Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 12
SERIES: CP85H | DESCRIPTION: PELTIER MODULE
FEATURES
• arcTEC™ structure on select models
• enhanced reliability for high thermal cycling
• superior thermal performance
• silicon sealed
• wide ΔT max
• low profile
• precise temperature control
• solid state construction
MODEL
input
voltage1
input
current2
internal
resistance3
max
(Vdc)
max
(A)
typ
(Ω±10%)
Th=27°C
(W)
Th=50°C
(W)
Th=27°C
(°C)
Th=50°C
(°C)
CP85134H
2.1
8.5
0.2
10.3
11.3
70
77
CP85153034H
4.2
8.5
0.47
21
23
70
77
CP85234H
3.8
8.5
0.35
18.8
20.8
70
77
CP852040345H6
7.6
8.5
0.75
38.2
42
70
77
CP85301534H
4.2
8.5
0.4
CP853345H6
8.8
8.5
0.85
CP8530345
11.8
8.5
CP854020345H6
7.6
8.5
CP854345H
15.7
8.5
1.5
6
6
Notes:
output
Qmax4
output
∆Tmax5
21
23
70
77
43.1
48
70
77
1.15
57.7
63.4
70
77
0.75
38.2
42
70
77
77.1
85
70
77
7
1. Maximum voltage at ΔT max and Th=27°C
2. Maximum current to achieve ΔT max
3. Measured by AC 4-terminal method at 25°C
4. Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C
5. Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa)
6. Designed with arcTEC™ structure.
7. Internal resistance tolerance is ±12.5%
cuidevices.com
Product Page
3D Model
CUI DEVICES | SERIES: CP85H | DESCRIPTION: PELTIER MODULE
date 08/05/2022 | page 2 of 12
SPECIFICATIONS
parameter
conditions/description
min
solder melting temperature
connection between thermoelectric pairs
235
typ
max
°C
assembly compression
1
RoHS
units
MPa
yes
MECHANICAL DRAWING
units: mm
MATERIAL
HOT SIDE
0.05
THICKNESS
COLD SIDE
0.05
ceramic plate
96% AL2O3
wire leads
20 AWG
sealer
silicon rubber 703 RTV (between cold and
hot side plates)
joint cover
marking
P/N & S/N printed on cold side surface
10.0 3.0
Red (+)
WIDTH
COLD SIDE
Black (-)
LENGTH
100.0 5.0
MODEL NO.
LENGTH
(mm)
WIDTH
(mm)
THICKNESS
(mm)
CP85134H
15 ±0.3
15 ±0.3
3.4 ±0.025
CP85153034H
15 ±0.3
30 ±0.3
3.4 ±0.025
CP85234H
20 ±0.3
20 ±0.3
3.4 ±0.025
CP852040345H
20 ±0.3
40 ±0.3
3.45 ±0.025
CP85301534H
30 ±0.3
15 ±0.3
3.4 ±0.025
CP853345H
30 ±0.3
30 ±0.3
3.45 ±0.025
CP8530345
30 ±0.3
30 ±0.3
3.45 ±0.025
CP854020345H
40 ±0.3
20 ±0.3
3.45 ±0.025
CP854345H
40 ±0.3
40 ±0.3
3.45 ±0.025
cuidevices.com
PLATING
tin
Product Page
3D Model
date 08/05/2022 | page 3 of 12
Input Voltage (V)
CP85134H PERFORMANCE (Th=27°C)
8.5 A
2.0
6.8 A
5.1 A
3.4 A
1.0
1.7 A
Heat Pumped, Q (W)
8.5
A
5.1
A
6.8
A
3.4 A
4.0
1.7 A
70
60
50
40
30
ΔT=Th-Tc (°C)
CP85134H PERFORMANCE (Th=50°C)
Input Voltage (V)
8.5 A
6.8 A
2.0
5.1 A
3.4 A
1.0
1.7 A
A
A
6.8
Heat Pumped, Q (W)
8.5
5.1
8.0
A
3.4 A
4.0
1.7 A
70
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 4 of 12
Input Voltage (V)
CP85153034H PERFORMANCE (Th=27°C)
8.0
6.0
8.5 A
4.0
6.8 A
5.1 A
3.4 A
2.0
1.7 A
Heat Pumped, Q (W)
8.5 A
18
5.1 A
12
3.4 A
6.0
6.8 A
1.7 A
70
60
50
40
ΔT=Th-Tc (°C)
30
10
Input Voltage (V)
CP85153034H PERFORMANCE (Th=50°C)
8.0
6.0
4.0
8.5 A
6.8 A
5.1 A
3.4 A
2.0
1.7 A
Heat Pumped, Q (W)
8.5 A 6.8 A
18
5.1 A
12
1.7 A
6.0
3.4 A
70
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 5 of 12
