RC6-6-01LS
RC6-6-01LS
    MARLOWINDUSTRIES,INC.
    TEM30X30X3.91MM
RC6-6-01LS 数据手册
Technical Data Sheet for RC6-6 Single-Stage Thermoelectric Module NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): PRODUCT FEATURES • • • • • • • • 27 66 30 5.6 8.2 1.2 50 73 33 5.6 9.2 --- ORDERING OPTIONS RoHS EU Compliant Rated operating temperature of 130°C. Ceramic Material: Aluminum Oxide. Superior nickel diffusion barriers on elements. High strength for rugged environment. Porch configuration for high strength leadwires connection. RTV sealing option available. Lapped option available for multiple module applications. Model Number RC6-6-01 RC6-6-01L RC6-6-01S RC6-6-01LS Description Leadwires Leadwires, Lapped Leadwires, Sealed Leadwires, Lapped, Sealed OPERATION CAUTIONS INSTALLATION For maximum reliability, storage and operation below 130°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Recommended mounting method: Clamp with uniform pressure to a flat surface with thermal interface material. For additional information, please refer to our TEM Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0690 Rev. 4 www.marlow.com II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0288 REV H - PAGE 1 OF 2 Hot Side Temperature 27°C 60.0 40.0 T (C) Hot Side Temperature 50°C HEAT LOAD (WATTS) 0.00 2.50 5.00 7.50 10.0 12.5 15.0 17.5 20.0 22.5 25.0 27.5 20.0 0.0 HEAT LOAD (WATTS) 80.0 0.00 2.50 5.00 7.50 10.0 12.5 15.0 17.5 20.0 22.5 25.0 27.5 30.0 60.0 40.0 T (C) 80.0 20.0 0.0 8.0 10.0 6.0 4.0 Q=0 T=0 2.0 0.0 0.0 VOLTAGE (VDC) VOLTAGE (VDC) TYPICAL PERFORMANCE CURVES ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN 8.0 6.0 4.0 Q=0 2.0 1.0 2.0 3.0 4.0 5.0 CURRENT (AMPS) 6.0 7.0 0.0 0.0 T=0 1.0 2.0 3.0 4.0 5.0 CURRENT (AMPS) 6.0 7.0 MECHANICAL CHARACTERISTICS For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691. All units are in millimeters unless otherwise stated. For customer support or general questions please contact a local office or visit our website at www.marlow.com. Marlow reserves the right to make product changes without notice. MI Form 005-0690 Rev. 4 www.marlow.com DOC # 102-0288 REV H - PAGE 2 OF 2
RC6-6-01LS 价格&库存
很抱歉,暂时无法提供与“RC6-6-01LS”相匹配的价格&库存,您可以联系我们找货
RC6-6-01LS
  • 1+357.228781+46.23955
  • 5+335.578815+43.43718
  • 10+326.6801410+42.28534
  • 25+315.2788625+40.80957
  • 60+304.7611260+39.44815
  • 120+296.68341120+38.40258
库存:2405
