XLT6-4-01LS
XLT6-4-01LS
    MARLOWINDUSTRIES,INC.
    TEMTHERMOCYCLER23.5X23.5X3.33MM
XLT6-4-01LS 数据手册
Technical Data Sheet for XLT6-4 Single-Stage Thermoelectric Module NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): PRODUCT FEATURES • • • • • • • • • • 27 65 20 3.7 8.2 1.8 50 73 22 3.7 9.2 --- ORDERING OPTIONS RoHS EU Compliant and REACH EU Compliant Rated operating temperature of 125°C. Ceramic Material: Aluminum Oxide Designed for temperature cycling applications. Capable of rapid heating and cooling rates. Porch configuration for high strength leadwire connection. Superior nickel diffusion barriers on elements. High strength for rugged environment. RTV sealing option available. Lapped option available for multiple module applications. Model Number XLT6-4-01 XLT6-4-01L XLT6-4-01S XLT6-4-01LS Description Leadwires Leadwires, Lapped Leadwires, Sealed Leadwires, Lapped, Sealed OPERATION CAUTIONS INSTALLATION For maximum reliability, storage and operation below 125°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Recommended mounting method: Clamp with uniform pressure to a flat surface with thermal interface material. For additional information, please refer to our TEC Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0692 Rev. 4 www.marlow.com II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0415 REV D - PAGE 1 OF 2 TYPICAL PERFORMANCE CURVES ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN Hot Side Temperature 50°C Hot Side Temperature 27°C 80.0 60.0 HEAT LOAD (WATTS) 0.00 60.0 2.50 40.0 5.00 7.50 2.50 T (C) T (C) 80.0 HEAT LOAD (WATTS) 0.00 5.00 40.0 7.50 10.0 20.0 10.0 12.5 20.0 12.5 15.0 0.0 15.0 0.0 10.0 6.0 4.0 Q=0 T=0 2.0 VOLTAGE (VDC) VOLTAGE (VDC) 8.0 8.0 6.0 4.0 Q=0 T=0 2.0 0.0 0.0 1.0 2.0 3.0 CURRENT (AMPS) 4.0 0.0 0.0 5.0 1.0 2.0 3.0 CURRENT (AMPS) 4.0 5.0 MECHANICAL CHARACTERISTICS For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691. (+), WHITE .925 [23.50] .59 [15] 20 AWG LEADS, TEFLON INSULATED (-), BLACK .925 [23.50] 4.00 ± .50 [101 ± 13] 1.102 [27.99] COLD SIDE, Tc HOT SIDE, Th -01 & -01S -01L & -01LS .135±.005 [3.43±0.13] .131±.001 [3.33±0.03] -01, -01S -01L, -01LS .003 [0.08] .002 [0.05] .002 [0.05] .001 [0.03] .002 [0.05] .001 [0.03] A A Dimensions in [ ] are millimeters For customer support or general questions please contact a local office or visit our website at www.marlow.com. MI Form 005-0692 Rev. 4 www.marlow.com DOC # 102-0415 REV D - PAGE 2 OF 2
XLT6-4-01LS 价格&库存
很抱歉,暂时无法提供与“XLT6-4-01LS”相匹配的价格&库存,您可以联系我们找货