Input Voltage (V)
CP85234H PERFORMANCE (Th=27°C)
8.5 A
4.0
6.8 A
5.1 A
3.4 A
2.0
1.7 A
Heat Pumped, Q (W)
6.8 A
A
8.5
16
5.1
A
3.4 A
8.0
1.7 A
70
60
50
40
30
ΔT=Th-Tc (°C)
CP85234H PERFORMANCE (Th=50°C)
Input Voltage (V)
8.5 A
4.0
6.8 A
5.1 A
3.4 A
2.0
1.7 A
Heat Pumped, Q (W)
8.5
A
A
6.8
A
5.1
16
3.4 A
8.0
1.7 A
70
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 6 of 12
Input Voltage (V)
CP852040345H PERFORMANCE (Th=27°C)
8.0
8.5 A
6.8 A
6.0
5.1 A
4.0
3.4 A
1.7 A
2.0
Heat Pumped, Q (W)
8.5 A
6.8 A
30
5.1 A
3.4 A
1.7 A
10
60
50
40
ΔT=Th-Tc (°C)
30
Input Voltage (V)
CP852040345H PERFORMANCE (Th=50°C)
8.0
8.5A
6.8A
5.1A
6.0
3.4A
4.0
1.7A
2.0
Heat Pumped, Q (W)
8.5A
40
6.8A
5.1A
30
3.4A
1.7A
10
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 7 of 12
CP85301534H PERFORMANCE (Th=27°C)
Input Voltage (V)
8.0
6.0
8.5 A
4.0
6.8 A
5.1 A
3.4 A
2.0
1.7 A
Heat Pumped, Q (W)
8.5 A
6.8 A
5.1 A
18
12
3.4 A
6.0
1.7 A
60
50
40
ΔT=Th-Tc (°C)
30
10
Input Voltage (V)
CP85301534H PERFORMANCE (Th=50°C)
8.0
6.0
4.0
8.5 A
6.8 A
5.1 A
3.4 A
2.0
1.7 A
Heat Pumped, Q (W)
8.5 A
6.8 A
18
5.1 A
3.4 A
12
1.7 A
6.0
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 8 of 12
Input Voltage (V)
CP853345H PERFORMANCE (Th=27°C)
8.5 A
8.0
6.8 A
5.1 A
3.4 A
4.0
1.7 A
Heat Pumped, Q (W)
40
6.8
A
5.1
30
A
A
3.4 A
1.7 A
10
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP853345H PERFORMANCE (Th=50°C)
8.0
8.5 A
6.8 A
5.1 A
3.4 A
4.0
1.7 A
6.8
Heat Pumped, Q (W)
40
A
A
5.1
30
A
3.4 A
1.7 A
10
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 9 of 12
Input Voltage (V)
CP8530345 PERFORMANCE (Th=27°C)
15
8.5 A
6.8 A
10
5.1 A
3.4 A
5
1.7 A
Heat Pumped, Q (W)
8.5 A
6.8 A
A
5.14
40
3.4 A
1.7 A
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP8530345 PERFORMANCE (Th=50°C)
15
8.5 A
6.8 A
10
5.1 A
3.4 A
5
1.7 A
Heat Pumped, Q (W)
8.5 A
6.8 A
A
5.14
60
40
3.4 A
1.7 A
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 10 of 12
Input Voltage (V)
CP854020345H PERFORMANCE (Th=27°C)
8.0
8.5 A
6.8 A
6.0
5.1 A
4.0
3.4 A
1.7 A
2.0
Heat Pumped, Q (W)
8.5 A
6.8 A
30
5.1 A
3.4 A
1.7 A
10
60
50
40
ΔT=Th-Tc (°C)
30
Input Voltage (V)
CP854020345H PERFORMANCE (Th=50°C)
8.0
8.5 A
6.8 A
5.1 A
6.0
3.4 A
4.0
1.7 A
2.0
Heat Pumped, Q (W)
8.5 A
40
6.8 A
5.1 A
30
3.4 A
1.7 A
10
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 11 of 12
Input Voltage (V)
CP854345H PERFORMANCE (Th=27°C)
8.5 A
16
6.8 A
5.1 A
8.0
3.4 A
1.7 A
Heat Pumped, Q (W)
80
8.5
60
6.8
A
5.1
A
A
3.4
40
A
1.7 A
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP854345H PERFORMANCE (Th=50°C)
8.5 A
16
6.8 A
5.1 A
3.4 A
8.0
1.7 A
Heat Pumped, Q (W)
80
6.8
A
A
A
5.1
60
3.4
40
A
1.7 A
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 12 of 12
REVISION HISTORY
rev.
description
date
1.0
initial release
09/08/2016
1.01
updated datasheet
09/25/2017
1.02
added new models
05/21/2018
1.03
added model CP8530345, brand update
10/18/2019
1.04
logo, datasheet style update
08/05/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CP854345H”相匹配的价格&库存,您可以联系我们找货
