Technical Data Sheet for CM30-1.9
Commercial Module for CATV & SLED Applications
NOMINAL PERFORMANCE IN NITROGEN
Hot Side Temperature (°C)
Δ Tmax (°C):
Qmax (watts):
Imax (amps):
Vmax (vdc):
AC Resistance (ohms):
PRODUCT FEATURES
27
71
4.5
1.9
3.6
1.6
50
92
5.4
1.8
4.5
ORDERING OPTIONS
RoHS EU Compliant
Ceramic Material: Aluminum Oxide
Au flash exterior, suitable for soldering.
Maximum process temperature is 220°C.
Porch configuration for high strength leadwire connection.
Model Number
CM30-1.9-01AC
Description
Metallized Exterior
OPERATION CAUTIONS
INSTALLATION
For maximum reliability, storage and operation below
130°C in a non-condensing environment is recommended.
To minimize thermal stress, use linear/proportional
temperature control or a similar method rather than an
ON/OFF method.
Recommended mounting methods: Bonding with thermal
epoxy or soldering with metallized ceramics. For additional
information, please refer to our TEC Installation Guide.
II-VI Marlow – Dallas, TX USA
214-340-4900
877-627-5691
marlow.sales@ii-vi.com
Marlow Industries Europe
GmbH - Germany
+49 (0) 6150 5439 - 403
info@marlow-europe.eu
II-VI Japan Inc.
81 43 297 2693 (tel)
center@ii-vi.co.jp
www.ii-vi.co.jp
MI Form 005-0808 Rev. A
II-VI Singapore Pte., Ltd.
(65) 6481 8215 (tel)
info@ii-vi.com.sg
Marlow Industries China, II-VI
Technologies Beijing
86-10-643 98226
info@iivibj.com
DOC # 102-0354 REV B- PAGE 1 OF 2
www.marlow.com
TA = Temperature
85°C - Vacuum
Hot Side
50°C
TASide
= 27°C
- Vacuum
Hot
Temperature
27°C
Heat
Load (W)
100.0
80.0
40.0
20.0
60.0
DT (°C)
0.00
0.50
1.00
1.50
2.00
2.50
3.00
3.50
4.00
60.0
DT (°C)
Heat
Load (W)
0.00
0.50
1.00
1.50
2.00
2.50
3.00
3.50
4.00
4.50
5.00
100.0
80.0
40.0
20.0
0.0
0.0
0.0
0.4
0.8
1.2
1.6
2.0
0.0
5.0
5.0
4.0
4.0
Voltage (VDC)
Voltage (VDC)
TYPICAL PERFORMANCE CURVES
ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN
Q=0
3.0
2.0
DT = 0
1.0
0.0
0.4
0.8
1.2
1.6
2.0
Q=0
3.0
2.0
DT = 0
1.0
0.0
0.0
0.4
0.8
1.2
1.6
2.0
Current (amps)
0.0
0.4
0.8
1.2
1.6
2.0
Current (amps)
MECHANICAL CHARACTERISTICS
For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691.
TYPICAL PERFORMANCE
Environment : Vacuum
TA (C) :
27
VMAX (VDC) :
3.6
D TMAX (C) :
71
IMAX (amps) :
1.9
QMAX (W) :
4.5
ACR (W) :
1.6
TYPICAL PERFORMANCE
TA (C) :
85
VMAX (VDC) :
4.5
D TMAX (C) :
92
IMAX (amps) :
1.8
QMAX (W) :
5.4
ACR (W) :
All dimensions are in millimeters unless otherwise stated.
For customer support or general questions please contact a local office or visit our website at www.marlow.com.
Marlow reserves the right to make product changes without notice.
DOC # 102-0354 REV B - PAGE 2 OF 2
www.marlow.com
很抱歉,暂时无法提供与“CM30-1.9-01AC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+597.413361+77.38935
- 5+561.296335+72.71072
- 20+531.9265220+68.90614
- 40+517.8318040+67.08030
- 60+509.7588860+66.03453
- 100+499.76776100+64.74027
