CM29-1.9-04AC
CM29-1.9-04AC
    MARLOWINDUSTRIES,INC.
    TEM10.2X6.02X1.68MM
CM29-1.9-04AC 数据手册
Technical Data Sheet for CM29-1.9 Commercial Module for CATV & SLED Applications PRODUCT FEATURES        -07AC -06AC -01AC, -04AC, -05AC NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): RoHS EU Compliant Rated operating temperature of 85°C. Maximum process temperature is 220°C. Ceramic Material: Aluminum Oxide -01AC: Au flash exterior, suitable for soldering. See page 2 for leadwire configurations. Minimum order quantity of 20 pieces. OPERATION CAUTIONS 27 71 4.3 1.9 3.5 1.54 85 92 5.2 1.8 4.4 -- ORDERING OPTIONS Model Number CM29-1.9-01AC CM29-1.9-04AC CM29-1.9-05AC CM29-1.9-06AC CM29-1.9-07AC For maximum reliability, storage and operation below 85°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Description Top and Base Metallized Exterior 146°C Pretinned Top and Base Exterior 138°C Pretinned Top and Base Exterior Bare Exterior Bare Exterior INSTALLATION Recommended mounting methods: Bonding with thermal epoxy or soldering with metallized ceramics. For additional information, please refer to our TEM Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0808 Rev. B II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0356 REV L - PAGE 1 OF 2 www.marlow.com HotTSide Temperature 85°C A = 85°C - Vacuum Hot Side 27°C TA = Temperature 27°C - Vacuum Heat Load (W) 100.0 80.0 40.0 20.0 60.0 DT (°C) 0.00 0.50 1.00 1.50 2.00 2.50 3.00 3.50 4.00 60.0 DT (°C) Heat Load (W) 0.00 0.50 1.00 1.50 2.00 2.50 3.00 100.0 80.0 40.0 3.50 4.00 4.50 5.00 20.0 0.0 0.0 0.0 0.4 0.8 1.2 1.6 2.0 0.0 5.0 5.0 4.0 4.0 Voltage (VDC) Voltage (VDC) TYPICAL PERFORMANCE CURVES ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN Q=0 3.0 2.0 DT = 0 1.0 0.0 0.4 0.8 1.2 1.6 2.0 Q=0 3.0 2.0 DT = 0 1.0 0.0 0.0 0.4 0.8 1.2 1.6 2.0 0.0 0.4 Current (amps) 0.8 1.2 1.6 2.0 Current (amps) For performance information in a vacuum or with hot side temperatures other than 27°C or 85°C, contact one of our Applications Engineers at 877-627-5691. -07AC MECHANICAL CHARACTERISTICS -01AC, -04AC, -05AC -06AC All dimensions are millimeters unless otherwise stated. For customer support or general questions please contact a local office or visit our website at www.marlow.com. Marlow reserves the right to make product changes without notice. MI Form 005-0808 Rev. B DOC # 102-0356 REV L - PAGE 2 OF 2 www.marlow.com
CM29-1.9-04AC 价格&库存
很抱歉,暂时无法提供与“CM29-1.9-04AC”相匹配的价格&库存,您可以联系我们找货
CM29-1.9-04AC
  • 1+314.158091+40.77199
  • 5+295.184255+38.30953
  • 10+287.3536410+37.29326
  • 25+277.3223925+35.99139
  • 50+269.9705350+35.03725
  • 100+262.81465100+34.10855
库存:426
