Additional Resources:
Product Page
date
08/05/2022
page 1 of 4
SERIES: CP125 | DESCRIPTION: PELTIER MODULE
FEATURES
• arcTEC™ structure
• solid state device
• precise temperature control
• quiet operation
MODEL
CP12437
Notes:
input
voltage1
input
current2
output
Qmax3
max
(Vdc)
max
(A)
Th=27°C
(W)
Th=50°C
(W)
Th=27°C
(°C)
Th=50°C
(°C)
15.4
12.5
110
121
68
75
1. Maximum voltage at ΔT max and Th=27°C
2. Maximum current to achieve ΔT max
3. Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C
4. Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa)
PART NUMBER KEY
CP12 X 37
Base Number
Length x Width:
4 = 40 x 40 mm
cuidevices.com
output
∆Tmax4
Product Page
CUI DEVICES | SERIES: CP125 | DESCRIPTION: PELTIER MODULE
date 08/05/2022 | page 2 of 4
SPECIFICATIONS
parameter
conditions/description
internal resistance1
solder melting temperature
min
typ
max
units
0.855
0.95
1.045
Ω
1
MPa
80
°C
connection between thermoelectric pairs
235
°C
assembly compression
hot side plate
RoHS
Note:
yes
1. Measured by AC 4-terminal method at 25°C
MECHANICAL DRAWING
units: mm
MATERIAL
HOT SIDE
0.05
THICKNESS
COLD SIDE
0.05
96% AL2O3
wire leads
18 AWG
sealer
silicon rubber 703 RTV (between cold and
hot side plates)
joint cover
marking
P/N & S/N printed on cold side surface
10 3.0
Red (+)
WIDTH
COLD SIDE
Black (-)
LENGTH
100.0 5.0
MODEL NO.
LENGTH
(mm)
WIDTH
(mm)
THICKNESS
(mm)
CP12437
40 ±0.3
40 ±0.3
3.7 ±0.1
cuidevices.com
PLATING
ceramic plate
tin
Product Page
date 08/05/2022 | page 3 of 4
Input Voltage (V)
PERFORMANCE (Th=27°C)
12.5 A
16
10 A
12
7.5 A
5.0 A
8.0
2.5 A
4.0
Heat Pumped, Q (W)
5A
12.
100
10 A
80
60
40
7.5
A
5.0
A
2.5 A
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
PERFORMANCE (Th=50°C)
12.5 A
16
10 A
7.5 A
12
5.0 A
8.0
2.5 A
4.0
Heat Pumped, Q (W)
120
12.5
100
A
7.5
80
10
A
A
5.0 A
60
40
2.5 A
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
date 08/05/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
09/08/2016
1.01
changed to arcTEC™ structure
12/01/2017
1.02
brand update
10/28/2019
logo, datasheet style update
08/05/2022
1.03
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CP12437”相匹配的价格&库存,您可以联系我们找货
