Technical Data Sheet
For NL1013T
Single-Stage Thermoelectric Module
PRODUCT FEATURES
RoHS EU Compliant
Rated operating temperature of 85°C.
Maximum processing temperature of 120°C.
Ceramic Material: Aluminum Oxide.
Metallized Exterior Surfaces are Au flash, suitable for soldering.
II-VI MARLOW
www.marlow.com
CONTACT US
marlow.sales@ii-vi.com– Dallas, TX USA
214-340-4900 – 877-627-5691
DOC #: 102-10012
REV: A01
NOMINAL PERFORMANCE IN VACUUM
Hot Side Temperature (°C)
Δ Tmax (°C):
Qmax (watts):
Imax (amps):
Vmax (vdc):
AC Resistance (ohms):
OPERATION CAUTIONS
27
61
4.8
1.0
8.5
0.77
50
69
5.4
1.0
9.6
ORDERING OPTIONS
Model Number
NL1013T-01AC
NL1013T
For maximum reliability, storage and operation
below 85°C in a non-condensing environment is
recommended. To minimize thermal stress, use
linear/proportional temperature control or a
similar method rather than an ON/OFF method.
INSTALLATION
Description
Top and Base Metallized Exterior
Recommended mounting methods: Bonding with
thermal epoxy or soldering with metallized ceramics.
For additional information, please refer to our TEM
Installation Guide.
TYPICAL PERFORMANCE CURVES
ENVIRONMENT: 10^-5 TORR VACUUM
0.0
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
4.5
T (C)
60
40
VOLTAGE (VDC)
6
4
2
Q=0
T=0
0.2
0.4
0.6
0.8
CURRENT (AMPS)
1.0
80
HEAT
LOAD
(WATTS)
0.0
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
4.5
5.0
60
T (C)
80
Hot Side Temperature 50°C
HEAT
LOAD
(WATTS)
40
VOLTAGE (VDC)
Hot Side Temperature 27°C
8
6
4
Q=0
T=0
2
0.2
0.4
0.6
0.8
CURRENT (AMPS)
1.0
For performance information in a vacuum or with hot side temperatures other than 27°C or 75°C, contact one of our Applications
Engineers at 877-627-5691.
DOC #: 102-10012
MI Form 005-0685
Rev A
REV: A01
2/3
NL1013T
MECHANICAL CHARACTERISTICS
0.20±0.13, 4X
Leads: 28 AWG, Buss,
Solid Tinned Copper
13.16
13.16
2.41±0.13
Cold Side, Tc
50.80±6.35
0.13
A
0.03
0.03
Hot Side, Th
A
0.20±0.13, 4X
All units are in millimeters unless otherwise stated.
For customer support or general questions please contact a local office or visit our website at www.marlow.com.
Marlow reserves the right to make product changes without notice.
DOC #: 102-10012
MI Form 005-0685
Rev A
REV: A01
3/3
很抱歉,暂时无法提供与“NL1013T-01AC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+841.913521+109.06207
- 5+790.946285+102.45974
- 10+769.9677410+99.74216
- 25+743.1038125+96.26219
- 64+716.5210764+92.81865
- 128+697.53635128+90.35935
