NL1010T-01AC
NL1010T-01AC
    MARLOWINDUSTRIES,INC.
    TEM3.96X3.96X2.4MM
NL1010T-01AC 数据手册
Technical Data Sheet for NL1010T Single-Stage Thermoelectric Module NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): PRODUCT FEATURES • • • • • 27 61 0.47 1.0 0.8 0.75 50 67 0.53 1.0 1.0 -- ORDERING OPTIONS RoHS EU Compliant Rated operating temperature of 85°C Maximum process temperature is 120°C. Ceramic Material: Aluminum Oxide -01 and -02: External Metallization is Au flash, suitable for soldering. Model Number NL1010T-01AC NL1010T-02AC NL1010T-03AC Description Both Surfaces are Metallized Hot Side Exterior is Metallized No Metallization OPERATION CAUTIONS INSTALLATION For maximum reliability, storage and operation below 85°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. Recommended mounting methods: Bonding with thermal epoxy or soldering with metallized ceramics. For additional information, please refer to our TEC Installation Guide. II-VI Marlow – Dallas, TX USA 214-340-4900 877-627-5691 marlow.sales@ii-vi.com Marlow Industries Europe GmbH - Germany +49 (0) 6150 5439 - 403 info@marlow-europe.eu II-VI Japan Inc. 81 43 297 2693 (tel) center@ii-vi.co.jp www.ii-vi.co.jp MI Form 005-0808 Rev. A II-VI Singapore Pte., Ltd. (65) 6481 8215 (tel) info@ii-vi.com.sg Marlow Industries China, II-VI Technologies Beijing 86-10-643 98226 info@iivibj.com DOC # 102-0289 REV J - PAGE 1 OF 2 www.marlow.com Hot Side Temperature 50°C Hot Side Temperature 27°C T (C) 60.0 40.0 20.0 0.0 0.8 0.6 0.4 Q=0 T=0 0.2 0.0 0.0 0.2 0.4 0.6 0.8 1.0 CURRENT (AMPS) HEAT LOAD (WATTS) 80.0 0.00 0.05 0.10 0.15 0.20 0.25 0.30 0.35 0.40 0.45 60.0 T (C) HEAT LOAD (WATTS) 0.00 0.05 0.10 0.15 0.20 0.25 0.30 0.35 0.40 0.45 40.0 20.0 0.0 VOLTAGE (VDC) 80.0 VOLTAGE (VDC) TYPICAL PERFORMANCE CURVES ENVIRONMENT: ONE ATMOSPHERE DRY NITROGEN 1.2 0.8 0.6 0.4 Q=0 T=0 0.2 0.0 0.0 0.2 0.4 0.6 0.8 1.0 CURRENT (AMPS) 1.2 MECHANICAL CHARACTERISTICS For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691. Dimensions are in inches, and millimeters are in [ ]. For customer support or general questions please contact a local office or visit our website at www.marlow.com. Marlow reserves the right to make product changes without notice. MI Form 005-0808 Rev. A DOC # 102-0289 REV J - PAGE 2 OF 2 www.marlow.com
NL1010T-01AC
物料型号:NL1010T-01AC, NL1010T-02AC, NL1010T-03AC
器件简介:NL1010T是一款单级热电模块,符合RoHS标准,最高工作温度85°C,最大处理温度120°C,使用氧化铝陶瓷材料。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 额定工作温度:85°C - 最大过程温度:120°C - 陶瓷材料:氧化铝 - 外部金属化:-01和-02型适合焊接的金闪层
功能详解:文档中未提供详细的功能解释,但根据性能曲线图,可以推断该模块在不同热侧温度下的性能表现。
应用信息:文档中未明确提供应用信息,但根据性能和材料特性,可能适用于需要精确温度控制的场合。
封装信息:引脚为28 AWG(0.32mm)的实心锡铜线,模块尺寸为1.561英寸(39.6mm)x 2.00英寸(50.8mm)±0.25英寸(6.35mm)。
NL1010T-01AC 价格&库存
很抱歉,暂时无法提供与“NL1010T-01AC”相匹配的价格&库存,您可以联系我们找货
