SP2394-07AB
SP2394-07AB
    MARLOWINDUSTRIES,INC.
    MULTISTAGETEM21.72X28.27X8.69MM
SP2394-07AB 数据手册
Technical Data Sheet for SP2394 Multi-Stage Thermoelectric Module NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): PRODUCT FEATURES • • • 27 130 4.5 5.1 8.5 1.56 50 146 4.9 5.1 9.4 --- ORDERING OPTIONS Pretinned metallized ceramic surface(s) with 117°C solder available. Elevated temperature burn-in with test data provide. Ceramic Material: Aluminum Oxide and Beryllium Oxide. Model Number SP2394-01AB SP2394-02AB SP2394-03AB SP2394-04AB SP2394-05AB SP2394-07AB Description Metallized Base and Top – cooler is mounted and shipped on test base Metallized Base Only – cooler is mounted and shipped on test base No Metallization, No Burn In Metallized Base Only, No Burn In Metallized Base and Top, 117° both sides Metallized Base and Top, No Burn In OPERATION CAUTIONS INSTALLATION For maximum reliability, storage and operation below 85°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Recommended mounting methods: Bonding with thermal epoxy or soldering with metallized ceramics. For additional information, please refer to our TEM Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0685 Rev. 6 www.marlow.com II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0253 REV K - PAGE 1 OF 2 Hot Side Temperature 50°C Hot Side Temperature 27°C Heat Heat Load (W) 0.00 0.50 1.00 1.50 2.00 2.50 3.00 3.50 160.0 Load (W) 0.00 120.0 0.50 120.0 1.50 80.0 2.00 2.50 ∆T (°C) ∆T (°C) 1.00 3.00 40.0 80.0 40.0 3.50 4.00 4.00 0.0 0.0 0.0 1.0 2.0 3.0 4.0 5.0 0.0 10.0 1.0 2.0 3.0 4.0 5.0 10.0 8.0 8.0 Q=0 Voltage (VDC) Voltage (VDC) TYPICAL PERFORMANCE CURVES ENVIRONMENT: VACUUM 6.0 4.0 ∆T = 0 2.0 0.0 Q=0 6.0 4.0 ∆T = 0 2.0 0.0 0.0 1.0 2.0 3.0 4.0 5.0 0.0 1.0 Current (amps) 2.0 3.0 4.0 5.0 Current (amps) For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691. MECHANICAL CHARACTERISTICS POS (+) .253 [6.43] .855 [21.72] LEADS: BUS, 22AWG COPPER, TINNED NEG (-) .425 [10.80] 4.00 ±0.25 [101.6 ±6.35] Beryllium Oxide Handling Precautions Beryllium oxide can be toxic only when dust, mist, or fumes containing particles small enough to enter the lungs are inhaled. For the user, precautions required are to avoid grinding, machining or pulverizing the material by mechanical, thermal, or chemical processing. marlow industries, inc. 1.113 [28.27] COLD SIDE R .010[.25] A .342±.013 [8.69±.33] A All units are in inches. All units in [ ] are in millimeters. For customer support or general questions please contact a local office or visit our website at www.marlow.com. Marlow reserves the right to make product changes without notice. MI Form 005-0685 Rev. 6 www.marlow.com DOC # 102-0253 REV K - PAGE 2 OF 2
SP2394-07AB
1. 物料型号:SP2394。 2. 器件简介:SP2394多级热电模块,具有不同订购选项,包括不同金属化层和高温老化测试。 3. 引脚分配:正极(+)引脚尺寸为.855 x .253 [21.72 x 6.35] mm,负极(-)引脚尺寸为[101.6 ±6.35] 4.00 ±0.25 .425 [10.80] mm,引脚材料为22AWG铜,锡镀。 4. 参数特性: - 在27°C热侧温度下,最大温差(∆Tmax)为130°C,最大功率(Qmax)为4.5瓦,最大电流(Imax)为5.1安培,最大电压(Vmax)为8.5伏直流,交流电阻为1.56欧姆。 - 在50°C热侧温度下,∆Tmax为146°C,Qmax为4.9瓦,Imax保持不变,Vmax增至9.4伏直流。 5. 功能详解:模块适用于真空环境,具有典型的性能曲线和机械特性。热电模块能够在27°C和50°C的热侧温度下运行,并提供不同负载下的性能数据。 6. 应用信息:推荐在85°C以下、非凝结环境下存储和操作,以获得最大可靠性。为减少热应力,建议使用线性/比例温度控制或类似方法,而不是开关控制方法。推荐的安装方法包括使用热环氧树脂粘接或使用金属化陶瓷焊接。 7. 封装信息:封装材料包括氧化铝和氧化铍。所有单位均为英寸,括号内为毫米。对于客户支持或一般问题,请联系当地办事处或访问www.marlow.com。Marlow保留在不通知的情况下进行产品更改的权利。
SP2394-07AB 价格&库存
很抱歉,暂时无法提供与“SP2394-07AB”相匹配的价格&库存,您可以联系我们找货
