5 1.2 A 0 6A A 4.8 Heat Pumped, Q (W) 40 3.6 A 30 2.4 A 20 1.2 A 10 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 13 of 22 CP603395H PERFORMANCE (Th=27°C) Input Voltage (V) 6A 4.8 A 8.0 3.6 A 2.4 A 4.0 1.2 A 0 Heat Pumped, Q (W) 30 6A 4.8 3.6 20 A A 2.4 A 10 1.2 A 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) CP603395H PERFORMANCE (Th=50°C) Input Voltage (V) 6A 4.8 A 8.0 3.6 A 2.4 A 4.0 1.2 A 0 6A A 4.8 Heat Pumped, Q (W) 30 3.6 20 A 2.4 A 1.2 A 10 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 14 of 22 Input Voltage (V) CP604020395H PERFORMANCE (Th=27°C) 8.0 6A 4.8 A 6.0 3.6 A 4.0 2.4 A 1.2 A 2.0 Heat Pumped, Q (W) 0 40 4.8 A 30 6A 20 3.6 A 10 2.4 A 1.2 A 0 70 60 50 40 ΔT=Th-Tc (°C) 30 10 20 0 CP604020395H PERFORMANCE (Th=50°C) Input Voltage (V) 6A 8.0 4.8 A 3.6 A 6.0 2.4 A 4.0 1.2 A 2.0 Heat Pumped, Q (W) 0 40 4.8 A 30 6A 20 2.4 A 10 0 3.6 A 1.2 A 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 15 of 22 Input Voltage (V) CP60433H PERFORMANCE (Th=27°C) 24 6A 18 4.8 A 3.6 A 12 2.4 A 6.0 1.2 A Heat Pumped, Q (W) 0 80 4.8 A 6A 60 3.6 A 40 2.4 A 20 1.2 A 0 70 60 50 40 ΔT=Th-Tc (°C) 30 20 10 0 Input Voltage (V) CP60433H PERFORMANCE (Th=50°C) 24 18 6A 4.8 A 3.6 A 12 2.4 A 1.2 A 6.0 Heat Pumped, Q (W) 0 4.8 A 80 6A 60 3.6 A 2.4 A 40 1.2 A 20 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 16 of 22 Input Voltage (V) CP604395H PERFORMANCE (Th=27°C) 6A 16 4.8 A 3.6 A 2.4 A 8.0 1.2 A 0 Heat Pumped, Q (W) 60 4.8 A 6A 3.6 40 A 2.4 A 20 1.2 A 0 70 60 50 40 30 20 10 0 ΔT=Th-Tc (°C) Input Voltage (V) CP604395H PERFORMANCE (Th=50°C) 6A 4.8 A 16 3.6 A 2.4 A 8.0 1.2 A 0 4.8 A Heat Pumped, Q (W) 60 6A 3.6 40 A 2.4 A 1.2 A 20 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 17 of 22 Input Voltage (V) CP604040 PERFORMANCE (Th=27°C) 6A 24 4.8 A 18 3.6 A 2.4 A 12 1.2 A 6 Heat Pumped, Q (W) 0 6A A 8 . 4 3.6 A 80 60 2.4 40 1.2 A 20 0 A 70 60 50 40 ΔT=Th-Tc (°C) 30 20 10 0 Input Voltage (V) CP604040 PERFORMANCE (Th=50°C) 6A 24 4.8 A 3.6 A 18 2.4 A 12 1.2 A 6 Heat Pumped, Q (W) 0 6A A 4.8 80 3.6 A 60 2.4 A 40 1.2 A 20 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 18 of 22 Input Voltage (V) CP60546241 PERFORMANCE (Th=27°C) 6A 40 4.8 A 30 3.6 A 2.4 A 20 1.2 A 10 Heat Pumped, Q (W) 0 160 6A A 4.8 120 3.6 A 2.4 A 80 1.2 A 40 0 70 60 50 40 ΔT=Th-Tc (°C) 30 20 10 0 CP60546241 PERFORMANCE (Th=50°C) Input Voltage (V) 6A 40 4.8 A 3.6 A 30 2.4 A 20 1.2 A 10 Heat Pumped, Q (W) 0 160 6A 120 2.4 80 A 1.2 A 40 0 4.8 A 3.6 A 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 19 of 22 Input Voltage (V) CP6055354 PERFORMANCE (Th=27°C) 40 6A 4.8 A 30 3.6 A 20 2.4 A 1.2 A 10 Heat Pumped, Q (W) 0 6A A 8 . 4 120 3.6 A 90 2.4 A 60 1.2 A 30 0 70 60 50 30 40 ΔT=Th-Tc (°C) 20 10 0 Input Voltage (V) CP6055354 PERFORMANCE (Th=50°C) 40 6A 4.8 A 30 3.6 A 20 2.4 A 1.2 A 10 Heat Pumped, Q (W) 0 6A A 4.8 120 3.6 A 90 2.4 A 60 1.2 A 30 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 20 of 22 Input Voltage (V) CP60555542 PERFORMANCE (Th=27°C) 32 6A 4.8 A 24 3.6 A 16 2.4 A 1.2 A 8 Heat Pumped, Q (W) 0 6A 100 4.8 80 A 3.6 A 60 2.4 A 40 1.2 A 20 0 70 60 50 30 40 ΔT=Th-Tc (°C) 20 0 10 Input Voltage (V) CP60555542 PERFORMANCE (Th=50°C) 32 6A 6A 4.8 A 4.8 A 24 3.6 A 3.6 A 2.4 A 16 2.4 A 1.21.2 A A 8 0 6A 6 AA 4.8 Heat Pumped, Q (W) 100 A 4.8 3.6 A 80 3.6 A 60 2.4 A 2.4 A 40 1.2 A 1.2 A 20 0 70 60 40 50 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 21 of 22 Input Voltage (V) CP604060395 PERFORMANCE (Th=27°C) 24 6A 4.8 A 18 3.6 A 12 2.4 A 1.2 A 6 Heat Pumped, Q (W) 0 80 6A 60 3.6 A 40 A 2.4 A 1.2 A 20 0 4.8 70 60 30 40 50 ΔT=Th-Tc (°C) 20 10 0 Input Voltage (V) CP604060395 PERFORMANCE (Th=50°C) 24 6A 4.8 A 18 3.6 A 12 2.4 A 1.2 A 6 Heat Pumped, Q (W) 0 80 6A 60 3.6 A 40 A 2.4 A 1.2 A 20 0 4.8 70 60 40 50 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CP60H | DESCRIPTION: PELTIER MODULE date 08/05/2022 | page 22 of 22 REVISION HISTORY rev. description date 1.0 initial release 09/08/2016 1.01 updated datasheet 09/25/2017 1.02 added new models 05/21/2018 1.03 added models CP604060395, CP60555542, CP6030395, CP604040, CP6055354, CP60546241, brand update 10/22/2019 1.04 added model CP60302031H 11/12/2020 logo, datasheet style update 08/05/2022 1.05 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CP60239H 价格&库存
很抱歉,暂时无法提供与“CP60239H”相匹配的价格&库存,您可以联系我们找货
CP60239H
    • 2+207.43736
    • 20+198.64764
    • 70+189.85792
    库存:100
