RC3-6-01LS
RC3-6-01LS
    MARLOWINDUSTRIES,INC.
    TEM20.1X20.1X3.91MM
RC3-6-01LS 数据手册
  Technical Data Sheet for RC3‐6  Single‐Stage Thermoelectric Module      NOMINAL PERFORMANCE IN NITROGEN      Hot Side Temperature (°C)  Δ Tmax (°C):  Qmax (watts):  Imax (amps):  Vmax (vdc):  AC Resistance (ohms):    27  65  13  5.6  3.6  0.5    50  73  14  5.6  4.1  ‐‐‐        PRODUCT FEATURES              OPERATION CAUTIONS    For maximum reliability, storage and operation below  130°C in a non‐condensing environment is recommended.   To minimize thermal stress, use linear/proportional  temperature control or a similar method rather than an  ON/OFF method.  ORDERING OPTIONS      RoHS EU Compliant  Rated operating temperature of 130°C.  Ceramic Material:  Aluminum Oxide  Porch configuration for high strength lead wire connection.  Superior nickel diffusion barriers on elements.  High strength for rugged environment.  RTV sealing option available.  Lapped option available for multiple module applications.  Model Number  RC3‐6‐01  RC3‐6‐01L  RC3‐6‐01S  RC3‐6‐01LS        Description  Leadwires  Leadwires, Lapped  Leadwires, Sealed  Leadwires, Lapped, Sealed        INSTALLATION    Recommended mounting method:  Clamp with uniform  pressure to a flat surface with thermal interface material.  For  additional information, please refer to our TEM Installation  Guide.        II‐VI Marlow – Dallas, TX USA  214‐340‐4900  877‐627‐5691  marlow.sales@ii‐vi.com  Marlow Industries Europe  GmbH ‐ Germany  +49 (0) 6150 5439 ‐ 403  info@marlow‐europe.eu  II‐VI Japan Inc.   81 43 297 2693 (tel)  center@ii‐vi.co.jp  www.ii‐vi.co.jp  MI Form 005‐0690 Rev. 4  Marlow Industries China, II‐VI  Technologies Beijing  86‐10‐643 98226  info@iivibj.com  DOC # 102‐0284 REV H ‐ PAGE 1 OF 2  www.marlow.com    II‐VI Singapore Pte., Ltd.   (65) 6481 8215 (tel)  info@ii‐vi.com.sg        ENVIRONMENT:  ONE ATMOSPHERE DRY NITROGEN    TA(C) 27 Hot Side Temperature 27°C  80.0 80.0 HEAT LOAD (WATTS) 0.00 1.00 2.00 3.00 4.00 5.00 6.00 7.00 8.00 9.00 10.0 11.0 12.0 40.0 20.0 0.0 60.0 T (C) 60.0 T (C) TA(C) 50 Hot Side Temperature 50°C  20.0 0.0 0.00 1.00 2.00 3.00 4.00 5.00 6.00 7.00 8.00 9.00 10.0 11.0 12.0 13.0 4.0 VOLTAGE (VDC) VOLTAGE (VDC) 4.0 3.0 2.0 Q=0 T=0 1.0 0.0 0.0 40.0 HEAT LOAD (WATTS) 3.0 2.0 Q=0 T=0 1.0 0.0 2.0 3.0 4.0 5.0 6.0 7.0 0.0 1.0 2.0 3.0 4.0 5.0 6.0 7.0 CURRENT (AMPS) CURRENT (AMPS) For performance information with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877‐627‐5691.  1.0   MECHANICAL CHARACTERISTICS  TYPICAL PERFORMANCE CURVES  THERMOELECTRIC COOLING PERFORMANCE CURVES    All units are in millimeters unless otherwise stated.      For customer support or general questions please contact a local office or visit our website at www.marlow.com.   Marlow reserves the right to make product changes without notice.    MI Form 005‐0690 Rev. 4   DOC # 102‐0284 REV H ‐ PAGE 2 OF 2  www.marlow.com
RC3-6-01LS 价格&库存
很抱歉,暂时无法提供与“RC3-6-01LS”相匹配的价格&库存,您可以联系我们找货
