XLT2393-01LS
XLT2393-01LS
    MARLOWINDUSTRIES,INC.
    TEMTHERMOCYCLER40X38X2.41MM
XLT2393-01LS 数据手册
Technical Data Sheet for XLT2393 Single-Stage Thermoelectric Module NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): 27 58 187 13.4 21.4 1.33 50 67 208 13.3 23.7 --- Performance values account for the heat sink resistance losses through the base ceramic. PRODUCT FEATURES • • • • • • • • • • • ORDERING OPTIONS RoHS EU Compliant Rated operating temperature of 125°C. Ceramic Material: Aluminum Oxide Designed for temperature cycling applications. Capable of rapid heating and cooling rates. Porch configuration for high strength leadwire connection. Superior nickel diffusion barriers on elements. High strength for rugged environment. RTV sealing option available. Lapped option available for multiple module applications. Diced option for further mechanical stress relief. Model Number XLT2393-00L XLT2393-00LS XLT2393-01L XLT2393-01LS XLT2393-01LD XLT2393-02LS XLT2393-05LS XLT2393-06SD XLT2393-07SD XLT2393-08SD XLT2393-53SD XLT2393-54SD Description Lapped Lapped, Sealed Leadwires, Lapped Leadwires, Lapped, Sealed Leadwires, Lapped, Diced Leadwires 6 inch, Lapped, Sealed Leadwires 8 inch, Lapped, Sealed Leadwires 11”, Lapped, Sealed, Diced, 9 Sections, Leadwires 11”, Lapped, Sealed, Diced, 25 Sections Leadwires 11”, Lapped, Sealed, Diced, 20 Sections Leadwires 4”, Sealed, Diced, 20 Sections, Metalized Base Leadwires 11”, Sealed, Diced, 20 Sections, Metalized Base OPERATION CAUTIONS INSTALLATION For maximum reliability, storage and operation below 125°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Recommended mounting method: Clamp with uniform pressure to a flat surface with thermal interface material. For additional information, please refer to our TEC Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0692 Rev. 4 www.marlow.com II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0243 REV AA - PAGE 1 OF 2 Hot Side Temperature 27°C Hot Side Temperature 50°C Heat 60 Load (W) 50 0 ∆T (ºC) ∆T (ºC) 25 30 70 Heat 60 Load (W) 0 50 40 50 25 40 50 30 75 20 75 20 100 100 10 10 125 125 0 28 0 26 24 22 20 18 16 14 12 10 8 6 4 2 0 0 150 0 4 8 12 16 20 Q=0 Voltage (VDC) Voltage (VDC) TYPICAL PERFORMANCE CURVES ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN ∆T = 0 4 8 12 16 20 4 30 0 28 26 24 22 20 18 16 14 12 10 8 6 4 2 0 0 8 12 16 20 Q=0 ∆T = 0 4 Current (amps) 8 12 16 20 Current (amps) For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691. MECHANICAL CHARACTERISTICS 1.575 [40.00] (+), WHITE (-02LS: RED) 1.575 [40.00] (-), BLACK 1.497 [38.02] COLD SIDE, Tc 1 .002 [0.05] A .001 [0.03] .001 [0.03] STANDARD .095±.001 [2.41±0.03] -53SD, -54SD, -55SD .103±.005 [2.62±0.13] HOT SIDE, Th LEADWIRES: 20 AWG, 19/32 STRANDING. TEFLON INSULATED LENGTH: 4.0 ±.5 [101.60±12.70] 6.0 ±.5 [152.40±12.70] (-02LS ONLY) STRIP LENGTH: .125±.02 [3.18±0.51] -05LS: LENGTH : 7.87±.5 [200±13] STRIP LENGTH: .10±.02 [2.5±0.5] -06SD: LENGTH : 11.0±.5 [279.40±12.70] STRIP LENGTH: .125±.02 [3.18±0.51] -07SD: LENGTH : 11.0±.5 [279.40±12.70] STRIP LENGTH: .125±.02 [3.18±0.51] -08SD: LENGTH : 11.0±.5 [279.40±12.70] STRIP LENGTH: .125±.02 [3.18±0.51] -54SD: LENGTH : 11.0±.5 [279.40±12.70] STRIP LENGTH: .125±.02 [3.18±0.51] -55SD: LENGTH : 11.0±.5 [279.40±12.70] STRIP LENGTH: .125±.02 [3.18±0.51] A 1 APPLY TO UN-DICED COOLER ONLY Dimensions in [ ] are millimeters For customer support or general questions please contact a local office or visit our website at www.marlow.com. MI Form 005-0692 Rev. 4 www.marlow.com DOC # 102-0243 REV AA - PAGE 2 OF 2
XLT2393-01LS 价格&库存
很抱歉,暂时无法提供与“XLT2393-01LS”相匹配的价格&库存,您可以联系我们找货
