71049-501
71049-501
    LAIRD(莱尔德)
    PELTIER SH10,95,06,L,W4.5
71049-501 数据手册
Annular SH Series SH10-95-06-L-W4.5 MFG Part Number: 71049-501 Annular SH Series Thermoelectric Cooler Features ● The SH10-95-06-L-W4.5 is an annular-style thermoelectric cooler. The hot and cold side ceramics have a circular hole in the center to accommodate light protrusion for optics, mechanical fastening or temperature probe. It has a maximum Qc of 19.1 Watts when ΔT = 0 and a maximum ΔT of 70.5 °C at Qc = 0. ● ● ● ● ● Applications Center Hole Precise Temperature Control No sound or vibration Reliable solid-state DC Operation RoHS-compliant ● ● ● ● ● Thermoelectric Coolers for Reagent Storage Thermoelectric Coolers for Handheld Cosmetic Lasers Cooling for Centrifuges Heads-Up Displays, Imaging Sensors Peltier Cooling for Machine Vision ELECTRICAL AND THERMAL PERFORMANCE For maximum performance, be sure to orient the CONTROL side of the TEC against the application to be managed and the HEATSINK side against the heat sink or other heat rejection method. The CONTROL side is always opposite the side with lead attachments. Lead attachment is a passive heat loss and less impactful if located on the side that attaches to the heat exchanger. Heat Pumped at Cold Side Thot = 27 °C 25.00 25.00 20.00 20.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 15.00 10.00 Qc (Watts) Qc (Watts) Heat Pumped at Cold Side Thot = 27 °C 5.00 0.00 0.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 15.00 10.00 5.00 0.50 1.00 1.50 2.00 2.50 3.00 3.50 0.00 0.00 4.00 Operating Current (Amps) 2.00 4.00 6.00 8.00 10.00 12.00 Operating Voltage (Volts) Operating Voltage (Volts) Current vs Voltage (I vs V) Thot = 27 °C 14.00 12.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 10.00 8.00 6.00 4.00 2.00 0.00 0.00 0.50 1.00 1.50 2.00 2.50 Operating Current (Amps) 3.00 3.50 4.00 14.00 Annular SH Series SH10-95-06-L-W4.5 MFG Part Number: 71049-501 Coefficient of Performance (COP = Qc/Pin) Thot = 27 °C 6.00 6.00 5.00 5.00 3.00 3.00 2.00 2.00 1.00 1.00 0.00 0.00 0.50 1.00 1.50 2.00 2.50 3.00 3.50 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 4.00 COP ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 4.00 COP Coefficient of Performance (COP = Qc/Pin) Thot = 27 °C 0.00 0.00 4.00 2.00 Operating Current (Amps) 70.00 60.00 60.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 40.00 30.00 10.00 10.00 2.50 3.00 3.50 0.00 0.00 4.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 2.00 Operating Current (Amps) 6.00 8.00 10.00 12.00 14.00 Coefficient of Performance (COP = Qc/Pin) Thot = 27 °C | Current = 2.6 Amps 20.00 2.00 15.00 1.50 COP Qc (Watts) 4.00 Operating Voltage (Volts) Heat Pumped at Cold Side (Qc) Thot = 27 °C | Current = 2.6 Amps 10.00 5.00 0.00 0.0 14.00 30.00 20.00 2.00 12.00 40.00 20.00 1.50 10.00 50.00 Qh (Watts) Qh (Watts) 50.00 1.00 8.00 Total Heat Dissipated at Hot Side (Qh=Qc+Pin) Thot = 27 °C 70.00 0.50 6.00 Operating Voltage (Volts) Total Heat Dissipated at Hot Side (Qh=Qc+Pin) Thot = 27 °C 0.00 0.00 4.00 1.00 0.50 10.0 20.0 30.0 40.0 ΔT (°C) 50.0 60.0 70.0 80.0 0.00 0.0 10.0 20.0 30.0 40.0 ΔT (°C) 50.0 60.0 70.0 80.0 Annular SH Series SH10-95-06-L-W4.5 MFG Part Number: 71049-501 SPECIFICATIONS* Hot Side Temperature 27.0 °C 35.0 °C 50.0 °C Qcmax (ΔT = 0) 19.1 Watts 19.6 Watts 20.7 Watts ΔTmax (Qc = 0) 70.5°C 73.5°C 78.8°C Imax (I @ ΔTmax) 3.1 Amps 3.1 Amps 3.0 Amps Vmax (V @ ΔTmax) 10.4 Volts 10.8 Volts 11.5 Volts Module Resistance 3.14 Ohms 3.27 Ohms 3.51 Ohms Max Operating Temperature 80 °C Weight 9.0 gram(s) * Specifications reflect thermoelectric coefficients updated March 2020 FINISHING OPTIONS Suffix Thickness Flatness / Parallelism Hot Face Cold Face Lead Length L 3.581 ±0.254 mm 0.141 ± 0.0100 in 0.004 mm / 0.004 mm 0.00015 in / 0.00015 in Lapped Lapped 114.3 mm 4.50 in SEALING OPTIONS Suffix Sealant Color None Temp Range Description No sealing specified NOTES 1. 2. 3. 4. Max operating temperature: 80°C Do not exceed Imax or Vmax when operating module Reference assembly guidelines for recommended installation Solder tinning also available on metallized ceramics Any information furnished by Laird and its agents, whether in specifications, data sheets, product catalogues or otherwise, is believed to be (but is not warranted as being) accurate and reliable, is provided for information only and does not form part of any contract with Laird. All specifications are subject to change without notice. Laird assumes no responsibility and disclaims all liability for losses or damages resulting from use of or reliance on this information. All Laird products are sold subject to the Laird Terms and Conditions of sale (including Laird’s limited warranty) in effect from time to time, a copy of which will be furnished upon request. © Copyright 2019-2022 Laird Thermal Systems, Inc. All rights reserved. Laird™, the Laird Ring Logo, and Laird Thermal Systems™ are trademarks or registered trademarks of Laird Limited or its subsidiaries. Revision: 00 Date: 06-01-2022 Print Date: 06-13-2022
71049-501 价格&库存
很抱歉,暂时无法提供与“71049-501”相匹配的价格&库存,您可以联系我们找货
