TR060-6.5-40-03LS
TR060-6.5-40-03LS
    MARLOWINDUSTRIES,INC.
    TEMTRITONICE40.13X40.13X3.9MM
TR060-6.5-40-03LS 数据手册
Technical Data Sheet for TR060-6.5 Single-Stage Thermoelectric Module TRITON ICETM SERIES NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): PRODUCT FEATURES • • • • • • • • • 27 76 61 6.5 15.8 2.1 50 86 66 6.5 17.8 --- ORDERING OPTIONS RoHS EU Compliant Rated operating temperature of 130°C. Ceramic Material: Aluminum Oxide Designed for temperature cycling applications. Porch configuration for high strength leadwire connection. Superior nickel diffusion barriers on elements. High strength for rugged environment. RTV sealing option available. Lapped option available for multiple module applications. Model Number TR060-6.5-40-01 TR060-6.5-40-01L TR060-6.5-40-01S TR060-6.5-40-01LS TR060-6.5-40-03LS TR060-6.5-40-04LS Description Leadwires Leadwires, Lapped Leadwires, Sealed Leadwires, Lapped, Sealed Leadwires, Lapped, Sealed, Sealed Leadwire Joints, Hi-Pot Tested Leadwires 120mm, Lapped, Sealed OPERATION CAUTIONS INSTALLATION For maximum reliability, storage and operation below 130°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Recommended mounting method: Clamp with uniform pressure to a flat surface with thermal interface material. For additional information, please refer to our TEC Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0688 Rev. 4 www.marlow.com II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0391 REV E - PAGE 1 OF 3 100.0 Hot Side Temperature 50°C 80.0 Heat Load (W) 0 80.0 60.0 10 60.0 20 40.0 30 20.0 0.0 ΔT (°C) ΔT (°C) 100.0 Hot Side Temperature 27°C 0.0 2.0 4.0 6.0 50 0.0 30 40 50 60 0.0 2.0 4.0 6.0 8.0 20.0 16.0 16.0 8.0 Voltage (VDC) Q=0 12.0 ΔT=0 4.0 0.0 20 20.0 8.0 Heat Load (W) 0 10 40.0 40 20.0 Voltage (VDC) TYPICAL PERFORMANCE CURVES ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN 0.0 2.0 4.0 6.0 Current (amps) 8.0 ΔT=0 4.0 0.0 8.0 Q=0 12.0 0.0 2.0 4.0 6.0 Current (amps) 8.0 For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691. + 123456 20 AWG LEADS TEFLON INSULATED _ 1.580±0.025 [40.13±0.64] TR060-6.5-40 (+), WHITE MARLOW MECHANICAL CHARACTERISTICS (2X .12 [3.18]) (-), BLACK 4.00 ± .50 [101.6±12.7] 1.580±0.025 [40.13±0.64] 1.760±0.025 [44.70±0.64] COLD SIDE, Tc -01, -01S -01L, -01LS .003 [0.08] .002 [0.05] .002 [0.05] .001 [0.03] .002 [0.05] .001 [0.03] A HOT SIDE, Th -01 & -01S -01L & -01LS .159 ±.005 [4.04±0.13] .154 ±.001 [3.91±0.03] A Dimensions in [ ] are millimeters -01, -01L, -01S, -01LS For customer support or general questions please contact a local office or visit our website at www.marlow.com. MI Form 005-0688 Rev. 4 www.marlow.com DOC # 102-0391 REV E - PAGE 2 OF 3 + (+), WHITE (-), BLACK 20 AWG LEADS TEFLON INSULATED MIL-W-16878/4 _ 1.580±0.025 [40.13±0.64] 123456 MARLOW TR060-6.5-40 (2X 0.125 [3.18]) 12.00 ± .50 [304.8±12.7] 1.760±0.025 [44.70±0.64] COLD SIDE, Tc .002 [0.05] .001 [0.03] A .001 [0.03] HOT SIDE, Th A .154 ±.001 [3.91±0.03] Dimensions in [ ] are millimeters -03LS + (2X .236 [5.99]) 123456 SOLDER Sn95 Ag3.5 ln1.5 OVER 2X WIRE ENDS 20 AWG LEADS TEFLON INSULATED _ 1.580±0.025 [40.13±0.64] TR060-6.5-40 (+), WHITE MARLOW MECHANICAL CHARACTERISTICS 1.580±0.025 [40.13±0.64] (-), BLACK 4.72 ± .50 [119.9±12.7] 1.580±0.025 [40.13±0.64] 1.760±0.025 [44.70±0.64] -04LS COLD SIDE, Tc .002 [0.05] .001 [0.03] A .001 [0.03] HOT SIDE, Th A -04LS .154 ±.001 [3.91±0.03] Dimensions in [ ] are millimeters -04LS For customer support or general questions please contact a local office or visit our website at www.marlow.com. MI Form 005-0688 Rev. 4 www.marlow.com DOC # 102-0391 REV E - PAGE 3 OF 3
TR060-6.5-40-03LS 价格&库存
很抱歉,暂时无法提供与“TR060-6.5-40-03LS”相匹配的价格&库存,您可以联系我们找货
