XLT2416-04AC
XLT2416-04AC
    MARLOWINDUSTRIES,INC.
    TEMTHERMOCYCLER25.4X25.4X3.8MM
XLT2416-04AC 数据手册
Technical Data Sheet for XLT2416 Single-Stage Thermoelectric Module NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): PRODUCT FEATURES • • • • • • • • • • • 27 56 34 14.7 3.6 0.20 50 64 37 14.6 4.0 --- ORDERING OPTIONS RoHS EU Compliant Rated operating temperature of 125°C. Ceramic Material: Aluminum Oxide Designed for temperature cycling applications. Capable of rapid heating and cooling rates. Porch configuration for high strength leadwire connection. Superior nickel diffusion barriers on elements. High strength for rugged environment. RTV sealing option available. Lapped option available for multiple module applications. Set of modules ACR matched available. Model Number XLT2416-03AC XLT2416-04AC XLT2416-05AC XLT2416-06AC XLT2416-08AC XLT2416-09AC XLT2416-16AC Description Lapped, Leadwires Lapped, Leadwires, Sealed Lapped, Leadwires, ACR Number Coded Lapped, Leadwires, ACR Number Coded Lapped, Leadwires, ACR & Height Marked Lapped, Leadwires, ACR & Height Marked Lapped, Leadwires, ACR Match, Height Match, Set of Six OPERATION CAUTIONS INSTALLATION For maximum reliability, storage and operation below 125°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Recommended mounting method: Clamp with uniform pressure to a flat surface with thermal interface material. For additional information, please refer to our TEC Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0692 Rev. 4 www.marlow.com II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0312 REV P - PAGE 1 OF 2 Hot Side Temperature 27°C Hot Side Temperature 50°C 60 70 Heat Heat Load (W) 0 2.5 5.0 7.5 10.0 12.5 15.0 17.5 20.0 22.5 25.0 27.5 30.0 Load (W) 50 60 0 2.5 7.5 ∆T (°C) ∆T (°C) 50 5.0 40 10.0 30 12.5 15.0 20 17.5 22.5 10 27.5 50.0 4.0 8.0 4 12.0 16.0 30 10 25.0 0 40 20 20.0 0 20.0 5 0.0 4.0 8.0 4 Q=0 Voltage (VDC) Voltage (VDC) TYPICAL PERFORMANCE CURVES ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN 3 ∆T = 0 2 12.0 16.0 20.0 Q=0 3 ∆T = 0 2 1 1 0 0 0 2 4 6 8 10 12 14 16 18 0 20 2 Current (amps) 4 6 8 10 12 14 16 18 20 Current (amps) ACR Range (ohms) 0.172 0.175 0.178 0.181 0.184 0.187 0.190 0.193 0.196 0.199 0.202 0.205 0.208 0.211 0.214 0.218 (+), WHITE LEADWIRES: 18 AWG, 19/30 STRANDING, TEFLON INSULATED 1.000 [25.40] HEIGHT READING (-08AC, -09AC, -16AC ONLY) (-), BLACK X 0.170 0.172 0.175 0.178 0.181 0.184 0.187 0.190 0.193 0.196 0.199 0.202 0.205 0.208 0.211 0.214 ACR NUMBER CODE (-05AC ONLY) ACR READING (-08AC, -09AC, -16AC ONLY) X ACR Number Code 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 X MECHANICAL CHARACTERISTICS For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691. 1.000 [25.40] LOT # (-08AC, -09AC, -16AC ONLY) 1.130 [28.70] COLD SIDE, Tc 4.0±.5 [101.6±12.7] .866±.10 [22±2.6] (-08AC, -16AC ONLY) .002 [.051] A .001 [.025] .001 [.025] .150 ±.0005 [3.81 ±.013] HOT SIDE, Th Dimensions in [ ] are millimeters A For customer support or general questions please contact a local office or visit our website at www.marlow.com. MI Form 005-0692 Rev. 4 www.marlow.com DOC # 102-0312 REV P - PAGE 2 OF 2
XLT2416-04AC 价格&库存
很抱歉,暂时无法提供与“XLT2416-04AC”相匹配的价格&库存,您可以联系我们找货
