CP15535
CP15535
    CUIDEVICES
    PELTIER,50X50X3.75MM,15A
CP15535 数据手册
For more information, please visit the product page. date 09/08/2016 page 1 of 4 SERIES: CP150 │ DESCRIPTION: PELTIER MODULE ED FEATURES CP15535 input current2 max (Vdc) max (A) 15.4 1. 2. 3. 4. Maximum Maximum Maximum Maximum output Qmax3 15 Th=50°C (W) Th=27°C (°C) Th=50°C (°C) 130 145 68 75 voltage at ΔT max and Th=27°C current to achieve ΔT max heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa) PART NUMBER KEY O CP15 X 35 Length x Width: 5 = 50 x 50 mm D IS C Base Number cui.com output ∆Tmax4 Th=27°C (W) N Notes: input voltage1 TI MODEL N U • solid state device • precise temperature control • quiet operation For more information, please visit the product page. CUI Inc │ SERIES: CP150 │ DESCRIPTION: PELTIER MODULE date 09/08/2016 │ page 2 of 4 SPECIFICATIONS parameter conditions/description internal resistance1 typ max units 0.84 0.924 Ω connection between thermoelectric pairs 138 assembly compression hot side plate RoHS Note: °C ED solder melting temperature min 0.756 2011/65/EU 1. Measured by AC 4-terminal method at 25°C MECHANICAL DRAWING units: mm U MATERIAL HOT SIDE 0.05 COLD SIDE sealer silicon rubber 703 RTV (between cold and hot side plates) silicon rubber 703 RTV marking P/N & S/N printed on cold side surface Black (-) 100.0 5.0 LENGTH (mm) WIDTH (mm) THICKNESS (mm) CP15535 50 ±0.3 50 ±0.3 3.75 ±0.1 D MODEL NO. cui.com tin joint cover N O IS C LENGTH PLATING 18 AWG Red (+) COLD SIDE °C 96% AL2O3 7 3.0 WIDTH 80 wire leads TI 0.05 MPa ceramic plate N THICKNESS 1 For more information, please visit the product page. CUI Inc │ SERIES: CP150 │ DESCRIPTION: PELTIER MODULE date 09/08/2016 │ page 3 of 4 12 A 9A 10 6A 5 3A 0 15 A N 120 80 40 0 70 60 TI Heat Pumped, Q (W) ED 15 A 15 U Input Voltage (V) PERFORMANCE (Th=27°C) 50 40 30 20 12 A 9A 6A 3A 10 0 N ΔT=Th-Tc (°C) O PERFORMANCE (Th=50°C) 15 12 A 9A 10 6A 3A 5 0 Heat Pumped, Q (W) D IS C Input Voltage (V) 15 A 15 A 12 A 120 9A 6A 80 3A 40 0 70 60 50 40 ΔT=Th-Tc (°C) cui.com 30 20 10 0 For more information, please visit the product page. CUI Inc │ SERIES: CP150 │ DESCRIPTION: PELTIER MODULE date 09/08/2016 │ page 4 of 4 REVISION HISTORY 1.0 description date initial release 09/08/2016 ED rev. D IS C O N TI N U The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
CP15535 价格&库存
很抱歉,暂时无法提供与“CP15535”相匹配的价格&库存,您可以联系我们找货
