HiTemp ET Series ET20-31-F1A-0909-11-W2.25
MFG Part Number: 430549-501
Legacy Product
HiTemp ET Series Thermoelectric Cooler
Features
Note: This product is not recommended for new designs.
This product series has been replaced with the HiTemp ETX Series.
The recommended replacement is:
MFG Part Number: 387006918
Description: OTX20-31-F1A-0909-11-W2.25
Applications
High-temperature operation
Reliable solid-state
No sound or vibration
Environmentally-friendly
RoHS-compliant
Peltier Cooling for Refrigerated Centrifuges
Peltier Cooling for Machine Vision
Thermoelectric Cooling for CMOS Sensors
Cooling Solutions for Autonomous Systems
Peltier Cooling for Digital
Light Processors
ELECTRICAL AND THERMAL PERFORMANCE
For maximum performance, be sure to orient the CONTROL side of the TEC against the application to be managed and the HEATSINK side against the heat sink or other heat
rejection method. The CONTROL side is always opposite the side with lead attachments. Lead attachment is a passive heat loss and less impactful if located on the side that attaches
to the heat exchanger.
Heat Pumped at Cold Side
Thot = 85 °C
5.00
5.00
4.00
4.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
3.00
2.00
Qc (Watts)
Qc (Watts)
Thot = 85 °C
1.00
0.00
0.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
3.00
2.00
1.00
0.50
1.00
1.50
2.00
0.00
0.00
2.50
1.00
Operating Current (Amps)
2.00
3.00
4.00
Operating Voltage (Volts)
Current vs Voltage (I vs V)
Thot = 85 °C
5.00
4.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
3.00
2.00
1.00
0.00
0.00
0.50
1.00
1.50
2.00
2.50
5.00
Legacy Product
Coefficient of Performance (COP = Qc/Pin)
Thot = 85 °C
6.00
6.00
5.00
5.00
3.00
3.00
2.00
2.00
1.00
1.00
0.00
0.00
0.50
1.00
1.50
2.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
4.00
COP
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
4.00
COP
Thot = 85 °C
0.00
0.00
2.50
1.00
2.00
Total Heat Dissipated at Hot Side (Qh=Qc+Pin)
Thot = 85 °C
4.00
5.00
Thot = 85 °C
16.00
16.00
14.00
14.00
12.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
10.00
8.00
6.00
Qh (Watts)
12.00
Qh (Watts)
3.00
8.00
6.00
4.00
4.00
2.00
2.00
0.00
0.00
0.50
1.00
1.50
2.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
10.00
0.00
0.00
2.50
1.00
2.00
3.00
4.00
5.00
Heat Pumped at Cold Side (Qc)
Thot = 85 °C | Current = 1.6 Amps
5.00
2.00
4.00
3.00
COP
Qc (Watts)
1.50
1.00
2.00
0.50
1.00
0.00
0.0
10.0
20.0
30.0
40.0
50.0
ΔT (°C)
60.0
70.0
80.0
90.0
0.00
0.0
10.0
20.0
30.0
40.0
50.0
ΔT (°C)
60.0
70.0
80.0
90.0
Legacy Product
SPECIFICATIONS*
Hot Side Temperature
50.0 °C
85.0 °C
110.0 °C
Qcmax (ΔT = 0)
4.3 Watts
4.8 Watts
5.0 Watts
ΔTmax (Qc = 0)
77.9°C
89.3°C
96.2°C
Imax (I @ ΔTmax)
2.0 Amps
1.9 Amps
1.9 Amps
Vmax (V @ ΔTmax)
3.7 Volts
4.3 Volts
4.7 Volts
Module Resistance
1.75 Ohms
2.03 Ohms
2.22 Ohms
Max Operating Temperature
150 °C
Weight
1.0 gram(s)
* Specifications reflect thermoelectric coefficients updated March 2020
FINISHING OPTIONS
Suffix
Thickness
Flatness / Parallelism
Hot Face
Cold Face
Lead Length
11
2.184 ±0.051 mm
0.086 ± 0.0020 in
0.051 mm / 0.051 mm
0.002 in / 0.002 in
Lapped
Lapped
50.8 mm
2.00 in
SEALING OPTIONS
Suffix
Sealant
Color
None
Temp Range
Description
No sealing specified
NOTES
1.
2.
3.
Max operating temperature: 150°C
Do not exceed Imax or Vmax when operating module
Reference assembly guidelines for recommended installation
Any information furnished by Laird and its agents, whether in specifications, data sheets, product catalogues or otherwise, is believed to be (but is not warranted as
being) accurate and reliable, is provided for information only and does not form part of any contract with Laird. All specifications are subject to change without notice.
Laird assumes no responsibility and disclaims all liability for losses or damages resulting from use of or reliance on this information. All Laird products are sold
subject to the Laird Terms and Conditions of sale (including Laird’s limited warranty) in effect from time to time, a copy of which will be furnished upon request.
© Copyright 2019-2022 Laird Thermal Systems, Inc. All rights reserved. Laird™, the Laird Ring Logo, and Laird Thermal Systems™ are trademarks or registered
trademarks of Laird Limited or its subsidiaries.
Revision: 00 Date: 06-01-2022
Print Date: 06-15-2022
很抱歉,暂时无法提供与“430549-501”相匹配的价格&库存,您可以联系我们找货
