56890-503
56890-503
    LAIRD(莱尔德)
    PELTIER MOD CP14,71,045,L1,W4.5
56890-503 数据手册
Ceramic Plate Series CP14-71-045-L1-W4.5 MFG Part Number: 56890-503 Ceramic Plate Series Thermoelectric Cooler Features ● The CP14-71-045-L1-W4.5 is a high-performance and highly reliable standard Thermoelectric Cooler. Assembled with Bismuth Telluride semiconductor material and thermally conductive Aluminum Oxide ceramics. It has a maximum Qc of 39.9 Watts when ΔT = 0 and a maximum ΔT of 70.5 °C at Qc = 0. ● ● Applications Compact geometric sizes DC Operation RoHS-compliant ● ● ● ● ● Thermoelectric Coolers for Reagent Storage Thermoelectric Coolers for Handheld Cosmetic Lasers Cooling for Centrifuges Heads-Up Displays, Imaging Sensors Peltier Cooling for Machine Vision ELECTRICAL AND THERMAL PERFORMANCE For maximum performance, be sure to orient the CONTROL side of the TEC against the application to be managed and the HEATSINK side against the heat sink or other heat rejection method. The CONTROL side is always opposite the side with lead attachments. Lead attachment is a passive heat loss and less impactful if located on the side that attaches to the heat exchanger. Heat Pumped at Cold Side Thot = 27 °C Heat Pumped at Cold Side Thot = 27 °C 45.00 45.00 40.00 40.00 35.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 30.00 25.00 20.00 Qc (Watts) Qc (Watts) 35.00 25.00 20.00 15.00 15.00 10.00 10.00 5.00 5.00 0.00 0.00 2.00 4.00 6.00 8.00 10.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 30.00 0.00 0.00 1.00 2.00 3.00 4.00 5.00 6.00 7.00 8.00 9.00 12.00 Operating Current (Amps) Operating Voltage (Volts) Operating Voltage (Volts) Current vs Voltage (I vs V) Thot = 27 °C 9.00 8.00 7.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 6.00 5.00 4.00 3.00 2.00 1.00 0.00 0.00 2.00 4.00 6.00 Operating Current (Amps) 8.00 10.00 12.00 Ceramic Plate Series CP14-71-045-L1-W4.5 MFG Part Number: 56890-503 Coefficient of Performance (COP = Qc/Pin) Thot = 27 °C 6.00 6.00 5.00 5.00 3.00 3.00 2.00 2.00 1.00 1.00 0.00 0.00 2.00 4.00 6.00 8.00 10.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 4.00 COP ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 4.00 COP Coefficient of Performance (COP = Qc/Pin) Thot = 27 °C 0.00 0.00 12.00 1.00 2.00 Operating Current (Amps) Total Heat Dissipated at Hot Side (Qh=Qc+Pin) Thot = 27 °C 140.00 120.00 120.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 80.00 60.00 20.00 20.00 8.00 10.00 7.00 8.00 9.00 0.00 0.00 12.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 60.00 40.00 6.00 6.00 80.00 40.00 4.00 5.00 100.00 Qh (Watts) Qh (Watts) 100.00 2.00 4.00 Total Heat Dissipated at Hot Side (Qh=Qc+Pin) Thot = 27 °C 140.00 0.00 0.00 3.00 Operating Voltage (Volts) 1.00 Operating Current (Amps) 2.00 3.00 4.00 5.00 6.00 7.00 8.00 9.00 Operating Voltage (Volts) Heat Pumped at Cold Side (Qc) Thot = 27 °C | Current = 7.3 Amps Coefficient of Performance (COP = Qc/Pin) Thot = 27 °C | Current = 7.3 Amps 40.00 2.00 35.00 1.50 25.00 COP Qc (Watts) 30.00 20.00 1.00 15.00 10.00 0.50 5.00 0.00 0.0 10.0 20.0 30.0 40.0 ΔT (°C) 50.0 60.0 70.0 80.0 0.00 0.0 10.0 20.0 30.0 40.0 ΔT (°C) 50.0 60.0 70.0 80.0 Ceramic Plate Series CP14-71-045-L1-W4.5 MFG Part Number: 56890-503 SPECIFICATIONS* Hot Side Temperature 27.0 °C 35.0 °C 50.0 °C Qcmax (ΔT = 0) 39.9 Watts 41.1 Watts 43.2 Watts ΔTmax (Qc = 0) 70.5°C 73.5°C 78.8°C Imax (I @ ΔTmax) 8.6 Amps 8.6 Amps 8.5 Amps Vmax (V @ ΔTmax) 7.8 Volts 8.1 Volts 8.6 Volts Module Resistance 0.84 Ohms 0.87 Ohms 0.94 Ohms Max Operating Temperature 80 °C Weight 12.0 gram(s) * Specifications reflect thermoelectric coefficients updated March 2020 FINISHING OPTIONS Suffix Thickness Flatness / Parallelism Hot Face Cold Face Lead Length L1 3.327 ±0.025 mm 0.131 ± 0.0010 in 0.025 mm / 0.025 mm 0.001 in / 0.001 in Lapped Lapped 114.3 mm 4.50 in SEALING OPTIONS Suffix Sealant Color None Temp Range Description No sealing specified NOTES 1. 2. 3. 4. Max operating temperature: 80°C Do not exceed Imax or Vmax when operating module Reference assembly guidelines for recommended installation Solder tinning also available on metallized ceramics Any information furnished by Laird and its agents, whether in specifications, data sheets, product catalogues or otherwise, is believed to be (but is not warranted as being) accurate and reliable, is provided for information only and does not form part of any contract with Laird. All specifications are subject to change without notice. Laird assumes no responsibility and disclaims all liability for losses or damages resulting from use of or reliance on this information. All Laird products are sold subject to the Laird Terms and Conditions of sale (including Laird’s limited warranty) in effect from time to time, a copy of which will be furnished upon request. © Copyright 2019-2022 Laird Thermal Systems, Inc. All rights reserved. Laird™, the Laird Ring Logo, and Laird Thermal Systems™ are trademarks or registered trademarks of Laird Limited or its subsidiaries. Revision: 00 Date: 06-01-2022 Print Date: 06-09-2022
56890-503 价格&库存
很抱歉,暂时无法提供与“56890-503”相匹配的价格&库存,您可以联系我们找货
