NL1507-03AC
NL1507-03AC
    MARLOWINDUSTRIES,INC.
    TEM14.33X11.28X2.43MMDIA4MM
NL1507-03AC 数据手册
Technical Data Sheet for NL1507 Single-Stage Thermoelectric Module NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): PRODUCT FEATURES • • • • 27 64 5.4 1.8 4.7 2.30 50 72 6.2 1.8 5.4 -- ORDERING OPTIONS RoHS EU Compliant Rated operating temperature of 85°C Maximum processing temperature of 220°C Ceramic Material: Aluminum Oxide. Model Number NL1507-03AC NL1507-04AC Description 4mm Thru Hole 4mm Thru Hole, Inspected for Alignment OPERATION CAUTIONS INSTALLATION For maximum reliability, storage and operation below 85°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Recommended mounting methods: Bonding with thermal epoxy or soldering with metallized ceramics. For additional information, please refer to our TEM Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0808 Rev. B II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0328 REV N - PAGE 1 OF 2 www.marlow.com 80.0 0.00 0.50 1.00 1.50 2.00 2.50 3.00 3.50 4.00 4.50 5.00 40.0 20.0 80.0 40.0 20.0 0.0 0.0 5.0 5.0 4.0 3.0 2.0 Q=0 T=0 1.0 0.0 0.0 0.4 0.8 1.2 1.6 CURRENT (AMPS) 2.0 HEAT LOAD (WATTS) 0.00 0.50 1.00 1.50 2.00 2.50 3.00 3.50 4.00 4.50 5.00 5.50 60.0 VOLTAGE (VDC) T (C) 60.0 Hot Side Temperature 50°C HEAT LOAD (WATTS) T (C) Hot Side Temperature 27°C VOLTAGE (VDC) TYPICAL PERFORMANCE CURVES ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN 4.0 3.0 2.0 Q=0 T=0 1.0 0.0 0.0 0.4 0.8 1.2 1.6 CURRENT (AMPS) 2.0 MECHANICAL CHARACTERISTICS For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691. All units are in inches, [ ] are in millimeters unless otherwise stated. For customer support or general questions please contact a local office or visit our website at www.marlow.com. Marlow reserves the right to make product changes without notice. MI Form 005-0808 Rev. B DOC # 102-0328 REV N - PAGE 2 OF 2 www.marlow.com
NL1507-03AC 价格&库存
很抱歉,暂时无法提供与“NL1507-03AC”相匹配的价格&库存,您可以联系我们找货
NL1507-03AC
  • 1+862.732051+111.49268
  • 5+810.493855+104.74183
  • 10+789.0076510+101.96512
  • 25+761.4787525+98.40750
  • 50+741.2970150+95.79937
  • 100+721.65512100+93.26101
库存:9
