Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 9
SERIES: CP39H | DESCRIPTION: PELTIER MODULE
FEATURES
• arcTEC™ structure on select models
• enhanced reliability for high thermal cycling
• superior thermal performance
• silicon sealed
• wide ΔT max
• low profile
• precise temperature control
• solid state construction
MODEL
input
voltage1
input
current2
internal
resistance3
max
(Vdc)
max
(A)
typ
(Ω±10%)
CP39136H
3.8
3.9
0.85
CP39236H
8.8
3.9
1.95
CP39234030H
14.9
3.9
3.38
CP39301536H
7.6
3.9
1.73
CP393365H
15.7
3.9
3.50
CP3940443656
32.5
3.9
6.95±5%
6
Notes:
1. Maximum voltage at ΔT max and Th=27°C
2. Maximum current to achieve ΔT max
3. Measured by AC 4-terminal method at 25°C
4. Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C
5. Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa)
6. Designed with arcTEC™ structure.
cuidevices.com
output
Qmax4
Th=27°C
(W)
output
∆Tmax5
Th=50°C
(W)
Th=27°C
(°C)
Th=50°C
(°C)
8.6
9.5
70
77
18.7
20.9
70
77
31.0
35.9
68
75
16.5
18.1
70
77
35.2
39.0
70
77
71.8
80.0
70
77
Product Page
3D Model
CUI DEVICES | SERIES: CP39H | DESCRIPTION: PELTIER MODULE
date 08/05/2022 | page 2 of 9
SPECIFICATIONS
parameter
conditions/description
min
solder melting temperature
connection between thermoelectric pairs
235
typ
max
°C
assembly compression
1
RoHS
units
MPa
yes
MECHANICAL DRAWING
units: mm
MATERIAL
HOT SIDE
0.05
THICKNESS
COLD SIDE
0.05
ceramic plate
96% AL2O3
wire leads
22 AWG
sealer
silicon rubber 703 RTV (between cold and
hot side plates)
joint cover
marking
P/N & S/N printed on cold side surface
10.0 3.0
Red (+)
WIDTH
COLD SIDE
Black (-)
LENGTH
100.0 5.0
MODEL NO.
LENGTH
(mm)
WIDTH
(mm)
THICKNESS
(mm)
CP39136H
15 ±0.3
15 ±0.3
3.6 ±0.025
CP39236H
20 ±0.3
20 ±0.3
3.6 ±0.025
CP39234030H
23 ±0.3
40 ±0.3
3.0 ±0.05
CP39301536H
30 ±0.3
15 ±0.3
3.6 ±0.025
CP393365H
30 ±0.3
30 ±0.3
3.65 ±0.025
CP394044365
44 ±0.3
40.5 ±0.3
3.65 ±0.1
cuidevices.com
PLATING
tin
Product Page
3D Model
date 08/05/2022 | page 3 of 9
Heat Pumped, Q (W)
Input Voltage (V)
CP39136H PERFORMANCE (Th=27°C)
3.9 A
4.0
3.12 A
2.34 A
1.56 A
2.0
0.78 A
2A
8.0
A
3.1
4A
2.3
6.0
6A
1.5
4.0
0.78
2.0
A
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP39136H PERFORMANCE (Th=50°C)
4.0
3.9 A
3.12 A
2.34 A
1.56 A
2.0
0.78 A
Heat Pumped, Q (W)
A
3.9
A
2
3.1
8.0
4A
2.3
6.0
6A
1.5
4.0
0.78
2.0
A
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 4 of 9
CP39236H PERFORMANCE (Th=27°C)
Input Voltage (V)
3.9 A
3.12 A
8.0
2.34 A
1.56 A
4.0
0.78 A
Heat Pumped, Q (W)
16
A
3.12
A
4A
2.3
A
1.56
8.0
0.78
A
60
50
40
30
ΔT=Th-Tc (°C)
CP39236H PERFORMANCE (Th=50°C)
Input Voltage (V)
3.9 A
3.12 A
8.0
2.34 A
1.56 A
4.0
0.78 A
Heat Pumped, Q (W)
12 A
3.
16
4A
2.3
1.56
8.0
A
0.78
A
A
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 5 of 9
Input Voltage (V)
CP39234030H PERFORMANCE (Th=27°C)
16.0
3.9 A
3.12 A
12.0
2.34 A
8.0
1.56 A
0.78 A
4.0
Heat Pumped, Q (W)
24
16
3.9
A
2.34
A
3.12
A
1.56
A
0.78 A
8.0
60
50
40
30
ΔT=Th-Tc (°C)
10
Input Voltage (V)
CP39234030H PERFORMANCE (Th=50°C)
16
3.9 A
3.12 A
12
2.34 A
1.56 A
8.0
0.78 A
4.0
Heat Pumped, Q (W)
32
3.12
24
A
4A
1.56
16
A
0.78
8.0
70
60
50
40
30
ΔT=Th-Tc (°C)
cuidevices.com
A
A
Product Page
3D Model
date 08/05/2022 | page 6 of 9
Input Voltage (V)
CP39301536H PERFORMANCE (Th=27°C)
3.9 A
8.0
3.12 A
6.0
2.34 A
1.56 A
4.0
0.78 A
2.0
Heat Pumped, Q (W)
3.9
12
2.3
8.0
1.56
4.0
A
A
4A
A
0.78 A
60
70
50
40
ΔT=Th-Tc (°C)
30
10
Input Voltage (V)
CP39301536H PERFORMANCE (Th=50°C)
8.0
3.9 A
3.12 A
2.34 A
6.0
1.56 A
4.0
0.78 A
2.0
Heat Pumped, Q (W)
3.9
12
2.3
8.0
4.0
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
1.56
A
0.78
A
3.12
A
A
4A
Product Page
3D Model
date 08/05/2022 | page 7 of 9
Input Voltage (V)
CP393365H PERFORMANCE (Th=27°C)
3.9 A
16
3.12 A
2.34 A
1.56 A
8.0
0.78 A
Heat Pumped, Q (W)
30
A
2A
3.1
4A
2.3
1.56
A
0.78
A
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP393365H PERFORMANCE (Th=50°C)
3.9 A
16
3.12 A
2.34 A
1.56 A
8.0
0.78 A
3.12 A
Heat Pumped, Q (W)
3.9
A
4A
2.3
30
1.56
10
A
A
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 8 of 9
Input Voltage (V)
CP394044365 PERFORMANCE (Th=27°C)
3.9 A
32
3.12 A
24
2.34 A
1.56 A
16
0.78 A
8
Heat Pumped, Q (W)
A
3.9 2 A
3.1
60
2.3
40
1.56
4A
A
0.78 A
60
50
40
ΔT=Th-Tc (°C)
30
10
CP394044365 PERFORMANCE (Th=50°C)
Input Voltage (V)
3.9 A
32
3.12 A
2.34 A
24
1.56 A
16
0.78 A
8
Heat Pumped, Q (W)
3.9 A
60
2.34
A
1.56
40
A
A
0.78 A
70
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 9 of 9
REVISION HISTORY
rev.
description
date
1.0
initial release
09/08/2016
1.01
updated datasheet
09/25/2017
1.02
added new model
05/21/2018
1.03
added model CP394044365, brand update
10/16/2019
1.04
added model CP39234030H
11/12/2020
logo, datasheet style update
08/05/2022
1.05
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CP39236H”相匹配的价格&库存,您可以联系我们找货
