NL1020T-01AC
NL1020T-01AC
    MARLOWINDUSTRIES,INC.
    TEM3.96X3.96X2.16MM
NL1020T-01AC 数据手册
Technical Data Sheet for NL1020T Single-Stage Thermoelectric Module NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): PRODUCT FEATURES • • • • • • • 27 64 0.9 1.8 0.8 0.40 50 72 1.0 1.8 0.9 -- ORDERING OPTIONS RoHS EU Compliant REACH EU Compliant Rated operating temperature of 85°C. Maximum process temperature is 120°C. Ceramic Material: Aluminum Oxide -01AC, -02AC: External Metallization is Au flash, suitable for soldering. RTV sealing option available. Model Number NL1020T-01AC NL1020T-02AC NL1020T-03AC NL1020T-04AC NL1020T-05AC Description Both surfaces are metallized Hot side exterior is metallized No metallization No metallization, Insulated Leads, Perimeter Sealed No metallization, Insulated Leads OPERATION CAUTIONS INSTALLATION For maximum reliability, storage and operation below 85°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Recommended mounting methods: Bonding with thermal epoxy or soldering with metallized ceramics. For additional information, please refer to our TEC Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0808 Rev. A II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0294 REV K - PAGE 1 OF 3 www.marlow.com 80.0 0.00 0.10 0.20 0.30 0.40 0.50 0.60 0.70 0.80 0.90 T (C) 60.0 40.0 20.0 0.0 Hot Side Temperature 50°C HEAT LOAD (WATTS) 80.0 40.0 20.0 0.6 0.4 Q=0 T=0 0.2 0.0 0.0 0.4 0.8 1.2 1.6 CURRENT (AMPS) VOLTAGE (VDC) 0.0 0.8 2.0 HEAT LOAD (WATTS) 0.00 0.10 0.20 0.30 0.40 0.50 0.60 0.70 0.80 0.90 1.00 60.0 T (C) Hot Side Temperature 27°C VOLTAGE (VDC) TYPICAL PERFORMANCE CURVES ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN 1.0 0.8 0.6 0.4 0.2 0.0 0.0 0.4 0.8 1.2 1.6 CURRENT (AMPS) 2.0 Q=0 T=0 For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691. MI Form 005-0808 Rev. A DOC # 102-0294 REV K - PAGE 2 OF 3 www.marlow.com MECHANICAL CHARACTERISTICS Dimensions are in millimeters, inches are in [ ]. * -01AC, -02AC Only: External Metallization per page 1. -01AC, -02AC, -03AC Dimensions are in millimeters, and inches are in [ ]. -04AC, -05AC For customer support or general questions please contact a local office or visit our website at www.marlow.com. Marlow reserves the right to make product changes without notice. MI Form 005-0808 Rev. A DOC # 102-0294 REV K - PAGE 3 OF 3 www.marlow.com
NL1020T-01AC 价格&库存
很抱歉,暂时无法提供与“NL1020T-01AC”相匹配的价格&库存,您可以联系我们找货
