430581-503
430581-503
    LAIRD(莱尔德)
    PELTIR ET20,30,F2A,0610,GG,W2.25
430581-503 数据手册
HiTemp ET Series ET20-30-F2A-0610-GG-W2.25 MFG Part Number: 430581-503 Legacy Product HiTemp ET Series Thermoelectric Cooler Features ● Note: This product is not recommended for new designs. This product series has been replaced with the HiTemp ETX Series. The recommended replacement is: MFG Part Number: 387006913 Description: OTX20-30-F2A-0610-GG-W2.25 ● ● ● ● Applications High-temperature operation Reliable solid-state No sound or vibration Environmentally-friendly RoHS-compliant Peltier Cooling for Refrigerated Centrifuges Peltier Cooling for Machine Vision Thermoelectric Cooling for CMOS Sensors Cooling Solutions for Autonomous Systems Peltier Cooling for Digital Light Processors ● ● ● ● ● ● ELECTRICAL AND THERMAL PERFORMANCE For maximum performance, be sure to orient the CONTROL side of the TEC against the application to be managed and the HEATSINK side against the heat sink or other heat rejection method. The CONTROL side is always opposite the side with lead attachments. Lead attachment is a passive heat loss and less impactful if located on the side that attaches to the heat exchanger. Heat Pumped at Cold Side Thot = 85 °C 5.00 5.00 4.00 4.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 3.00 2.00 Qc (Watts) Qc (Watts) Heat Pumped at Cold Side Thot = 85 °C 1.00 0.00 0.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 3.00 2.00 1.00 0.50 1.00 1.50 2.00 0.00 0.00 2.50 1.00 Operating Current (Amps) 2.00 3.00 4.00 Operating Voltage (Volts) Operating Voltage (Volts) Current vs Voltage (I vs V) Thot = 85 °C 5.00 4.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 3.00 2.00 1.00 0.00 0.00 0.50 1.00 1.50 Operating Current (Amps) 2.00 2.50 5.00 HiTemp ET Series ET20-30-F2A-0610-GG-W2.25 MFG Part Number: 430581-503 Legacy Product Coefficient of Performance (COP = Qc/Pin) Thot = 85 °C 6.00 6.00 5.00 5.00 3.00 3.00 2.00 2.00 1.00 1.00 0.00 0.00 0.50 1.00 1.50 2.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 4.00 COP ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 4.00 COP Coefficient of Performance (COP = Qc/Pin) Thot = 85 °C 0.00 0.00 2.50 1.00 2.00 Operating Current (Amps) Total Heat Dissipated at Hot Side (Qh=Qc+Pin) Thot = 85 °C 4.00 5.00 Total Heat Dissipated at Hot Side (Qh=Qc+Pin) Thot = 85 °C 16.00 16.00 14.00 14.00 12.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 10.00 8.00 6.00 Qh (Watts) 12.00 Qh (Watts) 3.00 Operating Voltage (Volts) 8.00 6.00 4.00 4.00 2.00 2.00 0.00 0.00 0.50 1.00 1.50 2.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 10.00 0.00 0.00 2.50 1.00 Operating Current (Amps) 2.00 3.00 4.00 5.00 Operating Voltage (Volts) Heat Pumped at Cold Side (Qc) Thot = 85 °C | Current = 1.6 Amps Coefficient of Performance (COP = Qc/Pin) Thot = 85 °C | Current = 1.6 Amps 4.50 2.00 4.00 1.50 3.00 2.50 COP Qc (Watts) 3.50 2.00 1.00 1.50 0.50 1.00 0.50 0.00 0.0 10.0 20.0 30.0 40.0 50.0 ΔT (°C) 60.0 70.0 80.0 90.0 0.00 0.0 10.0 20.0 30.0 40.0 50.0 ΔT (°C) 60.0 70.0 80.0 90.0 HiTemp ET Series ET20-30-F2A-0610-GG-W2.25 MFG Part Number: 430581-503 Legacy Product SPECIFICATIONS* Hot Side Temperature 50.0 °C 85.0 °C 110.0 °C Qcmax (ΔT = 0) 4.2 Watts 4.6 Watts 4.8 Watts ΔTmax (Qc = 0) 77.9°C 89.3°C 96.2°C Imax (I @ ΔTmax) 2.0 Amps 1.9 Amps 1.9 Amps Vmax (V @ ΔTmax) 3.6 Volts 4.1 Volts 4.5 Volts Module Resistance 1.69 Ohms 1.96 Ohms 2.15 Ohms Max Operating Temperature 150 °C Weight 1.0 gram(s) * Specifications reflect thermoelectric coefficients updated March 2020 FINISHING OPTIONS Suffix Thickness Flatness / Parallelism Hot Face Cold Face Lead Length GG 2.130 ±0.127 mm 0.084 ± 0.0050 in N/A / N/A Au Plated Au Plated 50.8 mm 2.00 in SEALING OPTIONS Suffix Sealant Color None Temp Range Description No sealing specified NOTES 1. 2. 3. Max operating temperature: 150°C Do not exceed Imax or Vmax when operating module Reference assembly guidelines for recommended installation Any information furnished by Laird and its agents, whether in specifications, data sheets, product catalogues or otherwise, is believed to be (but is not warranted as being) accurate and reliable, is provided for information only and does not form part of any contract with Laird. All specifications are subject to change without notice. Laird assumes no responsibility and disclaims all liability for losses or damages resulting from use of or reliance on this information. All Laird products are sold subject to the Laird Terms and Conditions of sale (including Laird’s limited warranty) in effect from time to time, a copy of which will be furnished upon request. © Copyright 2019-2022 Laird Thermal Systems, Inc. All rights reserved. Laird™, the Laird Ring Logo, and Laird Thermal Systems™ are trademarks or registered trademarks of Laird Limited or its subsidiaries. Revision: 00 Date: 06-01-2022 Print Date: 06-15-2022
430581-503 价格&库存
很抱歉,暂时无法提供与“430581-503”相匹配的价格&库存,您可以联系我们找货
