430820-501
430820-501
    LAIRD(莱尔德)
    PELTIER MOD HT4,7,F2,3030,TA,W6
430820-501 数据手册
ThermaTEC™ Series HT4-7-F2-3030 Thermoelectric Modules Note: This product has reached end of production and is available on a limited basis only. This product series has been replaced with the improved HiTemp ET Series product offering. Consider using ET4-7-F2-3030 HiTemp ET Series module as a replacement. The ThermaTEC™ Series of thermoelectric modules (TEMs) are designed to operate under cycling conditions or high temperature applications. This product line is available in multiple configurations and is ideal for applications that require both heating and cooling mode (reverse polarity) or power generation. Assembled with proprietary solder construction, Bismuth Telluride semiconductor material and thermally conductive Aluminum Oxide ceramics, the ThermaTEC Series is designed for higher current and larger heat-pumping applications. PERFORMANCE SPECIFICATIONS Hot Side Temperature (°C) Qmax (Watts) Delta Tmax (°C) Imax (Amps) Vmax (Volts) Module Resistance (Ohms) 11 TA TB THICKNESS (PRIOR TO TINNING) 0.161”± 0.005” 0.161”± 0.001” 0.161”± 0.0005” SEALING OPTION SUFFIX R E SEALANT RTV Epoxy APPLICATIONS Thermal cycling durability Power cycling reliability Precise temperature control Strong lead attachment RoHS compliant • Continuous operation at high temperatures • • • • • • • • • • • Americas: +1.919.597.7300 Europe: +46.31.420530 Asia: +86.755.2714.1166 ets.sales@lairdtech.com www.lairdtech.com SUFFIX FEATURES COLOR White Black 25°C 18.4 64 3.8 8.1 1.95 FLATNESS & PARALLELISM 0.002” / 0.0035” 0.001” / 0.001” 0.0005” / 0.0005” TEMP RANGE -60 to 204°C -55 to 150°C Analytical instrumentation PCR cyclers Thermal test sockets Electronic enclosure cooling Chillers (liquid cooling) Power generation 50°C 20.2 75 3.8 9.2 2.20 HOT FACE Lapped Lapped Lapped COLD FACE Lapped Lapped Lapped LEAD LENGTH 6.0” 6.0” 6.0” DESCRIPTION Non-corrosive, silicone adhesive sealant Low density syntactic foam epoxy encapsulant Page 1 of 2 HT4-7-F2-3030 Performance Curves at Th = 25°C THERMO ELECTRIC Ceramic Material: Alumina (AI2O3) Solder Construction: 271°C, Proprietary OPERATING TIPS • Max operating temperature: 175°C • Do not exceed Imax or Vmax when operating module • Reference assembly guidelines for recommended installation LAIRD-ETS-HT4-7-F2-3030-DATA-SHEET-101016 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2016 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights Page 2 of 2
430820-501 价格&库存
很抱歉,暂时无法提供与“430820-501”相匹配的价格&库存,您可以联系我们找货
