OptoTEC™ OT Series OT12-18-F2A-0606-GG-W2.25
MFG Part Number: 430779-502
Legacy Product
OptoTEC™ OT Series Thermoelectric Cooler
Features
Note: This product is not recommended for new designs.
This product series has been replaced with the OptoTEC™ OTX Series.
The recommended replacement is:
MFG Part Number: 387006656
Description: OTX12-18-F2A-0606-GG-W2.25
Applications
Miniature geometric sizes
Precise temperature control
Reliable solid-state operation
No sound or vibration
DC operation
RoHS-compliant
Thermoelectric Cooling for CMOS Sensors
Cooling Solutions for Autonomous Systems
Heads-Up Displays, Imaging Sensors
ELECTRICAL AND THERMAL PERFORMANCE
For maximum performance, be sure to orient the CONTROL side of the TEC against the application to be managed and the HEATSINK side against the heat sink or other heat
rejection method. The CONTROL side is always opposite the side with lead attachments. Lead attachment is a passive heat loss and less impactful if located on the side that attaches
to the heat exchanger.
Heat Pumped at Cold Side
Thot = 27 °C
Thot = 27 °C
1.60
1.60
1.40
1.40
1.20
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
1.00
0.80
0.60
Qc (Watts)
Qc (Watts)
1.20
0.80
0.60
0.40
0.40
0.20
0.20
0.00
0.00
0.20
0.40
0.60
0.80
1.00
1.20
0.00
0.00
1.40
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
1.00
Operating Current (Amps)
0.50
1.00
1.50
2.00
Operating Voltage (Volts)
Current vs Voltage (I vs V)
Thot = 27 °C
2.50
2.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
1.50
1.00
0.50
0.00
0.00
0.20
0.40
0.60
0.80
1.00
1.20
1.40
2.50
Legacy Product
Coefficient of Performance (COP = Qc/Pin)
Thot = 27 °C
6.00
6.00
5.00
5.00
3.00
3.00
2.00
2.00
1.00
1.00
0.00
0.00
0.20
0.40
0.60
0.80
1.00
1.20
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
4.00
COP
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
4.00
COP
Thot = 27 °C
0.00
0.00
1.40
0.50
4.50
4.50
4.00
4.00
3.50
3.50
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
3.00
2.50
2.00
1.00
0.50
0.50
0.80
1.00
1.20
0.00
0.00
1.40
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
2.00
1.00
0.60
2.50
2.50
1.50
0.40
2.00
3.00
1.50
0.20
1.50
Total Heat Dissipated at Hot Side (Qh=Qc+Pin)
Thot = 27 °C
Qh (Watts)
Qh (Watts)
Thot = 27 °C
0.00
0.00
1.00
0.50
1.00
1.50
2.00
2.50
Heat Pumped at Cold Side (Qc)
Thot = 27 °C | Current = 1.0 Amps
1.40
2.00
1.20
1.50
0.80
COP
Qc (Watts)
1.00
0.60
0.40
1.00
0.50
0.20
0.00
0.0
10.0
20.0
30.0
40.0
ΔT (°C)
50.0
60.0
70.0
0.00
0.0
10.0
20.0
30.0
40.0
ΔT (°C)
50.0
60.0
70.0
Legacy Product
SPECIFICATIONS*
Hot Side Temperature
27.0 °C
35.0 °C
50.0 °C
Qcmax (ΔT = 0)
1.3 Watts
1.4 Watts
1.5 Watts
ΔTmax (Qc = 0)
68.0°C
70.9°C
76.0°C
Imax (I @ ΔTmax)
1.2 Amps
1.2 Amps
1.2 Amps
Vmax (V @ ΔTmax)
1.9 Volts
2.0 Volts
2.1 Volts
Module Resistance
1.51 Ohms
1.57 Ohms
1.69 Ohms
Max Operating Temperature
80 °C
Weight
1.0 gram(s)
* Specifications reflect thermoelectric coefficients updated March 2020
FINISHING OPTIONS
Suffix
Thickness
Flatness / Parallelism
Hot Face
Cold Face
Lead Length
GG
3.023 ±0.127 mm
0.119 ± 0.0050 in
N/A / N/A
Au Plated
Au Plated
50.8 mm
2.00 in
SEALING OPTIONS
Suffix
Sealant
Color
Temp Range
None
Description
No sealing specified
NOTES
1.
2.
3.
4.
Max operating temperature: 80°C
Do not exceed Imax or Vmax when operating module
Reference assembly guidelines for recommended installation
Solder tinning also available on metallized ceramics
Any information furnished by Laird and its agents, whether in specifications, data sheets, product catalogues or otherwise, is believed to be (but is not warranted as
being) accurate and reliable, is provided for information only and does not form part of any contract with Laird. All specifications are subject to change without notice.
Laird assumes no responsibility and disclaims all liability for losses or damages resulting from use of or reliance on this information. All Laird products are sold
subject to the Laird Terms and Conditions of sale (including Laird’s limited warranty) in effect from time to time, a copy of which will be furnished upon request.
© Copyright 2019-2022 Laird Thermal Systems, Inc. All rights reserved. Laird™, the Laird Ring Logo, and Laird Thermal Systems™ are trademarks or registered
trademarks of Laird Limited or its subsidiaries.
OptoTEC™ is a trademark of Laird Thermal Systems, Inc. All other marks are owned by their respective owners.
Revision: 00 Date: 06-01-2022
Print Date: 06-15-2022
很抱歉,暂时无法提供与“430779-501”相匹配的价格&库存,您可以联系我们找货
