RC3-4-01LS
RC3-4-01LS
    MARLOWINDUSTRIES,INC.
    Module
    TEM16X16X3.33MM
RC3-4-01LS 数据手册
  Technical Data Sheet for RC3‐4  Single‐Stage Thermoelectric Module      NOMINAL PERFORMANCE IN NITROGEN      Hot Side Temperature (°C)  Δ Tmax (°C):  Qmax (watts):  Imax (amps):  Vmax (vdc):  AC Resistance (ohms):  Device ZT  27  65  9  3.7  3.6  0.8  0.74  50  73  10  3.7  4.1  ‐‐  ‐‐      PRODUCT FEATURES          ORDERING OPTIONS      RoHS EU Compliant  Rated operating temperature of 130°C.  Ceramic Material:  Aluminum Oxide  Porch configuration for high strength lead wire connection.  Superior nickel diffusion barriers on elements.  High strength for rugged environment.  RTV sealing option available.  Lapped option available for multiple module applications.  Model Number  RC3‐4‐01  RC3‐4‐01L  RC3‐4‐01S  RC3‐4‐01LS  RC3‐4‐03LS      OPERATION CAUTIONS    For maximum reliability, storage and operation below  130°C in a non‐condensing environment is recommended.   To minimize thermal stress, use linear/proportional  temperature control or a similar method rather than an  ON/OFF method.      Description  20 AWG 101mm Leadwires  20 AWG 101mm Leadwires, Lapped  20 AWG 101mm Leadwires, Sealed  20 AWG 101mm Leadwires,  Lapped, Sealed  24 AWG 165mm Leadwires,  Lapped, Sealed      INSTALLATION    Recommended mounting method:  Clamp with uniform  pressure to a flat surface with thermal interface material.  For  additional information, please refer to our TEM Installation  Guide.        II‐VI Marlow – Dallas, TX USA  214‐340‐4900  877‐627‐5691  marlow.sales@ii‐vi.com  Marlow Industries Europe  GmbH ‐ Germany  +49 (0) 6150 5439 ‐ 403  info@marlow‐europe.eu  II‐VI Japan Inc.   81 43 297 2693 (tel)  center@ii‐vi.co.jp  www.ii‐vi.co.jp  MI Form 005‐0690 Rev. 4  Marlow Industries China, II‐VI  Technologies Beijing  86‐10‐643 98226  info@iivibj.com  DOC # 102‐0281 REV G ‐ PAGE 1 OF 3  www.marlow.com    II‐VI Singapore Pte., Ltd.   (65) 6481 8215 (tel)  info@ii‐vi.com.sg        ENVIRONMENT:  ONE ATMOSPHERE DRY NITROGEN  ENVIRONMENT:  ONE ATMOSPHERE DRY NITROGEN    Hot Side Temperature 27°C 40.0 1.00 2.00 3.00 VOLTAGE (VDC) 40.0 0.0 4.0 4.0 3.0 2.0 Q=0 T=0 2.0 3.0 CURRENT (AMPS) 4.0 5.00 6.00 0.0 1.0 3.00 20.0 5.00 6.00 1.0 7.00 9.00 3.0 2.0 Q=0 T=0 1.0 0.0 0.0 5.0 1.0 2.0 3.0 CURRENT (AMPS) 4.0 5.0   For performance information with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877‐627‐5691.    POWER GENERATION PERFORMANCE CURVES  ENVIRONMENT:  ONE ATMOSPHERE DRY NITROGEN    Cold Side Temperature 27°C Cold Side Temperature 50°C Hot Side Temperature (°C) Hot Side Temperature (°C) 40 45 50 55 Tc=27°C 0.3 1.3 2.3 3.3 Heat (W) 65 75 85 0.5 0.45 0.4 0.35 0.3 0.25 0.2 0.15 0.1 Power Voltage 0.05 0 4.3 5.3 Opt Power (W) 35 Opt Voltage (V) 30 0.2 0.18 0.16 0.14 0.12 0.1 0.08 0.06 0.04 0.02 0 Efficiency 1 2 3 4 5 6 7 Load Resistance Ratio 8 65 70 75 80 85 0.3 0.25 0.2 0.15 0.1 0.05 Power 1.0 1.5 2.0 2.5 Heat (W) Hot Side Temperature (°C)  Cold Side Temperature (°C)  Optimum Efficiency, η (%)  Optimum Power (W)  Optimum Voltage (V)  Load Resistance for Opt η (Ω)  Open Circuit Voltage, VOC (V)  Short Circuit Current (A)  Thermal Resistance (°C/W)  Voltage / VOC η / Opt η 0 1 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 Voltage 0.1 0 9 10 60 Tc=50°C 0.5 Normalized Off-Peak Performance 1 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 0.1 0.09 0.08 0.07 0.06 0.05 0.04 0.03 0.02 0.01 0 55 Opt Voltage (V) Hot Side Temperature (°C) Opt Power (W) TYPICAL PERFORMANCE CURVES  1.00 2.00 4.00 4.00 20.0 HEAT LOAD (WATTS 0.00 60.0 T (C) 60.0 HEAT LOAD (WATTS) 0.00 0.0 0.0 Hot Side Temperature 50°C 80.0 VOLTAGE (VDC) T (C) 80.0 3.0 Voltage 0 3.5   85  27  2.45  0.149  0.435  1.27  0.77  0.79  9.53  55  27  1.24  0.036  0.208  1.18  0.37  0.41  9.54  35  27  0.36  0.003  0.059  1.13  0.10  0.12  9.52      For performance information with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877‐627‐5691.      MI Form 005‐0690 Rev. 4  DOC # 102‐0281 REV G ‐ PAGE 2 OF 3  www.marlow.com    MECHANICAL CHARACTERISTICS      All units are in millimeters unless otherwise stated.    *NOTE: Cold side, hot side, positive lead, and negative lead are valid only for thermoelectric cooling. For power generation, refer to figure below:     For customer support or general questions please contact a local office or visit our website at www.marlow.com.   Marlow reserves the right to make product changes without notice.    MI Form 005‐0690 Rev. 4  DOC # 102‐0281 REV G ‐ PAGE 3 OF 3  www.marlow.com
RC3-4-01LS 价格&库存
很抱歉,暂时无法提供与“RC3-4-01LS”相匹配的价格&库存,您可以联系我们找货
