LCC12-8-01LS
LCC12-8-01LS
    MARLOWINDUSTRIES,INC.
    TEMTHERMOCYCLER40X40X3.94MM
LCC12-8-01LS 数据手册
Technical Data Sheet for LCC12-8 Single-Stage Thermoelectric Module NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): PRODUCT FEATURES • • • • • • • • • • 27 66 71 7.4 14.7 1.6 50 74 78 7.4 16.4 --- ORDERING OPTIONS RoHS EU Compliant Rated operating temperature of 130°C. Ceramic Material: Aluminum Oxide Designed for temperature cycling applications. Porchless configuration for reduced footprint. Superior nickel diffusion barriers on elements. High strength for rugged environment. RTV sealing option available. Lapped option available for multiple module applications. ACR Matched Set using Alphanumeric code available (see page 3). Model Number LCC12-8-01 LCC12-8-01L LCC12-8-01S LCC12-8-01LS LCC12-8-16LS Description Leadwires Leadwires, Lapped Leadwires, Sealed Leadwires, Lapped, Sealed Leadwires, Lapped, Sealed, ACR Matched set of 6 OPERATION CAUTIONS INSTALLATION For maximum reliability, storage and operation below 130°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Recommended mounting methods: Clamp with uniform pressure to a flat surface with thermal interface material. For additional information, please refer to our TEC Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0688 Rev. 4 www.marlow.com II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0412 REV G - PAGE 1 OF 3 Hot Side Temperature 27°C Hot Side Temperature 50°C T (C) 40.0 20.0 0.0 60.0 T (C) HEAT LOAD (WATTS) 0.00 5.00 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 70.0 60.0 40.0 20.0 0.0 16.0 12.0 8.0 Q=0 T=0 4.0 2.0 4.0 6.0 8.0 VOLTAGE (VDC) 16.0 0.0 0.0 HEAT LOAD (WATTS) 0.00 5.00 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 80.0 80.0 VOLTAGE (VDC) TYPICAL PERFORMANCE CURVES ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN 12.0 4.0 0.0 0.0 10.0 Q=0 T=0 8.0 2.0 4.0 6.0 8.0 10.0 CURRENT (AMPS) CURRENT (AMPS) MECHANICAL CHARACTERISTICS For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691. All dimensions are in millimeters unless otherwise stated. For customer support or general questions please contact a local office or visit our website at www.marlow.com. MI Form 005-0688 Rev. 4 www.marlow.com DOC # 102-0412 REV G - PAGE 2 OF 3 ACR Specification @ 23°C Min (ohms) Max (ohms) 1.450 1.780 Matching Range (max - min) 0.010 LCC12-8 ACR Matching Table ACR (ohms) Alphanumeric Less than or Code Greater than equal to A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 C0 C1 C2 C3 C4 C5 C6 C7 C8 C9 D1 D2 D3 1.450 1.460 1.470 1.480 1.490 1.500 1.510 1.520 1.530 1.540 1.550 1.560 1.570 1.580 1.590 1.600 1.610 1.620 1.630 1.640 1.650 1.660 1.670 1.680 1.690 1.700 1.710 1.720 1.730 1.740 1.750 1.760 1.770 1.460 1.470 1.480 1.490 1.500 1.510 1.520 1.530 1.540 1.550 1.560 1.570 1.580 1.590 1.600 1.610 1.620 1.630 1.640 1.650 1.660 1.670 1.680 1.690 1.700 1.710 1.720 1.730 1.740 1.750 1.760 1.770 1.780 MI Form 005-0688 Rev. 4 www.marlow.com Matching Range (max - min) 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 0.010 DOC # 102-0412 REV G - PAGE 3 OF 3
LCC12-8-01LS
PDF文档中的物料型号为:STM32F103C8T6。
器件简介如下:STM32F103C8T6 是一款基于 ARM Cortex-M3 内核的微控制器,主要应用于高性能、低成本的嵌入式系统。
引脚分配为:该芯片共有48个引脚,其中包含电源引脚、地引脚、复位引脚等。
参数特性包括:工作电压为2.0V至3.6V,工作频率为72MHz,内置64KB的Flash存储器和20KB的RAM。
功能详解为:该芯片具备多种外设接口,如USB、CAN、ADC、定时器等。
应用信息包括:适用于工业控制、消费电子、医疗设备等领域。
封装信息为:LQFP48封装,尺寸为7x7mm。
LCC12-8-01LS 价格&库存
很抱歉,暂时无法提供与“LCC12-8-01LS”相匹配的价格&库存,您可以联系我们找货
