CM35-1.9-01AC
CM35-1.9-01AC
    MARLOWINDUSTRIES,INC.
    TEM12.19X5.99X1.65MM
CM35-1.9-01AC 数据手册
Technical Data Sheet for CM35-1.9 Commercial Module for CATV & SLED Applications NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): PRODUCT FEATURES      27 71 5.2 1.9 4.2 1.87 85 92 6.2 1.8 5.3 --- ORDERING OPTIONS RoHS EU Compliant Ceramic Material: Aluminum Oxide (AC) or Aluminum Nitride (AN) Au flash exterior, suitable for soldering. Maximum process temperature is 220°C. Height includes metallization, where applicable, and excludes tinning. Model Number CM35-1.9-01AC CM35-1.9-04AC CM35-1.9-05AC CM35-1.9-06AC CM35-1.9-07AC CM35-1.9-08AN CM35-1.9-09AN Description TEM, Top and Base Metallized Exterior, ALO Ceramics -01AC, Top and Base Pre-Tinned w/146°C Solder -01AC, Top and Base Pre-Tinned w/138°C Solder -01AC, Top and Base Pre-Tinned w/183°C Solder -01AC, Top and Base Pre-Tinned w/118°C Solder TEM, Top and Base Metallized Exterior, ALN Ceramics TEM, No Metallized Exterior, ALN Ceramics OPERATION CAUTIONS INSTALLATION For maximum reliability, storage and operation below 85°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Recommended mounting methods: Bonding with thermal epoxy or soldering with metallized ceramics. For additional information, please refer to our TEC Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0808 Rev. A II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0355 REV H - PAGE 1 OF 2 www.marlow.com = 85°C - Vacuum HotTASide Temperature 85°C A = 27°C - Vacuum HotTSide Temperature 27°C Heat 100.0 Heat Load (W) 100.0 Load (W) 0.00 80.0 80.0 1.00 0.00 1.00 2.00 40.0 2.00 60.0 DT (°C) DT (°C) 60.0 3.00 40.0 4.00 3.00 20.0 20.0 4.00 0.0 0.4 0.8 1.2 1.6 2.0 5.0 5.0 Voltage (VDC) 6.0 Q=0 3.0 2.0 DT = 0 1.0 6.00 0.0 6.0 4.0 5.00 0.0 5.00 0.0 Voltage (VDC) TYPICAL PERFORMANCE CURVES ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN 0.4 0.8 1.2 1.6 2.0 Q=0 4.0 3.0 2.0 DT = 0 1.0 0.0 0.0 0.0 0.4 0.8 1.2 1.6 2.0 Current (amps) 0.0 0.4 0.8 1.2 1.6 2.0 Current (amps) MECHANICAL CHARACTERISTICS For performance information in a vacuum or with hot side temperatures other than 27°C or 85°C, contact one of our Applications Engineers at 877-627-5691. TYPICAL PERFORMANCE Environment : Vacuum TA (C) : 27 VMAX (VDC) : 4.2 D TMAX (C) : 71 IMAX (amps) : 1.9 QMAX (W) : 5.2 ACR (W) : 1.87 TYPICAL PERFORMANCE Environment : Vacuum TA (C) : 85 VMAX (VDC) : 5.3 D TMAX (C) : 92 IMAX (amps) : 1.8 QMAX (W) : 6.2 ACR (W) : - All dimensions are in millimeters unless otherwise stated. * NOTE: Dimension is without pre-tinning. For customer support or general questions please contact a local office or visit our website at www.marlow.com. Marlow reserves the right to make product changes without notice. MI Form 005-0808 Rev. A DOC # 102-0355 REV H - PAGE 2 OF 2 www.marlow.com
CM35-1.9-01AC 价格&库存
很抱歉,暂时无法提供与“CM35-1.9-01AC”相匹配的价格&库存,您可以联系我们找货
CM35-1.9-01AC
  • 1+329.692031+42.85193
  • 5+309.728735+40.25719
  • 20+293.5150920+38.14981
  • 40+285.7317640+37.13816
  • 60+281.2779660+36.55928
  • 100+275.76382100+35.84258
库存:579
