Multistage MS Series MS3-119-20-15-11-W8
MFG Part Number: 9360002-301
Multistage MS Series Thermoelectric Cooler
Features
The MS3-119-20-15-11-W8 multistage thermoelectric cooler is able to
reach colder temperatures than single stage thermoelectric coolers. It has
a maximum Qc of 14 Watts when ΔT = 0 and a maximum ΔT of 106 °C at
Qc = 0.
Applications
High temperature differential
Precise temperature control
Reliable solid-state operation
Environmentally-friendly
DC operation
RoHS-compliant
Thermoelectric Cooling for CMOS Sensors
Heads-Up Displays, Imaging Sensors
ELECTRICAL AND THERMAL PERFORMANCE
For maximum performance, be sure to orient the CONTROL side of the TEC against the application to be managed and the HEATSINK side against the heat sink or other heat
rejection method. The CONTROL side is always opposite the side with lead attachments. Lead attachment is a passive heat loss and less impactful if located on the side that attaches
to the heat exchanger.
Heat Pumped at Cold Side
Thot = 27 °C
Thot = 27 °C
20.00
20.00
15.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
10.00
Qc (Watts)
Qc (Watts)
15.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
10.00
5.00
5.00
0.00
0.00 1.00 2.00 3.00 4.00 5.00 6.00 7.00 8.00 9.00
0.00
Operating Current (Amps)
Operating Voltage (Volts)
Current vs Voltage (I vs V)
Thot = 27 °C
9.00
8.00
7.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
6.00
5.00
4.00
3.00
2.00
1.00
0.00
0.00
1.00
2.00
3.00
4.00
5.00
6.00
7.00
8.00
9.00
Coefficient of Performance (COP = Qc/Pin)
Thot = 27 °C
6.00
6.00
5.00
5.00
3.00
3.00
2.00
2.00
1.00
1.00
0.00
0.00
1.00
2.00
3.00
4.00
5.00
6.00
7.00
8.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
4.00
COP
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
4.00
COP
Thot = 27 °C
0.00
0.00
9.00
1.00
2.00
90.00
90.00
80.00
80.00
70.00
70.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
60.00
50.00
40.00
20.00
10.00
10.00
4.00
5.00
6.00
7.00
7.00
8.00
9.00
8.00
0.00
0.00
9.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
ΔT=40°C
ΔT=50°C
ΔT=60°C
40.00
20.00
3.00
6.00
50.00
30.00
2.00
5.00
60.00
30.00
1.00
4.00
Total Heat Dissipated at Hot Side (Qh=Qc+Pin)
Thot = 27 °C
Qh (Watts)
Qh (Watts)
Thot = 27 °C
0.00
0.00
3.00
1.00
2.00
3.00
4.00
5.00
6.00
7.00
8.00
9.00
Heat Pumped at Cold Side (Qc)
Thot = 27 °C | Current = 6.4 Amps
16.00
2.00
14.00
1.50
10.00
COP
Qc (Watts)
12.00
8.00
1.00
6.00
4.00
0.50
2.00
0.00
0.0
20.0
40.0
60.0
ΔT (°C)
80.0
100.0
120.0
0.00
0.0
20.0
40.0
60.0
ΔT (°C)
80.0
100.0
120.0
SPECIFICATIONS*
Hot Side Temperature
27.0 °C
Qcmax (ΔT = 0)
14.0 Watts
ΔTmax (Qc = 0)
106.0 °C
Imax (I @ ΔTmax)
8.1 Amps
Vmax (V @ ΔTmax)
7.6 Volts
Module Resistance
0.94 Ohms
Max Operating Temperature
80 °C
Weight
67.0 gram(s)
* Specifications reflect thermoelectric coefficients updated March 2020
FINISHING OPTIONS
Suffix
Thickness
Flatness / Parallelism
Hot Face
Cold Face
Lead Length
11
12.900 ±0.203 mm
0.508 ± 0.008 in
0.025 mm / 0.203 mm
0.001 in / 0.008 in
Lapped
Lapped
199.9 mm
7.87 in
SEALING OPTIONS
Suffix
Sealant
Color
None
Temp Range
Description
No sealing specified
NOTES
1.
2.
3.
4.
Max operating temperature: 80°C
Do not exceed Imax or Vmax when operating module
Reference assembly guidelines for recommended installation
Solder tinning also available on metallized ceramics
Any information furnished by Laird and its agents, whether in specifications, data sheets, product catalogues or otherwise, is believed to be (but is not warranted as
being) accurate and reliable, is provided for information only and does not form part of any contract with Laird. All specifications are subject to change without notice.
Laird assumes no responsibility and disclaims all liability for losses or damages resulting from use of or reliance on this information. All Laird products are sold
subject to the Laird Terms and Conditions of sale (including Laird’s limited warranty) in effect from time to time, a copy of which will be furnished upon request.
© Copyright 2019-2022 Laird Thermal Systems, Inc. All rights reserved. Laird™, the Laird Ring Logo, and Laird Thermal Systems™ are trademarks or registered
trademarks of Laird Limited or its subsidiaries.
Revision: 00 Date: 06-01-2022
Print Date: 06-14-2022
很抱歉,暂时无法提供与“9360002-301”相匹配的价格&库存,您可以联系我们找货
