Technical Data Sheet for NL2022T
Thermoelectric Module
NOMINAL PERFORMANCE IN NITROGEN
Hot Side Temperature (°C)
Δ Tmax (°C):
Qmax (watts):
Imax (amps):
Vmax (vdc):
AC Resistance (ohms):
PRODUCT FEATURES
27
78
0.39
1.4
0.8
0.56
50
89
0.44
1.4
1.0
ORDERING OPTIONS
RoHS EU Compliant
Pretinned metallized ceramic surface(s) with 117°C solder.
Thermistor mounted on edge of cold side ceramic.
(Calibration available.)
Elevated temperature burn-in with test data provided.
Model Number
NL2022T-01
NL2022T-02
NL2022T-03
Description
Both Surfaces are Metallized
Hot Side Exterior is Metallized
No Metallization
OPERATION CAUTIONS
INSTALLATION
For maximum reliability, storage and operation below
85°C in a non-condensing environment is recommended.
To minimize thermal stress, use linear/proportional
temperature control or a similar method rather than an
ON/OFF method.
Recommended mounting methods: Bonding with thermal
epoxy or soldering with metallized ceramics. For additional
information, please refer to our TEM Installation Guide.
II-VI Marlow – Dallas, TX USA
214-340-4900
877-627-5691
marlow.sales@ii-vi.com
Marlow Industries Europe
GmbH - Germany
+49 (0) 6150 5439 - 403
info@marlow-europe.eu
II-VI Japan Inc.
81 43 297 2693 (tel)
center@ii-vi.co.jp
www.ii-vi.co.jp
MI Form 005-0808 Rev. B
www.marlow.com
II-VI Singapore Pte., Ltd.
(65) 6481 8215 (tel)
info@ii-vi.com.sg
Marlow Industries China, II-VI
Technologies Beijing
86-10-643 98226
info@iivibj.com
DOC # 102-0302 REV G - PAGE 1 OF 3
Hot Side Temperature 50°C
Hot Side Temperature 27°C
HEAT
LOAD
(WATTS)
0.00
0.05
0.10
0.15
0.20
0.25
0.30
0.35
60.0
40.0
20.0
80.0
60.0
40.0
20.0
0.0
0.0
1.0
1.0
VOLTAGE (VDC)
T (C)
80.0
100.0
T (C)
100.0
VOLTAGE (VDC)
TYPICAL PERFORMANCE CURVES
ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN
0.8
0.6
0.4
0.2
0.0
0.0
Q=0
T=0
0.4
0.8
1.2
CURRENT (AMPS)
0.8
0.6
0.4
Q=0
T=0
0.2
0.0
0.0
1.6
HEAT
LOAD
(WATTS)
0.00
0.05
0.10
0.15
0.20
0.25
0.30
0.35
0.40
0.4
0.8
1.2
CURRENT (AMPS)
1.6
MECHANICAL CHARACTERISTICS
For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691.
Positive Lead
.156
[3.96]
.125
[3.18]
Leads: 28 AWG (0.32) Bus
Solid Tinned Copper
Negative Lead
.125
[3.18]
2.00 +/-.25
[50.80+/-6.35]
.156
[3.96]
Cold Side
.003 [0.08]
A
.001 [0.03]
Parallelism
Flatness
.149+/-.007
[3.78 +/-0.18]
.001 [0.03]
Ceramics: Aluminum oxide (AC)
Dimensions in inches and [mm].
A
All units are in inches and [ ] are in millimeters unless otherwise stated.
For customer support or general questions please contact a local office or visit our website at www.marlow.com.
Marlow reserves the right to make product changes without notice.
www.marlow.com
DOC # 102-0302 REV G - PAGE 2 OF 3
www.marlow.com
DOC # 102-0302 REV G - PAGE 3 OF 3
很抱歉,暂时无法提供与“NL2022T-01AC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+344.927311+44.60192
