NL1012T-01AC
NL1012T-01AC
    MARLOWINDUSTRIES,INC.
    TEM8.79X8.79X2.41MM
NL1012T-01AC 数据手册
Technical Data Sheet for NL1012T Single-Stage Thermoelectric Module NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): Device ZT PRODUCT FEATURES       27 61 2.1 1.0 3.7 3.24 0.77 50 68 2.4 1.0 4.2 --- ORDERING OPTIONS RoHS EU Compliant Rated operating temperature of 85°C Maximum process temperature is 120°C. Ceramic Material: Aluminum Oxide 01AC, -02AC: Metallized Exterior Surfaces are Au flash, suitable for soldering. -04AC: Height dimension includes metallization and excludes solder. Model Number NL1012T-01AC NL1012T-02AC NL1012T-03AC NL1012T-04AC Description TEM, Top and Base Metallized Exterior TEM, Base Metallized Exterior TEM, No Metallized Exterior TEM, Top and Base Pre-Tinned with 117°C Solder. OPERATION CAUTIONS INSTALLATION For maximum reliability, storage and operation below 85°C in a non-condensing environment is recommended. To minimize thermal stress when operating in cooling mode, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Recommended mounting methods: Bonding with thermal epoxy or soldering with metallized ceramics. For additional information, please refer to our TEC Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0808 Rev. A II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0291 REV L - PAGE 1 OF 3 www.marlow.com ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN Hot Side Temperature 27°C HEAT LOAD (WATTS) 80.0 20.0 VOLTAGE (VDC) 0.0 T (C) 0.0 2.0 Q=0 T=0 0.0 0.0 0.2 0.4 0.6 0.8 CURRENT (AMPS) 40.0 20.0 3.0 1.0 0.00 0.25 0.50 0.75 1.00 1.25 1.50 1.75 2.00 2.25 60.0 VOLTAGE (VDC) T (C) 40.0 HEAT LOAD (WATTS) 80.0 0.00 0.25 0.50 0.75 1.00 1.25 1.50 1.75 2.00 60.0 4.0 3.0 2.0 1.0 Q=0 T=0 0.0 0.0 1.0 0.2 0.4 0.6 0.8 CURRENT (AMPS) 1.0 POWER GENERATION PERFORMANCE CURVES Hot Side Temperature (°C) 35 0.035 40 45 50 55 Tc=27°C 0.03 0.025 0.02 0.015 0.01 0.005 0 0.1 0.3 0.5 0.7 0.9 Heat (W) 65 75 85 0.5 0.45 0.4 0.35 0.3 0.25 0.2 0.15 0.1 Power Voltage 0.05 0 1.1 1.3 1.5 0.014 55 0.012 Opt Power (W) 30 Opt Voltage (V) 0.04 60 65 70 75 80 85 0.25 Tc=50°C 0.01 0.3 0.2 0.008 0.15 0.006 0.1 0.004 Opt Voltage (V) Hot Side Temperature (°C) Opt Power (W) TYPICAL PERFORMANCE CURVES Hot Side Temperature 50°C 0.05 0.002 Power 0 0.1 0.3 0.5 Heat (W) Voltage 0 0.7 Efficiency 0 1 2 3 4 5 6 7 Load Resistance Ratio 8 1 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 Voltage 0.1 0 9 10 Voltage / VOC η / Opt η Normalized Off-Peak Performance 1 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 Hot Side Temperature (°C) Cold Side Temperature (°C) Optimum Efficiency, η (%) Optimum Power (W) Optimum Voltage (V) Load Resistance for Opt η (Ω) Open Circuit Voltage, VOC (V) Short Circuit Current (A) Thermal Resistance (°C/W) 85 27 2.52 0.038 0.446 5.23 0.78 0.20 38.51 55 27 1.28 0.009 0.213 4.88 0.37 0.10 38.56 35 27 0.37 0.001 0.060 4.65 0.11 0.03 38.50 For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691. MI Form 005-0808 Rev. A DOC # 102-0291 REV L - PAGE 2 OF 3 www.marlow.com MECHANICAL CHARACTERISTICS Dimensions are in inches, and millimeters are in [ ]. * NOTE: Cold Side, Hot Side, and Positive and Negative Leads are valid only for thermoelectric cooling. For power generation, refer to figure below. For customer support or general questions please contact a local office or visit our website at www.marlow.com. Marlow reserves the right to make product changes without notice. Power Generation performance information is given in a nitrogen environment and cold side temperatures of 27°C and 50°C. Module temperature does not include thermal resistance of heat sinks. For performance information in vacuum, other cold side temperatures, or specific heat sinks, consult one of our applications engineers. TYPICAL POWER GENERATION CONFIGURATION EXAMPLE: MI Form 005-0808 Rev. A DOC # 102-0291 REV L - PAGE 3 OF 3 www.marlow.com
NL1012T-01AC 价格&库存
很抱歉,暂时无法提供与“NL1012T-01AC”相匹配的价格&库存,您可以联系我们找货
