Technical Data Sheet for NL2064T
Two-Stage Thermoelectric Module
NOMINAL PERFORMANCE IN NITROGEN
Hot Side Temperature (°C)
Δ Tmax (°C):
Qmax (watts):
Imax (amps):
Vmax (vdc):
AC Resistance (ohms):
PRODUCT FEATURES
27
93
10.4
5.4
8.6
1.43
50
105
11.2
5.4
9.6
ORDERING OPTIONS
RoHS EU Compliant
Rated operating temperature of 85°C
Maximum processing temperature of 120°C
Ceramic material: Aluminum oxide top and base, Beryllium
oxide mid.
Model Number
NL2064T-11AB
NL2064T-12AB
NL2064T-13AB
NL2064T-14AB
Description
Both Surfaces are Metallized, Wire
Buss Tin Coated
Hot Side Exterior is Metallized, Wire
Buss Tin Coated
No Metallization, Wire Buss Tin
Coated
No Metallization, Wire Buss Gold
Over Ni/ Cu
OPERATION CAUTIONS
INSTALLATION
For maximum reliability, storage and operation below 85°C
in a non-condensing environment is recommended. To
minimize thermal stress, use linear/proportional
temperature control or a similar method rather than an
ON/OFF method.
Recommended mounting methods: Bonding with thermal
epoxy or soldering with metallized ceramics. For additional
information, please refer to our TEM Installation Guide.
II-VI Marlow – Dallas, TX USA
214-340-4900
877-627-5691
marlow.sales@ii-vi.com
Marlow Industries Europe
GmbH - Germany
+49 (0) 6150 5439 - 403
info@marlow-europe.eu
II-VI Japan Inc.
81 43 297 2693 (tel)
center@ii-vi.co.jp
www.ii-vi.co.jp
MI Form 005-0808 Rev. B
II-VI Singapore Pte., Ltd.
(65) 6481 8215 (tel)
info@ii-vi.com.sg
Marlow Industries China, II-VI
Technologies Beijing
86-10-643 98226
info@iivibj.com
DOC # 102-0345 REV F - PAGE 1 OF 2
www.marlow.com
Hot Side Temperature: 27°C
100.0
T (C)
80.0
60.0
40.0
20.0
0.0
Hot Side Temperature: 50°C
HEAT
LOAD
(WATTS)
0.00
1.00
2.00
3.00
4.00
5.00
6.00
7.00
8.00
9.00
10.0
Hot Side Temperature 50°C
HEAT
LOAD
(WATTS)
120.0
100.0
0.00
1.00
2.00
3.00
4.00
5.00
6.00
7.00
8.00
9.00
10.0
80.0
T (C)
Hot Side Temperature 27°C
60.0
40.0
20.0
0.0
8.0
10.0
6.0
4.0
Q=0
T=0
2.0
0.0
0.0
VOLTAGE (VDC)
VOLTAGE (VDC)
TYPICAL PERFORMANCE CURVES
ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN
8.0
6.0
4.0
Q=0
T=0
2.0
1.0
2.0
3.0
4.0
CURRENT (AMPS)
5.0
6.0
0.0
0.0
1.0
2.0 3.0 4.0 5.0
CURRENT (AMPS)
6.0
7.0
MECHANICAL CHARACTERISTICS
For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691.
Beryllium Oxide Handling
Precautions
Beryllium oxide can be toxic only when
dust, mist, or fumes containing particles
small enough to enter the lungs are
inhaled. For the user, precautions required
are to avoid grinding, machining or
pulverizing the material by mechanical,
thermal, or chemical processing.
marlow industries, inc.
R
For customer support or general questions please contact a local office or visit our website at www.marlow.com.
Marlow reserves the right to make product changes without notice.
DOC # 102-0345 REV F - PAGE 2 OF 2
www.marlow.com
很抱歉,暂时无法提供与“NL2064T-11AB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3793.946721+490.29970
- 6+3539.344666+457.39694
- 10+3469.9439010+448.42814
- 26+3343.8498426+432.13274
