430139-513
430139-513
    LAIRD(莱尔德)
    PELTIER MOD HT3,12,F2,3030,TA,W6
430139-513 数据手册
ThermaTEC™ Series HT3-12-F2-3030 Thermoelectric Modules Note: This product has reached end of production and is available on a limited basis only. This product series has been replaced with the improved HiTemp ET Series product offering. Consider using ET3-12-F2-3030 HiTemp ET Series module as a replacement. The ThermaTEC™ Series of thermoelectric modules (TEMs) are designed to operate under cycling conditions or high temperature applications. This product line is available in multiple configurations and is ideal for applications that require both heating and cooling mode (reverse polarity) or power generation. Assembled with proprietary solder construction, Bismuth Telluride semiconductor material and thermally conductive Aluminum Oxide ceramics, the ThermaTEC Series is designed for higher current and larger heatpumping applications. Americas: +1.919.597.7300 Europe: +46.31.420530 Asia: +86.755.2714.1166 ets.sales@lairdtech.com www.lairdtech.com FEATURES • • • • • • Thermal cycling durability Power cycling reliability Precise temperature control Strong lead attachment RoHS compliant Continuous operation at high temperatures APPLICATIONS • Analytical instrumentation • PCR cyclers • Thermal test sockets • Electronic enclosure cooling • Chillers (liquid cooling) • Power generation SPECIFICATIONS TECHNICAL Hot Side Temperature (°C) Qmax (Watts) Delta Tmax (°C) Imax (Amps) Vmax (Volts) Module Resistance (Ohms) SUFFIX THICKNESS (PRIOR TO TINNING) 11 TA TB 25°C 24.7 63 2.9 14.5 4.65 0.126”±0.005” 0.126”±0.001” 0.126”±0.0005” 50°C 27.2 75 2.9 16.4 5.24 FLATNESS & PARALLELISM HOT FACE COLD FACE LEAD LENGTH 0.002” /0.0035” 0.001”/0.001” 0.0005”/0.0005” Lapped Lapped Lapped Lapped Lapped Lapped 6.0” 6.0” 6.0” SEALING OPTIONS SUFFIX SEALANT COLOR TEMP RANGE DESCRIPTION RT EP RTV Epoxy White Black -60 to 204 °C -55 to 150 °C Non-corrosive, silicone adhesive Low density syntactic foam epoxy encapsulant Page 1 of 3 HT3-12-F2-3030 THERMO Performance Curves at Th =25°C ELECTRIC Page 2 of 3 HT3-12-F2-3030 NOTES 1. Max operating temperature: 175°C 2. Do not exceed Imax or Vmax when operating module 3. Reference assembly guidelines for recommended installation LAIRD-ETS-HT3-12-F2-3030-DATA-SHEET-101416 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2016 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights. Page 3 of 3
430139-513 价格&库存
很抱歉,暂时无法提供与“430139-513”相匹配的价格&库存,您可以联系我们找货
